U460-002-2AM-C
U460-002-2AM-C
    TRIPPLITE
    2-PORT USB 3.1 GEN 1 PORTABLE HU
U460-002-2AM-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Multiport Adapter, 2x USB-A and 1x USBC Ports, Card Reader and PD Charging, USB 3.0, White Highlights ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps ● USB-C PD charging port supports power input up to 20V 3A (60W) ● USB-A port provides up to 5V/1.5A (7.5W) of fast-charging power. ● Compact and easy to carry in a pocket, purse or laptop bag ● Reversible USB-C plug connects in either direction ● Plug-and-play operation with no software or drivers required MODEL NUMBER: U460-002-2AM-C System Requirements ● Source device with USB-C or Thunderbolt 3 port Package Includes Adds USB-A, USB-C PD charging and memory card ports to the USB-C or Thunderbolt 3 port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. Description The U460-002-2AM-C USB 3.1 Gen 1 USB-C Portable Hub/Adapter expands the potential of your tablet, laptop, Chromebook, MacBook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for adding a thumb drive and other USB peripherals, powering and charging a PD Charging-compliant mobile device, and accessing data on a memory card—all at the same time. The plug-and-play U460-002-2AM-C requires no software, drivers or external power. Connect the reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. The dual USB-A ports accept USB peripherals, such as a flash drive, mouse, keyboard or printer. The dedicated fast-charging port provides up to 5V/1.5A (7.5W) for charging smartphones and other mobile devices. Both ports support fast USB 3.1 Gen 1 data transfer rates up to 5 Gbps and are backward compatible with previous USB generations, so you can continue using older peripherals while getting highspeed performance from new devices. The USB-C Power Delivery (PD) port provides power and charging to the PD Charging-compliant device (such as a MacBook or Chromebook) connected to the U460-002-2AM-C. Connect the device’s AC wall charger to the USB-C PD port, which supports power input up to 20V 3A (60W). The memory card slots support MicroSD, SD, SDHC, SDXC and MMC cards for convenient access to digital photos, camcorder videos, smartphone data and other essential files. Features Turn Your Device’s USB-C Port into a Multiport Workstation ● Ideal for adding USB peripherals, powering and charging a PD Charging-compliant mobile device, and accessing memory card data simultaneously ● Plug-and-play operation with no software, drivers or external power required ● About the size of a credit card for easy carrying in a pocket, purse or laptop bag Connect USB Peripherals ● Dual USB-A ports accept flash drives, mice, keyboards, printers and other USB peripherals ● Fast-charging USB-A port provides up to 5V/1.5A (7.5W) for charging mobile devices ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 and USB 1.1 1/4 ● U460-002-2AM-C USB 3.1 Gen 1 USB-C Portable Hub/Adapter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Note: Host must support USB OTG (On-the-Go) Charge a Connected Device ● USB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C/Thunderbolt 3 device ● Supports power input up to 20V 3A (60W Note: USB-C PD port does not support Quick Charge (QC). Access Memory Card Files ● Card reader supports MicroSD, SD, SDHC, SDXC and MMC memory cards for convenient access to photos, videos and other data Built-In Cable with Reversible USB-C Connector ● Fumble-free reversible USB-C plug connects in either direction for quick connection every time Specifications OVERVIEW UPC Code 037332193780 Product Type Multiport Adapter Host Connector USB C (MALE) VIDEO Number of Monitors Supported 1 Extended Mode No Mirror Mode No DATA Data Ports (2) USB A (FEMALE); USB C (FEMALE) Data Ports Details (2) USB-A - USB 3.2 Gen 1 (5 Gbps); USB-C - USB 3.2 Gen 1 (5 Gbps) STORAGE Card Slots SD (FEMALE); MICRO SD (FEMALE) Card Slots Details SD 3.0 Memory Card slots (SD and MicroSD) INPUT Built-In Cable Length (ft.) 0.36 Built-In Cable Length (m) 0.11 Built-In Cable Length (in.) 4.33 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 2 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 CHARGING Total Charging Watts 60 Charging Ports USB-C: 60W (20V 3A) Power Delivery (PD 2.0); USB-A: 5V 1.5A (7.5W) Charging Ports / Amps 1.5A; 3A PHYSICAL Color White Material of Construction Plastic Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.9 mm Wire Gauge (AWG) 28/34 Shipping Dimensions (hwd / in.) 1.00 x 3.90 x 5.50 Shipping Weight (lbs.) 0.14 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 1.1 x 9.4 x 4.0 Unit Packaging Type Box Unit Weight (lbs.) 0.1 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32 to 113 °F (0 to 45 °C) Storage Temperature Range 14 to 158 °F (-10 to 70 °C) Relative Humidity 5% to 90% RH, Non-Condensing BTUs 6.8 BTU/Hr Operating Humidity Range 10 - 85 % RH, Non-Condensing Storage Humidity Range 5 - 90 % RH, Non-Condensing 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Provided to Connected Device(s) 5V 1.5A (7.5W) Output USB-A port, Up to 20V 3A (60W) Input (USB-C) CONNECTIONS Number of Ports 5 Side A - Connector 1 USB C (MALE) Side B - Connector 1 (2) USB 3.0 A (FEMALE) Side B - Connector 2 USB C (FEMALE) Side B - Connector 3 MICRO SD (FEMALE) Side B - Connector 4 SD (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Data Transfer Rate 5 Gbps USB Hub Ports Yes USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support Yes Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No SD Card Specification SD; Micro SD STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U460-002-2AM-C 价格&库存
很抱歉,暂时无法提供与“U460-002-2AM-C”相匹配的价格&库存,您可以联系我们找货
