2992
2992
    ADAFRUIT
    BATTERY CONTACT NEGATIVE SMD
2992 数据手册
Ethernet Hub and USB Hub w/ Micro USB OTG Connector PRODUCT ID: 2992 DESCRIPTION - One can never have enough socks, or USB ports. Add some more USB and Ethernet capability to your Raspberry Pi Zero or, really, any kind of tablet or computer with an OTG connector with this USB 2.0 and Ethernet Hub! This handy combo-hub has 3 USB 2.0 ports, and a AX88772A Ethernet transceiver. This chipset is really common and can be used by any Linux, Mac or Windows computer. It's particularly handy for the Raspberry Pi Zero which is tight on USB ports and has no Ethernet out. We did some basic tests and got 11+ MB/s transfer speeds on our Pi Zero. Note that Ethernet draws a lot of power and you'll be looking at 280mA current draw when the hub is plugged in, even if the Ethernet itself isn't being used. https://www.adafruit.com/products/2992 2/24/2016 Technical Details Dimensions: 97mm x 24mm x 16mm / 3.8" x 0.9" x 0.6" Weight: 33g
很抱歉,暂时无法提供与“2992”相匹配的价格&库存,您可以联系我们找货
