USB-C to DVI Adapter with USB-A Port and PD
Charging, White
MODEL NUMBER: U444-06N-DU-C
Highlights
Supports USB DisplayPort
Alternate Mode for transmitting
video
Supports DVI video resolutions
up to 1920 x 1080 (1080p) @ 60
Hz
PD Charging port supports
power input up to 20V 3A
BC 1.2-compliant USB-A port
provides up to 1.5A of fastcharging power
Reversible USB-C plug
connects in either direction
Plug-and-play operation with no
software or drivers required
Applications
Transmit 1080p video to a DVI
display via the USB-C port on
your laptop, computer or tablet
Charge the host device with up
to 60 watts of power via the PD
Charging port
Adds DVI, USB-A and USB-C PD charging ports to the USB-C or Thunderbolt 3 port on your tablet,
laptop, notebook, MacBook, Chromebook, smartphone or PC.
System Requirements
Features
Turn Your Device’s USB-C Port into a Multiport WorkstationIdeal for transmitting video to a large
display, adding a USB peripheral, and powering and charging a PD Charging-compliant mobile device
simultaneouslyPlug-and-play operation with no software, drivers or external power requiredAbout the size
of a credit card for easy carrying in a pocket, purse or laptop bag
Transmit Crystal-Clear 1080p Video to DVI DisplayCompatible with USB-C or Thunderbolt 3 source
devices that support USB DisplayPort Alternate ModeSupports DVI single-link video resolutions up to
1920 x 1080 (1080p) @ 60 HzSupports DVI digital transfer rates up to 6.75 Gbps (2.25 Gbps per
channel)Extends video from your primary display to anotherDuplicates the same video on 2
displaysConverts a secondary display to your primary display
Connect a USB PeripheralUSB-A port accepts flash drives, mice, keyboards, printers and other USB
peripheralsSupports USB 3.1 Gen 1 data transfer rates up to 5 GbpsBackward compatible with USB 2.0
and USB 1.1BC 1.2-compliant port provides up to 1.5A of fast-charging power to mobile devicesNote:
Host must support USB OTG (On-the-Go)
Charge a Connected DeviceUSB-C PD port connects to wall charger to power and charge the
connected PD Charging-compliant USB-C/Thunderbolt 3 deviceSupports power input up to 20V 3A
(60W)Note: USB-C PD port does not support Quick Charge (QC).
Built-In Cable with Reversible USB-C ConnectorFumble-free reversible USB-C plug connects in either
direction for quick connection every time
Specifications
OVERVIEW
UPC Code
037332193902
1/4
Source device with USB-C or
Thunderbolt 3 port that supports
Mode
Display device with DVI input
(DVI port)
Package Includes
U444-06N-DU-C USB 3.1 Gen 1
Owner’s manual
Product Type
Technology
DVI
Host Connector
USB C (MALE)
VIDEO
Video Input
USB C (MALE)
Video Output
DVI-I DUAL LINK (FEMALE)
Number of Monitors Supported
1
Video Ports
Video Ports Details
HDCP 1.3
Resolutions Supported
1920 x 1080 @ 60 Hz (1080p)
Supported Resolutions
1280x720 (720p); 1920x1080 (1080p)
Max Supported Video Resolution
DVI: 1920 X 1080 (1080P) @ 60HZ
Extended Mode
No
Mirror Mode
No
3D Video Supported
No
DATA
Data Ports
USB A (FEMALE)
Data Ports Details
USB-A - USB 3.2 Gen 1 (5 Gbps)
INPUT
Built-In Cable Length (ft.)
0.36
Built-In Cable Length (m)
11.0
Built-In Cable Length (in.)
4.33
Bus Powered
Yes
Product Length (in.)
6
Product Length (cm.)
15.24
Product Length (ft.)
0.5
Product Length (m.)
0.15
BATTERY
Battery Charging (5V/1.5A Port)
Yes
POWER
USB Power Delivery (PD) Charging
Support
Yes
2/4
Specification
2.0
CHARGING
Total Charging Watts
60
Charging Ports Details
20V/3A (60W) PD Charging
Charging Ports
USB-A: 5V 1.5A (7.5W); USB-C: 60W (20V 3A) Power Delivery (PD 2.0)
Charging Ports / Amps
1.5A; 3A
PHYSICAL
Color
White
Material of Construction
Plastic
Cable Jacket Rating
VW-1
Shipping Dimensions (hwd / cm)
2.29 x 11.18 x 14.22
Shipping Dimensions (hwd / in.)
0.90 x 4.40 x 5.60
Shipping Weight (kg)
0.18
Shipping Weight (lbs.)
0.40
Unit Dimensions (hwd / in.)
0.57 x 3.1 x 1.6
Unit Packaging Type
Box
Unit Weight (kg)
0.04
Unit Weight (lbs.)
0.08
ENVIRONMENTAL
Operating Temperature Range
32 to 113 °F (0 to 45 °C)
Storage Temperature Range
14 to 158 °F (-10 to 70 °C)
BTUs
4.1 BTU/Hr
Power Consumption (Watts)
1.2
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
Power Provided to Connected
Device(s)
5V 0.9A (4.5W) Output (USB-A), Up to 20V 3A (60W) Input (USB-C)
CONNECTIONS
Ports
3
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK)
Side B - Connector 2
USB 3.0 A (FEMALE)
Side B - Connector 3
USB C (FEMALE)
3/4
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
HDCP Specification
1.3
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
UASP Support
No
Auto MDIX Support
No
Full Duplex Support
No
Suspend Mode Support
No
Remote Wakeup Support
No
STANDARDS & COMPLIANCE
Certifications
CE, FCC, RoHS, REACH
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
4/4
很抱歉,暂时无法提供与“U444-06N-DU-C”相匹配的价格&库存,您可以联系我们找货
