U460-003-3AM
U460-003-3AM
    TRIPPLITE
    3-PORT USB 3.1 GEN 1 PORTABLE HU
U460-003-3AM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3-Port USB-C Hub with Card Reader, USB-C to 3x USB-A Ports and SD Reader, USB 3.0, White MODEL NUMBER: U460-003-3AM Highlights ● USB-C 3.1 Type-C hub is compatible with all USB-C and Thunderbolt 3 devices ● Connects external hard drives, keyboard, printer and other USB peripherals ● Supports USB 3.1 Gen 1 speeds up to 5 Gbps to ensure fast data transfers ● Reversible USB-C plug connects in either direction for immediate no-fuss use ● Plug-and-play operation with no software required for easy, immediate installation Applications ● Charge and power a tablet, smartphone or other compatible mobile device ● Connect up to 3 USB peripherals, such as an external hard drive, flash drive and printer ● Transfer photos, videos and other important files between your MacBook or Chromebook and a memory card Adds 3 USB-A ports and memory card slots to the USB-C or Thunderbolt 3 port on your MacBook, Chromebook, tablet or notebook. Features USB-C 3.1 Hub Connects USB Peripherals to Your USB-C or Thunderbolt 3 Device This USB-C hub allows you to connect up to three USB peripherals to your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. This lets you expand the potential of your device by connecting USB peripherals, such as an external hard drives, flash drives, power meters and printers. You can also insert a memory card into the corresponding slot to transfer data. The memory card reader supports MicroSD, SD, SDHC, SDXC and MMC cards for convenient access to digital photos, camcorder videos, smartphone data and other essential files. Only one memory card may be used at a time. Connects USB Peripherals and Transfers Data at Fast USB 3.1 Gen 1 Speeds In addition to accepting USB peripherals, the USB ports provide up to 0.9 amps each for charging and powering smartphones and other mobile devices. All three USB ports and the memory card slot transfer data at speeds up to 5 Gbps, which is 10 times faster than USB 2.0. The USB ports are backward compatible with previous USB generations, so you can continue using older peripherals while getting highspeed performance from new devices. Note: Host must support USB OTG (On-the-Go) Built-In USB-C Cable Connects in Either Direction Connect the reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. Ready to Use Right Out of the Package The plug-and-play USB Type-C hub is specifically designed for use with the MacBook, Google Chromebook Pixel and other laptops, tablets and devices equipped with a USB-C or Thunderbolt 3 port. It requires no software, drivers or external power. It’s about the size of a credit card to make it easy to carry in a pocket, backpack or laptop bag for use anywhere. Specifications OVERVIEW UPC Code 037332193766 1/4 System Requirements ● Device with USB-C or Thunderbolt 3 port (USB 3.1 port needed to achieve USB 3.1 speeds) Package Includes ● U460-003-3AM USB 3.1 Gen 1 USB-C Hub, 5 Gbps, White ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Type Hub Host Connector USB C (MALE) VIDEO Number of Monitors Supported 0 Extended Mode No Mirror Mode No DATA Data Ports (3) USB A (FEMALE) Data Ports Details (3) USB-A - USB 3.2 Gen 1 (5 Gbps) STORAGE Card Slots SD (FEMALE); MICRO SD (FEMALE) Card Slots Details SD 3.0 Memory Card slots (SD and MicroSD) INPUT Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) No POWER Power Consumption (Watts) 2.4 CHARGING Charging Ports / Amps (3) 0.9A PHYSICAL Color White Material of Construction Plastic Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 0.90 x 4.00 x 5.60 Shipping Weight (lbs.) 0.16 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.11 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32 to 113 °F (0 to 45 °C) Storage Temperature Range 14 to 158 °F (-10 to 70 °C) BTUs 8.2 Operating Humidity Range 10 - 85 % RH Storage Humidity Range 5 - 90 % RH CONNECTIONS Number of Ports 5 Side A - Connector 1 USB C (MALE) Side B - Connector 1 (3) USB 3.0 A (FEMALE) Side B - Connector 2 MICRO SD (FEMALE) Side B - Connector 3 SD (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support Yes Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No SD Card Specification SD; Micro SD STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U460-003-3AM 价格&库存
很抱歉,暂时无法提供与“U460-003-3AM”相匹配的价格&库存,您可以联系我们找货
