1000 Eaton Boulevard
Cleveland, OH 44122
United States
3-Port USB-C Hub with LAN Port and Power
Delivery, USB-C to 3x USB-A Ports and Gbe, USB
3.0, White
Highlights
Supports USB 3.1 Gen 1
speeds up to 5 Gbps to ensure
fast data transfers
Power Delivery cable provides
3A (60W) power output for
charging connected device
Connects you to a wired
10/100/1000 Ethernet network
when Wi-Fi is unavailable
Reversible USB-C plug
connects in either direction for
immediate no-fuss use
Plug-and-play operation with no
software required for easy,
immediate installation
MODEL NUMBER: U460-003-3AG-C
Applications
Save data from your computer
to a USB thumb drive or
external hard drive
Access a wired Gigabit Ethernet
network in a location with no or
spotty Wi-Fi
Charge your notebook or laptop
by connecting its wall charger to
the USB-C PD Charging port
Features
Portable USB 3.1 Hub Turns Your Device’s USB-C or Thunderbolt 3 Port into a WorkstationThis
USB-C adapter with Power Delivery (PD) Charging expands the potential of your tablet, laptop,
Chromebook, MacBook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for adding a thumb
drive and other USB peripherals, powering and charging a PD Charging-compliant mobile device, and
connecting to a Gigabit Ethernet network—all at the same time.
Connect a USB
microphone/headset to record a
podcast or listen to music
Write a report using a USB
keyboard with your tablet or
Android phone
Adds USB-C PD charging, Gigabit Ethernet and 3 USB-A ports to the USB-C or Thunderbolt 3 port on
your MacBook, Chromebook or tablet.
PD Charging Port Charges the Connected Chromebook, MacBook Pro or Other DeviceThe USB-C
PD charging port provides power and charging to the connected PD Charging-compliant device (such as a
MacBook, Chromebook or Android smartphone). Connect the device’s AC wall charger to the USB-C PD
port, which supports power input up to 20V 3A (60W). That’s sufficient wattage to fast-charge, sync and
power most high-capacity devices, including the MacBook Pro.Note: USB-C PD port does not support
Quick Charge (QC)
System Requirements
Connects USB Peripherals and Transfers Data at Fast USB 3.1 Gen 1 SpeedsThree USB-A ports
transfer data at speeds up to 5 Gbps, which is 10 times faster than USB 2.0, between your device and up
to three USB peripherals, such as a flash drive, printer and keyboard/mouse. The USB Battery Charging
(BC) 1.2 port provides power output up to 5V 1.5A (5W) for charging a connected device. The USB ports
are backward compatible with previous USB generations, so you can continue using older peripherals
while getting high-speed performance from new devices.Note: Host must support USB OTG (On-the-Go)
Package Includes
Accesses a Wired Gigabit Ethernet NetworkThe RJ45 port offers access to a Gigabit Ethernet network
when Wi-Fi is unavailable or when a wired connection offers faster speeds. Connect using a UTP cable
(Tripp Lite N201-Series Cat6 cables sold separately), and enjoy true 10/100/1000 Mbps Ethernet speeds
for fast data transfers.
Reversible USB-C Connector Attaches in Either DirectionUnlike traditional USB cables that connect in
only one direction, the reversible USB-C male connector plugs into a USB-C or Thunderbolt 3 port in
either direction for a fumble-free connection every time.
Ready to Use Right from the Package, So You Can Plug and Play ImmediatelyThe plug-and-play
1/4
Source device with USB-C or
Thunderbolt 3 port
Ethernet network with speeds
up to 1000 Mbps
U460-003-3AG-C USB 3.1 Gen
1 Portable Hub/Adapter
Owner’s manual
Cleveland, OH 44122
United States
USB-C dock is specifically designed for use with the MacBook Pro, Google Chromebook Pixel and other
laptops, tablets and devices equipped with a USB-C or Thunderbolt 3 port. It requires no software or
drivers. It’s smaller than a standard smartphone, making it easy to pack into a pocket, backpack or laptop
bag for multiport convenience wherever you go.
Specifications
OVERVIEW
UPC Code
037332193810
Product Type
Hub
Technology
Cat5/5e; Cat6
Host Connector
USB C (MALE)
VIDEO
Number of Monitors Supported
Video Ports
(3) USB A (FEMALE)
Extended Mode
No
Mirror Mode
No
DATA
Data Ports
(3) USB A (FEMALE)
Data Ports Details
(3) USB-A - USB 3.2 Gen 1 (5 Gbps)
NETWORK
Network Ports
RJ45 (FEMALE)
INPUT
Bus Powered
Yes
Product Length (in.)
6
Product Length (cm.)
15.24
Product Length (ft.)
0.5
Product Length (m.)
0.15
BATTERY
Battery Charging (5V/1.5A Port)
Yes
POWER
Power Consumption (Watts)
2.50
2/4
Cleveland, OH 44122
United States
USB Power Delivery (PD) Charging
Support
Yes
Specification
20V/3A
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green - Power, Orange - Activity
CHARGING
Total Charging Watts
60
Charging Ports
USB-C: 60W (20V 3A) Power Delivery (PD 2.0); USB-A: 5V 1.5A (7.5W)
Charging Ports / Amps
(1) 1.5A; (1) 3A
PHYSICAL
Color
White
Material of Construction
Plastic
Cable Jacket Rating
VW-1
Shipping Dimensions (hwd / in.)
5.51 x 0.91 x 3.94
Shipping Weight (lbs.)
0.13
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
Unit Weight (lbs.)
0.09
Unit Weight (kg)
0.04
ENVIRONMENTAL
Operating Temperature Range
32 to 113 °F (0 to 45 °C)
Storage Temperature Range
14 to 158 °F (-10 to 70 °C)
BTUs
8.5 BTU/Hr
Operating Humidity Range
10 - 85 % RH, Non-Condensing
Storage Humidity Range
5 - 90 % RH, Non-Condensing
Power Provided to Connected
Device(s)
Up to 20V 3A (60W) Input (USB-C), 5V 1.5A (7.5W) Output USB port
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3; 802.3az; 802.3u; 802.3x
CONNECTIONS
Number of Ports
5
3/4
Cleveland, OH 44122
United States
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
(3) USB 3.0 A (FEMALE)
Side B - Connector 2
RJ45 (FEMALE)
Side B - Connector 3
USB C (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
UASP Support
Yes
Auto MDIX Support
Yes
Full Duplex Support
Yes
Suspend Mode Support
Yes
Remote Wakeup Support
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“U460-003-3AG-C”相匹配的价格&库存,您可以联系我们找货
