B156-004-V2
B156-004-V2
    TRIPPLITE
    4-PORTDISPLAYPORT1.2MULTI-STR
B156-004-V2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer with DisplayPort 1.2-compatible graphics card (e.g. AMD Radeon with AMD Eyefinity) required for video wall mode. Backward compatible with most DisplayPort 1.1a equipment running current graphics Highlights ● Supports UHD video resolutions up to 4K @ 60Hz (3840 x 2160) ● Built-in 6 in. cable connects directly to DisplayPort source ● Supports up to 48-bit Deep Color (16 bits per channel) ● Works with all operating systems ● Supports DTS-HD, Dolby TrueHD and 7.1-channel surround sound drivers with feature set limited to that of your equipment. Compatibility with older graphics cards not guaranteed. MST-compliant DisplayPort 1.2 graphics cards are limited to a bandwidth of 21.6 Gbps amongst all monitors with higher resolution monitors using up more bandwidth. 1080p monitors will use up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display settings interface of your graphics card. If the total percentage of bandwidth taken up by all the connected monitors exceeds 100%, an image will not display on one or more of them.Maximum supported video resolutions and number of monitors will be dependent upon your graphics card. Check the specifications of your graphics card to determine its capabilities. 4-Port DisplayPort Multi-Monitor Splitter, MST Hub, 4K 60Hz UHD, DP1.2, TAA System Requirements ● Computer with DisplayPort 1.2compatible graphics card (e.g. AMD Radeon with AMD Eyefinity) required for video wall mode. ● Backward compatible with most DisplayPort 1.1a equipment running current graphics drivers with feature set limited to that of your equipment. Compatibility with older graphics cards not guaranteed. ● Mac OS X does not support MST for NVIDIA and Intel Graphics Processor Units, limiting video display on connected monitors to mirror mode. ● MST-compliant DisplayPort 1.2 graphics cards are limited to a bandwidth of 21.6 Gbps amongst all monitors with higher resolution monitors using up more bandwidth. 1080p monitors will use up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display settings interface of your graphics card. If the total percentage of bandwidth taken up by all the connected monitors exceeds 100%, an image will not display on one or more of them. ● Monitor(s) with DisplayPort input. MODEL NUMBER: B156-004-V2 Displays the same image on 4 DisplayPort monitors, extends the desktop across them, or combines all into one large monitor. Ideal for digital signage in schools, churches, conference rooms, trade shows and retail outlets. Description The B156-004-V2 4-Port DisplayPort 1.2 MST Hub connects up to four DisplayPort monitors to the DisplayPort output on your computer. Ideal for digital signage in schools, churches, conference rooms, trade shows, hotels and retail outlets, this hub allows you to display the same image on all four monitors, extend the desktop across them, or combine all four into one large monitor in video wall mode. The B156-004-V2 is compliant with DisplayPort 1.2 and backward compatible with versions 1.1 and 1.1a with the feature set being limited to that of your equipment. It supports high-definition video resolutions up to 1920 x 1080 (1080p) per monitor. In video wall mode, this hub supports expanded video resolutions, such as 4K @ 60Hz (3840 x 2160) in a 2 x 2 monitor configuration or 7680 x 1080 in a vertical 4 x 1 configuration. This MST hub also supports HDCP, EDID, DDC and 48-bit Deep Color (16 bits per channel), as well as DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio. It works with all operating systems. Plugand-play convenience means no software or drivers are needed. A built-in six-inch cable connects directly to a DisplayPort source. LEDs indicate when the monitors are receiving a signal. The B156-004-V2 complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features Connects Up to 4 DisplayPort Monitors to Your Computer’s DisplayPort Output 1/4 Package Includes ● B156-004-V2 4-Port DisplayPort 1.2 MST Hub 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Ideal for digital signs in schools, churches, conference rooms, trade shows and retail settings ● Displays same image on 4 monitors simultaneously in mirror mode ● Extends desktop across 4 monitors in extended mode ● Combines 4 monitors into one large monitor in video wall mode ● Built-in 6 in. cable connects directly to DisplayPort source ● LEDs indicate when monitors are receiving a signal Meets the Latest Performance Standards ● Supports HD video resolutions up to 1920 x 1080 per monitor ● Supports expanded resolutions in video wall mode, such as 4K @ 60Hz (3840 x 2160) in a 2 x 2 monitor configuration or 7680 x 1080 in a vertical 4 x 1 configuration ● Supports HDCP, EDID and DDC ● Supports 48-bit Deep Color (16 bits per channel) ● Supports DTS-HD, Dolby True HD and 7.1-channel surround sound audio ● Backward compatible with DisplayPort 1.1 and 1.1a Easy to Use Almost Anywhere ● Works with all operating systems ● Plug and play—no software or drivers required TAA Compliant ● Complies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332193209 Technology DisplayPort Host Connector DISPLAYPORT (MALE) VIDEO Max Supported Video Resolution 4K @ 60Hz (3840 x 2160) Max Supported Color Depth 48-bit Deep Color 3D Video Supported Yes AUDIO Audio Specification DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A 2/4 ● External power supply with NEMA 1-15P plug and 5 ft. cord (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 2A) ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 4 USER INTERFACE, ALERTS & CONTROLS LED Indicators (x4) Orange (Monitor Signal); (x1) Green (Power) PHYSICAL Color Black Material of Construction Plastic Rackmountable No Shipping Dimensions (hwd / in.) 2.20 x 6.30 x 8.40 Shipping Dimensions (hwd / cm) 5.59 x 16.00 x 21.34 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 10.8 x 7.5 x 2.4 Unit Dimensions (hwd / mm) 108 x 75 x 24 Unit Packaging Type Box Unit Weight (lbs.) 0.2 Unit Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range 14 to 167 °F (-10 to 75 °C) Storage Temperature Range -4 to 176 °F (-20 to 80 °C) Relative Humidity 0% to 85%, Non-Condensing BTUs 13.65 BTU/Hr COMMUNICATIONS EDID Compatible Yes CONNECTIONS Number of Ports 4 Side A - Connector 1 DISPLAYPORT (MALE) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 (4) DISPLAYPORT (FEMALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS Displayport Specification 1.2 HDCP Specification 1.3 Driver Required No MST Support Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B156-004-V2 价格&库存
很抱歉,暂时无法提供与“B156-004-V2”相匹配的价格&库存,您可以联系我们找货
B156-004-V2
  • 1+723.42329
库存:2
