B155-002-DVI-V2
B155-002-DVI-V2
    TRIPPLITE
    2-PORTMINIDISPLAYPORT1.2TOD
B155-002-DVI-V2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer with Mini DisplayPort 1.2-compatible graphics card (e.g. AMD Radeon with AMD Eyefinity) required for video wall mode. Backward compatible with most Mini DisplayPort 1.1a equipment running Highlights ● Supports HD video resolutions up to 1080p @ 60 Hz (1920 x 1080) ● Built-in 6 in. cable connects directly to Mini DisplayPort source ● Supports up to 48-bit Deep Color (16 bits per channel) ● Works with all operating systems ● Supports DTS-HD, Dolby TrueHD and 7.1-channel surround sound current graphics drivers with feature set limited to that of your equipment. Compatibility with older graphics cards not guaranteed. MST compliant DisplayPort 1.2 graphics cards are limited to a bandwidth of 21.6 Gbps amongst all monitors, with higher resolution monitors using up more bandwidth. 1080p monitors will use up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display settings interface for your graphics card. If the total percentage of bandwidth taken up by all of the connected monitors exceeds 100%, an image will not display on one or more of them.Maximum supported video resolutions and number of monitors depend on your graphics card. Check graphics card specifications to determine its capabilities. 2-Port Mini DisplayPort to DVI Multi-Monitor Splitter, MST Hub, DP1.2, TAA System Requirements ● Computer with Mini DisplayPort 1.2-compatible graphics card (e.g. AMD Radeon with AMD Eyefinity) required for video wall mode. ● Backward compatible with most Mini DisplayPort 1.1a equipment running current graphics drivers with feature set limited to that of your equipment. Compatibility with older graphics cards not guaranteed. ● Mac OS X does not support MST for NVIDIA and Intel Graphics Processor Units, limiting video display on connected monitors to mirror mode. ● Maximum supported video resolutions and number of monitors depend on your graphics card. Check graphics card specifications to determine its capabilities. ● Monitor(s) with DVI input. MODEL NUMBER: B155-002-DVI-V2 Displays the same image on 2 DVI monitors, extends the desktop across them, or combines both into one large monitor. Ideal for digital signage in schools, churches, conference rooms, trade shows and retail outlets. Description Package Includes The B155-002-DVI-V2 2-Port Mini DisplayPort 1.2 to DVI MST Hub connects two DVI monitors to the Mini DisplayPort output on your computer. Ideal for digital signage in schools, churches, conference rooms, trade shows, hotels and retail outlets, this hub allows you to display the same image on both monitors, extend the desktop across them, or combine both as one large monitor in video wall mode. The B155-002-DVI-V2 is compliant with Mini DisplayPort 1.2 and backward compatible with versions 1.1 and 1.1a with the feature set being limited to that of your equipment. It supports high-definition video resolutions up to 1080p @ 60 Hz (1920 x 1080) on each monitor. Expanded video resolutions are supported when displaying in video wall mode, such as 3840 x 1080 in a horizontal 1 x 2 monitor configuration or 1920 x 2160 in a vertical 2 x 1 monitor configuration. The B155-002-DVI-V2 also supports HDCP, EDID, DDC and 48-bit Deep Color (16 bits per channel), as well as DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio. This MST hub works with all operating systems. Plug-and-play convenience means no software, drivers or external power supply is needed. A built-in six-inch cable connects directly to a Mini DisplayPort source. LEDs indicate when the monitors are receiving a signal. The B155-002-DVI-V2 complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features 1/4 ● B155-002-DVI-V2 2-Port Mini DisplayPort 1.2 to DVI MST Hub ● USB Micro-B cable, 3 ft. ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Connects 2 DVI Monitors to Your Computer’s Mini DisplayPort OutputIdeal for digital signs in schools, churches, conference rooms, trade shows and retail settingsDisplays same image on 2 monitors simultaneously in mirror modeExtends desktop across 2 monitors in extended modeCombines 2 monitors into one large monitor in video wall modeBuilt-in 6 in. cable connects directly to Mini DisplayPort sourceLEDs indicate when monitors are receiving a signal Meets the Latest Performance StandardsSupports HD video resolutions up to 1080p @ 60 Hz (1920 x 1080)Expanded video resolutions are supported in video wall mode, such as 3840 x 1080 in a horizontal 1 x 2 monitor configuration or 1920 x 2160 in a vertical 2 x 1 configurationSupports HDCP, EDID and DDCSupports 48-bit Deep Color (16 bits per channel)Supports DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio Easy to Use Almost AnywhereWorks with all operating systemsPlug and play—no software, drivers or external power supply requiredIncluded USB Micro-B cable provides power TAA CompliantComplies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332193438 Technology DVI; DisplayPort Host Connector MINI DISPLAYPORT (MALE) VIDEO Max Supported Video Resolution 1080p @ 60 Hz (1920 x 1080) Max Supported Color Depth 48-bit Deep Color 3D Video Supported Yes POWER Power Consumption (Watts) 4.1 USER INTERFACE, ALERTS & CONTROLS LED Indicators (x2) Orange (Monitor Signal) PHYSICAL Color Black Material of Construction Plastic Rackmountable No Shipping Dimensions (hwd / in.) 1.70 x 5.40 x 7.80 Shipping Dimensions (hwd / cm) 4.32 x 13.72 x 19.81 Shipping Weight (lbs.) 0.42 Shipping Weight (kg) 0.19 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 7.6 x 6.15 x 2.55 Unit Dimensions (hwd / mm) 61.5 x 76 x 25.5 Unit Packaging Type Box Unit Weight (lbs.) 0.154 Unit Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range 14 to 167 F (-10 to 75 C) Storage Temperature Range -4 to 176 F (-20 to 80 C) Relative Humidity 0% to 85%, Non-Condensing BTUs 14 BTU/Hr COMMUNICATIONS EDID Compatible Yes CONNECTIONS Number of Ports 2 Side A - Connector 1 MINI DISPLAYPORT (MALE) Side A - Connector 2 MICRO-USB B (FEMALE) Side B - Connector 1 (2) DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS Displayport Specification 1.2 HDCP Specification 1.3 Driver Required No MST Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B155-002-DVI-V2 价格&库存
很抱歉,暂时无法提供与“B155-002-DVI-V2”相匹配的价格&库存,您可以联系我们找货
