U215-002
U215-002
    TRIPPLITE
    2-PORTUSB2.0HI-SPEEDPRINTER/
U215-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port USB 2.0 Printer/Peripheral Sharing Switch Highlights ● Switch between computers via mouse, hotkey or manual button ● Supports data transfer rates up to 480 Mbps ● Easy setup with included optional software CD ● No power adapter required MODEL NUMBER: U215-002 System Requirements ● 1 or 2 computers with available USB ports ● Switch is compatible with all USB-enabled operating systems ● Optional software is compatible with Windows (XP and later) and Mac (OS X 10.3 and later) Package Includes Allows 2 computers to share one USB 2.0 peripheral, such as a printer, scanner or external hard drive, saving you money, space and time. Description The U215-002 2-Port USB 2.0 Hi-Speed Printer/Peripheral Sharing Switch saves you money, time and precious workspace by letting you connect two computers to a single USB peripheral. Recommended for home and small offices, this sharing switch eliminates the cost of buying two printers, two scanners, two hard drives, etc., as well as the problem of where to put them and their cables. One-touch port switching lets you switch between computers using a mouse, hotkeys or manual pushbutton. Idle time-out switching ensures all data is sent from the active printer buffer before switching ports. A taskbar icon indicates the connected device’s status. LEDs on the unit indicate which computer currently controls the device. The U215-002 is compatible with USB 2.0 and USB 1.1 devices and supports data transfer rates up to 480 Mbps. No external power supply required. Switch is compatible with all USB-enabled Operating Systems. Optional CD software is compatible with Windows (XP and later) and Mac (OS X 10.3 and later). NOTE: Customers are encourage to use the 1.5 ft. USB cables provided between the source (e.g. PC) and switch. Using longer cables could cause an intermittent or connection loss. Features Connect 2 Computers to a Single USB Device ● Recommended for printers, scanners, hard drives and other USB peripherals ● Saves money, time and workspace ● Ideal for home and small offices ● Compatible with USB 2.0 and USB 1.1 peripherals ● Supports data transfer rates up to 480 Mbps One-Touch Port Switching ● Switch between computers with mouse, hotkey or manual pushbutton ● All data sent from active printer buffer before switching ports ● Taskbar icon indicates device status ● LEDs indicate computer control Easy Setup and Broad Compatibility ● Switch is compatible with all USB-enabled Operating Systems 1/3 ● U215-002 2-Port USB 2.0 HiSpeed Printer/Peripheral Sharing Switch ● (2) USB 2.0 cables (A/B), 1.5 ft. ● Installation CD ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Optional software is compatible with Windows (XP and later) and Mac (OS X 10.3 and later) ● No external power supply required Specifications OVERVIEW UPC Code 037332198631 Technology USB 2.0 (High Speed) Host Connector USB A (MALE) INPUT Bus Powered Yes POWER Power Consumption (Watts) 0.5 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (1, 2) PHYSICAL Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 1.50 x 4.40 x 3.74 Shipping Dimensions (hwd / cm) 3.81 x 11.18 x 9.50 Shipping Weight (lbs.) 0.26 Shipping Weight (kg) 0.12 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0 Unit Weight (kg) 0.00 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range 14 to 131 F (-10 to 55 C) Relative Humidity 5% to 90% RH, Non-Condensing BTUs 1.7 BTU/Hr CONNECTIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Ports 2 Side A - Connector 1 USB A (FEMALE) Side B - Connector 1 (2) USB B (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Port Selection Pushbutton; Hotkey; Mouse USB Specification USB 2.0 (up to 480 Mbps) Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; WEEE; FCC (USA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U215-002 价格&库存
很抱歉,暂时无法提供与“U215-002”相匹配的价格&库存,您可以联系我们找货
