1000 Eaton Boulevard
Cleveland, OH 44122
United States
Computer with DisplayPort 1.2-compatible graphics card (e.g. AMD Radeon with AMD Eyefinity) required
for video wall mode. Backward compatible with most DisplayPort 1.1a equipment running current graphics
Highlights
Supports UHD video resolutions
up to 4K @ 60 Hz (3840 x 2160)
Built-in 6 in. cable connects
directly to Mini DisplayPort
source
Supports up to 48-bit Deep
Color (16 bits per channel)
Works with all operating
systems
Supports DTS-HD, Dolby
TrueHD and 7.1-channel
surround sound
drivers with feature set limited to that of your equipment. Compatibility with older graphics cards not
guaranteed. MST compliant DisplayPort 1.2 graphics cards are limited to a bandwidth of 21.6 Gbps
amongst all monitors, with higher resolution monitors using up more bandwidth. 1080p monitors will use
up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be
different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display
settings interface for your graphics card. If the total percentage of bandwidth taken up by all of the
connected monitors exceeds 100%, an image will not display on one or more of them.Maximum supported
video resolutions and number of monitors depend on your graphics card. Check graphics card
specifications to determine its capabilities.
3-Port Mini DisplayPort to HDMI Multi-Monitor
Splitter, MST Hub, 4K 60Hz UHD, DP1.2, TAA
System Requirements
Computer with DisplayPort 1.2compatible graphics card (e.g.
AMD Radeon with AMD
Eyefinity) required for video wall
mode.
running current graphics drivers
guaranteed.
Mac OS X does not support
MST for NVIDIA and Intel
Graphics Processor Units,
limiting video display on
connected monitors to mirror
mode.
Maximum supported video
card specifications to determine
its capabilities.
Monitor(s) with HDMI input.
MODEL NUMBER: B155-003-HD-V2
Displays the same image on 3 HDMI monitors, extends the desktop across all three, or combines all into
one large monitor. Ideal for digital signage in schools, churches, conference rooms, trade shows and retail
outlets.
Package Includes
Description
The B155-003-HD-V2 3-Port Mini DisplayPort 1.2 to HDMI MST Hub connects up to three HDMI monitors
to the Mini DisplayPort (MDP) output on your computer. Ideal for digital signage in schools, churches,
conference rooms, trade shows, hotels and retail outlets, this hub allows you to display the same image
on all three monitors, extend the desktop across them, or combine all three as one large monitor in video
wall mode.
The B155-003-HD-V2 is compliant with DisplayPort 1.2 and backward compatible with versions 1.1 and
1.1a with the feature set being limited to that of your equipment. It supports Ultra High Definition (UHD)
video resolutions up to 4K @ 60 Hz (3840 x 2160). In video wall mode, it supports expanded resolutions,
such as 5760 x 1080 in a horizontal 1 x 3 monitor configuration or 1920 x 3240 in a vertical 3 x 1
configuration.
This MST hub also supports HDCP, EDID, DDC and 48-bit Deep Color (16 bits per channel), as well as
DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio. It works with all operating systems. Plugand-play convenience means no software or drivers are needed. A built-in six-inch cable connects directly
to a MDP source. LEDs indicate when the monitors are receiving a signal. The B155-003-HD-V2 complies
with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
Features
1/4
Hub
External power supply w/NEMA
1-15P plug and 5 ft. cord (Input:
100–240V, 50/60 Hz, 0.5A;
Output: 5V, 2A)
Owner’s manual
Cleveland, OH 44122
United States
Connects Up to 3 HDMI Monitors to Your Computer’s Mini DisplayPort Output
● Ideal for digital signs in schools, churches, conference rooms, trade shows and retail settings
Displays same image on 3 monitors simultaneously in mirror mode
Extends desktop across 3 monitors in extended mode
Combines 3 monitors into one large monitor in video wall mode
Built-in 6 in. cable connects directly to MDP source
LEDs indicate when monitors are receiving a signal
Meets the Latest Performance Standards
● Supports UHD video resolutions up to 4K @ 60 Hz (3840 x 2160)
Supports expanded resolutions in video wall mode, such as 5760 x 1080 in horizontal 1 x 3
configuration
Supports HDCP, EDID and DDC
Supports 48-bit Deep Color (16 bits per channel)
Supports DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio
Easy to Use Almost Anywhere
● Works with all operating systems
Plug and play—no software or drivers required
TAA Compliant
● Complies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332192998
Technology
HDMI; DisplayPort
Host Connector
MINI DISPLAYPORT (MALE)
VIDEO
Max Supported Video Resolution
Max Supported Color Depth
48-bit Deep Color
3D Video Supported
Yes
AUDIO
Audio Specification
POWER
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V, 50/60Hz, 0.5A
External Power Supply Output
Specs (V / A)
5V, 2A
External Power Supply Cord Length
(ft.)
4.5
2/4
Cleveland, OH 44122
United States
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
6.1
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x3) Orange (Monitor Signal)
PHYSICAL
Color
Black
Material of Construction
Plastic
Rackmountable
No
Shipping Dimensions (hwd / in.)
8.30 x 2.17 x 6.50
Shipping Dimensions (hwd / cm)
21.08 x 5.51 x 16.51
Shipping Weight (lbs.)
0.80
Shipping Weight (kg)
0.36
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
2.4 x 10.8 x 7.5
Unit Dimensions (hwd / mm)
108 x 74 x 25
Unit Packaging Type
Box
Unit Weight (lbs.)
0.20
Unit Weight (kg)
0.09
ENVIRONMENTAL
Operating Temperature Range
14 to 167 °F (-10 to 75 °C)
Storage Temperature Range
-4 to 176 °F (-20 to 80 °C)
Relative Humidity
0% to 85%, Non-Condensing
BTUs
20.8 BTU/Hr
COMMUNICATIONS
EDID Compatible
Yes
CONNECTIONS
Number of Ports
3
Side A - Connector 1
Side B - Connector 1
(3) HDMI (FEMALE)
Connector Plating
Nickel
Contact Plating
Gold
3/4
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Displayport Specification
1.2
HDCP Specification
1.3
Driver Required
No
MST Support
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; UL; cUL
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
