U444-06N-VGU-C
U444-06N-VGU-C
    TRIPPLITE
    USB-C TO VGA ADAPTER W/ USB A HU
U444-06N-VGU-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Multiport Adapter, VGA, USB-A Port, Gbe and PD Charging, White MODEL NUMBER: U444-06N-VGU-C Highlights ● Supports USB DisplayPort Alternate Mode for transmitting video ● Supports HD video resolutions up to 1920 x 1200 (1080p) @ 60 Hz ● Supports true 10/100/1000 Mbps Ethernet network speeds ● USB-C PD charging port supports power input up to 20V 3A (60W) ● USB-A port provides up to 5V/1.5A (7.5W) of fast-charging power ● Plug-and-play operation with no software or drivers required System Requirements Mini docking station adds VGA, USB-A, USB-C PD charging and Gigabit Ethernet ports to the USB-C port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. Description ● Source device with USB-C port that supports USB DisplayPort Alternate Mode ● Display device with VGA input (VGA port) Package Includes The U444-06N-VGU-C USB 3.2 Gen 1 USB-C to VGA Adapter expands the potential of your tablet, laptop, Chromebook, MacBook, smartphone or PC’s USB-C port. It’s ideal for transmitting 1080p video to a large display, adding a thumb drive or other USB peripheral, powering and charging a PD Chargingcompliant mobile device, and connecting to a Gigabit Ethernet network—all at the same time. With a source device that also supports USB DisplayPort Alternate Mode, you can extend video from your primary display to another, duplicate the same video on both displays, or change the second display to your primary. The plug-and-play U444-06N-VGU-C requires no software, drivers or external power. Connect the reversible USB-C plug to your source device’s USB-C port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. To send HD video to a VGA television, projector or monitor, connect the VGA port to the display using a VGA cable (sold separately). The VGA port supports HD video resolutions up to 1920 x 1200 (1080p) at 60 Hz. The USB-A port accepts USB peripherals, such as a flash drive, mouse, keyboard or printer. It supports fast USB 3.2 Gen 1 data transfer rates up to 5 Gbps and is backward compatible with previous USB generations. The port provides up to 5V/1.5A (7.5W) of fast-charging power to mobile devices. The USB-C Power Delivery (PD) port provides power and charging to the PD Charging-compliant device (such as a MacBook or Chromebook) the U444-06N-VGU-C is connected to. Connect the device’s AC wall charger to the USB-C PD port, which supports power input up to 20V 3A (60W). The RJ45 port offers access to a Gigabit Ethernet network when no Wi-Fi is available or when a wired connection offers faster speeds. Connect using a UTP cable (sold separately), and enjoy true 10/100/1000 Mbps Ethernet speeds for fast data transfers. Features Mini Docking Station Turns Your Device’s USB-C Port into a Multiport WorkstationIdeal for transmitting video to a large display, adding a USB peripheral, powering and charging a PD Chargingcompliant mobile device, and connecting to a Gigabit Ethernet network simultaneouslyPlug-and-play operation with no software, drivers or external power requiredAbout the size of a credit card for easy carrying in a pocket, purse or laptop bag Transmit Crystal-Clear 1080p Video to VGA DisplayCompatible with USB-C source devices that support USB DisplayPort Alternate ModeSupports HD video resolutions up to 1920 x 1200 (1080p) @ 60 HzExtends video from your primary display to anotherDuplicates the same video on 2 displaysConverts a secondary display to your primary display 1/4 ● U444-06N-VGU-C USB 3.2 Gen 1 USB-C to VGA Adapter, White ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Connect a USB PeripheralUSB-A port accepts flash drives, mice, keyboards, printers and other USB peripheralsSupports USB 3.2 Gen 1 data transfer rates up to 5 GbpsBackward compatible with USB 2.0 and USB 1.1Fast charging USB port provides up to 1.5A of fast-charging power to mobile devices.Note: Host must support USB OTG (On-the-Go) Charge a Connected DeviceUSB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C deviceSupports power input up to 20V 3A (60W)Note: USB-C PD port does not support Quick Charge (QC). Access a Wired Gigabit Ethernet NetworkRJ45 port supports true 10/100/1000 Mbps network speedsRecommended for a faster wired network connection or getting online when no Wi-Fi is available Built-In Cable with Reversible USB-C ConnectorFumble-free reversible USB-C plug connects in either direction for quick connection every time Specifications OVERVIEW UPC Code 037332193728 Product Type Multiport Adapter Technology Cat5/5e; Cat6; VGA/SVGA Host Connector USB C (MALE) VIDEO Number of Monitors Supported 1 Video Ports HD15 (FEMALE) Resolutions Supported VGA: 1920 x 1200 60Hz Max Supported Video Resolution VGA: 1920 X 1200 (1080P) @ 60HZ Extended Mode No Mirror Mode No DATA Data Ports USB A (FEMALE) Data Ports Details USB-A - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) INPUT Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 2.20 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 CHARGING Total Charging Watts 60 Charging Ports USB-C: 60W (20V 3A) Power Delivery (PD 2.0); USB-A: 5V 1.5A (7.5W) Charging Ports / Amps 1.5A; 3A PHYSICAL Color White Material of Construction PVC, ABS Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 0.91 x 5.51 x 3.94 Shipping Dimensions (hwd / cm) 2.31 x 14.00 x 10.01 Shipping Weight (lbs.) 0.13 Shipping Weight (kg) 0.06 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.11 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 7.6 BTU/Hr Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 5V 0.9A (4.5W) Output (USB-A), Up to 20V 3A (60W) Input (USB-C) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3; 802.3u; 802.3az; 802.3x CONNECTIONS Number of Ports 4 Side A - Connector 1 USB C (MALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 USB 3.0 A (FEMALE) Side B - Connector 3 RJ45 (FEMALE) Side B - Connector 4 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables UASP Support No Auto MDIX Support Yes Full Duplex Support Yes Suspend Mode Support Yes Remote Wakeup Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U444-06N-VGU-C 价格&库存
很抱歉,暂时无法提供与“U444-06N-VGU-C”相匹配的价格&库存,您可以联系我们找货
