U444-06N-H4GU-C
U444-06N-H4GU-C
    TRIPPLITE
    USB 3.1 GEN 1 USB-C TO HDMI EXTE
U444-06N-H4GU-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Multiport Adapter - 4K HDMI, USB-A Port, GbE, 60W PD Charging, HDCP, White MODEL NUMBER: U444-06N-H4GU-C Highlights ● Transmits video signals from sources supporting USB-C DisplayPort Alt Mode ● Delivers UHD picture quality at resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz ● Connects you to a wired Gigabit Ethernet network when Wi-Fi is weak or unavailable ● Power Delivery port provides 20V 3A (60W) power output for charging connected device ● USB-A port supports USB 3.1 Gen 1 speeds up to 5 Gbps for fast data transfers Applications Adds HDMI, USB-A, USB-C PD charging and Gigabit Ethernet ports to the USB-C or Thunderbolt 3 port on your MacBook or Chromebook. Features Mini Docking Station Turns Your USB-C or Thunderbolt 3 Device into a Multiport Workstation This 4K adapter turns the USB-C or Thunderbolt 3 port on your tablet, laptop, Chromebook, MacBook, smartphone or PC into multiple ports. It’s ideal for transmitting digital audio and 4K video to a large display, adding a thumb drive or other USB peripheral, powering and charging a PD Charging-compliant mobile device, and connecting to a Gigabit Ethernet network—all at the same time. Supports USB-C DisplayPort Alternate Mode for Converting Video Signals By connecting the USB-C plug to a source device that supports USB DisplayPort Alt Mode, you can output 4K video to an HDMI monitor, television or projector without the hassle of installing special software drivers. Transmits Crystal-Clear 4K HDMI Video and Digital Audio To send digital audio and Ultra High Definition video to a 4K-ready HDMI television, projector or monitor, connect the HDMI port to the display using an HDMI cable (such as Tripp Lite’s P568-Series cables, sold separately). The USB to HDMI 4K adapter supports video resolutions up to 3840 x 2160 (4K x 2K) at 30 Hz. It’s backward compatible with 1080p displays, allowing you to use it with older equipment. Connects USB Peripherals and Transfers Data at Fast USB 3.1 Gen 1 Speeds The USB-A port accepts USB peripherals, such as a flash drive, mouse, keyboard or printer, and provides up to 5V 1A (5W) for charging and powering mobile devices. It transfers data at speeds up to 5 Gbps, which is 10 times faster than USB 2.0. The USB Type-C adapter is backward compatible with previous USB generations, so you can continue using older peripherals while getting high-speed performance from new devices. Note: Host must support USB OTG (On-the-Go). PD Charging Port Charges High-Powered Devices via AC Wall Charger The USB-C Power Delivery port provides power output up to 20V 3A (60W), which is more than sufficient for charging and powering the connected source device, such as a MacBook or Chromebook. Connect the port to the device’s AC wall charger. Note: USB-C PD port does not support Quick Charge (QC). Accesses a Wired Gigabit Ethernet Network The RJ45 port offers access to a Gigabit Ethernet network when Wi-Fi is unavailable or when a wired connection offers faster speeds. Connect using a UTP cable (such as Tripp Lite’s N201-Series Cat6 cables, sold separately), and enjoy true 10/100/1000 Mbps (1 Gbps) Ethernet speeds for fast data transfers. 1/5 ● Connect your laptop to an HDMI monitor in a lecture hall or conference room for a video presentation ● Add a secondary monitor to the MacBook, Chromebook or laptop in your office or home workspace ● Stream online video from your computer on a larger 4K display in your home theater or digital signage setup ● Charge and power a USB-C or Thunderbolt 3 device with its AC wall charger ● Connect a USB peripheral, such as an external hard drive, printer or hub ● Upload data from your notebook or download data from the Ethernet at true 10/100/1000 Mbps speeds System Requirements ● Source device with USB-C or Thunderbolt 3 output that supports USB DisplayPort Alternate Mode ● Display device with HDMI input (HDMI port) Package Includes ● U444-06N-H4GU-C USB 3.1 Gen 1 USB-C to HDMI 4K Adapter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Reversible USB-C Connector Attaches in Either Direction Unlike traditional USB cables that connect in only one direction, the reversible USB-C male connector plugs into a USB-C or Thunderbolt 3 port in either direction for a fumble-free connection every time. Ready to Use Right Out of the Package The plug-and-play USB 3.1 Type-C adapter is specifically designed for the MacBook, Google Chromebook Pixel and other laptops, tablets and devices equipped with a USB-C or Thunderbolt 3 port. It requires no software, drivers or external power. About the size of a credit card, the U444-06N-H4GUC fits easily into a pocket, purse or laptop bag for convenient connections on the go. Specifications OVERVIEW UPC Code 037332193964 Product Type Multiport Adapter Technology Cat5/5e; Cat6; HDMI Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output HDMI (FEMALE) Number of Monitors Supported 1 Video Ports HDMI (FEMALE) Video Ports Details HDMI 1.4; HDCP 1.4 Resolutions Supported HDMI: 4K 30Hz (3840 x 2160) Supported Resolutions 1920x1080 (1080p); 3840x2160 (4K) Max Supported Video Resolution HDMI: 3840 X 2160 (4K X 2K) @ 30HZ Extended Mode Yes Extended Mode Details Supports extended mode to a connected monitor up to 4K @ 30 Hz Mirror Mode Yes Mirror Mode Details Supports mirror mode to a connected display at resolutions up to 4K @ 30 Hz 3D Video Supported Yes AUDIO Audio Ports HDMI (FEMALE) Audio Ports Details Supports 7.1 channel surround sound via HDMI port Audio Specification 7.1 channel surround sound via HDMI port DATA 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Data Ports USB A (FEMALE) Data Ports Details USB-A - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) Network Ports Details 1 Gbps (Gigabit) INPUT Built-In Cable Length (ft.) 0.36 Built-In Cable Length (m) 0.11 Built-In Cable Length (in.) 4.33 Built-In Cable Length (cm) 11 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 2.80 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators RJ45 (x1 Green, x1 Orange) CHARGING Number of Charging Ports 2 Total Charging Amps 3 Total Charging Watts 60 Charging Port Type USB A (FEMALE); USB C (FEMALE) Charging Ports Details Supports host device charging up to 20V/3A (60W)USB-A Fast Charge port supports device charging up to 5V/1.5A (7.5W) Charging Ports USB-C: 60W (20V 3A) Power Delivery (PD 2.0); USB-A: 5V 1.5A (7.5W) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Ports / Amps 1.5A; 3A Charging Amps per Port 1.5; 3 PHYSICAL Color White Material of Construction PVC, ABS Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 0.95 x 3.90 x 5.50 Shipping Dimensions (hwd / cm) 2.41 x 9.91 x 13.97 Shipping Weight (lbs.) 0.18 Shipping Weight (kg) 0.08 Unit Dimensions (hwd / in.) 0.570 x 1.570 x 3.150 Unit Dimensions (hwd / cm) 1,45 x 4 x 8 Unit Packaging Type Box Unit Weight (lbs.) 0.10 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 9.6 BTU/Hr Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) Up to 20V 3A (60W) Input (USB-C) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) CONNECTIONS Number of Ports 4 RJ45 Ports 1 RJ45 Ports Detail Supports Gigabit Ethernet Side A - Connector 1 USB C (MALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 USB 3.0 A (FEMALE) Side B - Connector 3 RJ45 (FEMALE) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 4 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.4 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables UASP Support No Auto MDIX Support Yes Full Duplex Support Yes Suspend Mode Support Yes Remote Wakeup Support Yes Network Speed Support 1 Gbps (Gigabit) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
U444-06N-H4GU-C 价格&库存
很抱歉,暂时无法提供与“U444-06N-H4GU-C”相匹配的价格&库存,您可以联系我们找货
