U444-06N-HGU-C
U444-06N-HGU-C
    TRIPPLITE
    USB 3.1 GEN 1 USB-C TO HDMI EXTE
U444-06N-HGU-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Multiport Adapter - HDMI, USB 3.2 Gen 1 Port, Gigabit Ethernet, 60W PD Charging, HDCP, White Highlights ● Supports USB DisplayPort Alternate Mode for transmitting audio/video ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Supports true 10/100/1000 Mbps Ethernet network speeds ● USB-C PD 3.0 port supports 20V 3A (60W) power output for charging host device ● Plug-and-play operation with no software required for easy, immediate installation MODEL NUMBER: U444-06N-HGU-C System Requirements Mini docking station adds HDMI, USB-A, USB-C PD charging and Gigabit Ethernet ports to the USB-C or Thunderbolt 3 port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode ● Display device with HDMI input (HDMI port) Package Includes ● U444-06N-HGU-C USB-C Multiport Adapter ● Owner’s manual Features Mini Docking Station Turns Your Device’s USB-C Port into a Multiport Workstation ● Ideal for transmitting audio/video to a large display, adding a USB peripheral, powering and charging a PD Charging-compliant mobile device, and connecting to a Gigabit Ethernet network simultaneously ● Plug-and-play operation with no software, drivers or external power required ● About the size of a credit card for easy carrying in a pocket, purse or laptop bag Transmit Crystal-Clear 1080p Video and Digital Audio to HDMI Display ● Compatible with USB-C or Thunderbolt 3 source devices that support USB DisplayPort Alternate Mode ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Extends video from your primary display to another ● Duplicates the same video on 2 displays ● Converts a secondary display to your primary display Connect a USB Peripheral ● USB-A port accepts flash drives, mice, keyboards, printers and other USB peripherals ● Supports USB 3.2 Gen 1 data transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 and USB 1.1 ● Provides up to 5V/1.5A (7.5W) of fast-charging power to mobile devices ● Host must support USB OTG (On-the-Go) Charge a Connected Device ● USB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C/Thunderbolt 3 device ● Supports power input up to 20V 3A (60W) ● USB-C PD port does not support Quick Charge (QC) Access a Wired Gigabit Ethernet Network ● RJ45 port supports true 10/100/1000 Mbps network speeds 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Recommended for a faster wired network connection or getting online when no Wi-Fi is available Built-In Cable with Reversible USB-C Connector ● Fumble-free reversible USB-C plug connects in either direction for quick connection every time Specifications OVERVIEW UPC Code 037332193940 Product Type Multiport Adapter Technology Cat5/5e; Cat6; HDMI Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output HDMI (FEMALE) Number of Monitors Supported 1 Video Ports HDMI (FEMALE) Video Ports Details HDMI 1.3; HDCP 1.3 Resolutions Supported HDMI: 1080P 60Hz (1920 x 1080) Supported Resolutions 1280x720 (720p); 1920x1080 (1080p) Max Supported Video Resolution HDMI: 1920 X 1080 (1080P) @ 60HZ Extended Mode Yes Extended Mode Details Extend the desktop from your host computer to an HDMI monitor at video resolutions up to 1920 x 1080 (1080p) @ 60 Hz Mirror Mode Yes Mirror Mode Details Mirror the video output from your host computer to an HDMI monitor at video resolutions up to 1920 x 1080 (1080p) @ 60 Hz Max Supported Color Depth 30-bit Deep Color HDR Support No 3D Video Supported No EDID Support No DATA Data Ports USB A (FEMALE) Data Ports Details USB-A - USB 3.2 Gen 1 (5 Gbps) INPUT Built-In Cable Length (ft.) 0.36 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Built-In Cable Length (m) 0.11 Built-In Cable Length (in.) 4.33 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 2.60 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green = Connected, Orange = Activity CHARGING Number of Charging Ports 2 Total Charging Watts 60 Charging Port Type USB A (FEMALE); USB C (FEMALE) Charging Ports Details USB-A port supports fast charging up to 5V/1.5A (7.5W)USB-C port supports PD Charging up to 20V/3A (60W) Charging Ports USB-C: 60W (20V 3A) Power Delivery (PD 2.0); USB-A: 5V 1.5A (7.5W) Charging Ports / Amps 1.5A; 3A PHYSICAL Color White Material of Construction PVC, ABS Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.9mm Wire Gauge (AWG) 28+34 Shipping Dimensions (hwd / in.) 0.91 x 5.51 x 3.94 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 2.31 x 14.00 x 10.01 Shipping Weight (lbs.) 0.18 Shipping Weight (kg) 0.08 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 1.45 x 4 x 8 Unit Packaging Type Box Unit Weight (lbs.) 0.10 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 9 BTU/Hr Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 5V 1.5A (7.5W) Output (USB-A), Up to 20V 3A (60W) Input (USB-C) COMMUNICATIONS Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit) IEEE Standards Supported 802.3; 802.3u; 802.3az; 802.3x CONNECTIONS Number of Ports 4 RJ45 Ports 1 RJ45 Ports Detail Supports 10/100/1000 Mbps (Gigabit) Ethernet Side A - Connector 1 USB C (MALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 USB 3.0 A (FEMALE) Side B - Connector 3 USB C (FEMALE) Side B - Connector 4 RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.3 USB Hub Ports Yes Number of USB Hub Ports 1 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support Yes Remote Wakeup Support Yes Multi-Resolution Support No Ethernet Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
U444-06N-HGU-C 价格&库存
很抱歉,暂时无法提供与“U444-06N-HGU-C”相匹配的价格&库存,您可以联系我们找货
U444-06N-HGU-C
库存:1
