B160-200-HSI
B160-200-HSI
    TRIPPLITE
    2-PORTHDMIAUDIO/VIDEOWITHRS-
B160-200-HSI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port HDMI over IP Extender Receiver over Cat5/Cat6, RS-232 Serial and IR Control, 1080p 60 Hz, 328 ft. (100 m), TAA Highlights ● Compatible with Tripp Lite B160-Series A/V over IP transmitters ● Display video from any source, analog or digital ● Supports video resolutions up to 1920 x 1080 (1080p) ● Dual HDMI outputs for connecting 2 displays ● Plug and play—no software or drivers required MODEL NUMBER: B160-200-HSI Package Includes Receives an IP-based audio + video signal transmitted point-to-point from a source 328 ft. away via Cat5e/6 cable or through a dedicated Ethernet network switch. Features HDMI A/V, Serial and IR Control Signals over Cat5/6 Cabling ● Receives IP-based audio/video transmitted point-to-point from a source 328 ft. away ● Add low-cost network switches between transmitter and receiver to continue extending distance up to 328 ft. per switch ● Dual HDMI outputs for connecting 2 displays Create a Multi-In, Multi-Out Installation Using B160-Series Transmitters and Receivers ● Connect up to 64 transmitters and 255 receivers through multiple dedicated managed network switches ● IGMP-enabled switches allow centralized control over which sources show on which displays ● Displays video from any analog or digital source, so you can mix and match technologies and use existing sources and monitors Enhanced Technical Features ● Supports video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Uses H.264 video compression standard ● Transmits on 20–60 kHz IR frequency ● Extends IR control signals that control a source from a remote display ● Supports RS-232 serial baud rates up to 57600 Bps ● HDCP and 3D compatible when used with a DisplayPort or HDMI transmitter Plug-and-Play Functionality ● No software or drivers required ● Hardware included for mounting on wall, rack or pole 1/5 ● Receiver unit ● External power supply (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V 2A) ● Plug adapters for U.S., U.K., Europe and Australia ● IR-In cable ● 3.5 mm to DB9 adapter cable (M/M) ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Compatible with all Tripp Lite B160-Series A/V over IP transmitters TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332196774 Product Type Receiver Technology DVI; HDMI; IR; A/V over IP; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 1280 x 720 (720p) Range (ft) 328 Max 1920 x 1080 (1080p) Range (ft) 328 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 2 Range Extension using other Tripp Lite product 328ft Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range network switch Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 328 Maximum Signal Range (m) 100 Maximum Signal Range Details 328 ft via Cat6275 ft via Cat5e AUDIO Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Source Type AC Adapter External Power Supply Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P; BS1363; CEE 7/16 Schuko; AS/NZS 3112 Power Source Unit (Included) Power Over Cable (PoC) Support No DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 6.7 USER INTERFACE, ALERTS & CONTROLS LED Indicators RJ45 Output (Green / Power, Orange / Signal), Channel Signal (Red), Power (Green) PHYSICAL Color Black Material of Construction Steel Included Mounting Accessories Wallmount Number of Displays 2 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Rackmountable Yes Shipping Dimensions (hwd / in.) 2.00 x 6.30 x 10.20 Shipping Weight (lbs.) 1.80 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.24 Unit Weight (kg) 0.11 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 0% to 85%, Non-Condensing BTUs 23 BTU/Hr COMMUNICATIONS Signal Range (ft.) 328 Signal Range (m) 100 EDID Compatible Yes IR Remote Extension Support Yes RS-232 Serial Extension Support Yes Consumer Electronics Control (CEC) Supported Yes Latency 2-3 seconds USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable N202-Series Cat6 Patch Cable 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications BSMI; CB; CCC; CE; FCC; GS; PSE; RCM; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B160-200-HSI 价格&库存
很抱歉,暂时无法提供与“B160-200-HSI”相匹配的价格&库存,您可以联系我们找货
