1000 Eaton Boulevard
Cleveland, OH 44122
United States
DisplayPort over IP Extender Transmitter over
Cat5/Cat6, RS-232 Serial and IR Control, 1920 x
1080, 328 ft. (100 m), TAA
Highlights
Compatible with Tripp Lite
B160-Series A/V over IP
receivers
Video source can be sent to any
analog or digital display
Supports video resolutions up to
1920 x 1080, including 1080p Limited to maximum resolution
of receiver
HDMI output on transmitter for
connecting local display
Plug and play—no software or
drivers required
MODEL NUMBER: B160-001-DPSI
Package Includes
Converts DisplayPort™ audio/video to an IP-based signal that is transmitted point-to-point to a receiver
328 ft. away via Cat5e/6 cable or through a dedicated Ethernet network switch.
Features
Distributes DisplayPort A/V, Serial and IR Control Signals over Cat5/6 Cabling
● Converts audio/video to an IP-based signal that is transmitted point-to-point to a display 328 ft. away
Add low-cost network switches between transmitter and receiver to continue extending distance up to
328 ft. per switch
HDMI output for connecting a local display
Create a Multi-In, Multi-Out Installation Using B160-Series Transmitters and Receivers
● Connect up to 64 transmitters and 255 receivers through multiple dedicated managed network switches
IGMP-enabled switches allow centralized control over which sources show on which displays
Video source can be sent to any analog or digital display, so you can mix and match technologies and
use existing monitors
Enhanced Technical Features
● Supports video resolutions up to 1920 x 1080, including 1080p (limited to receiver’s max resolution)
Uses H.264 video compression standard
Transmits on 20–60 kHz IR frequency
Extends IR control signals that control a source from a remote display
Supports RS-232 serial baud rates up to 57600 Bps
HDCP and 3D compatible when used with a DisplayPort or HDMI receiver (not compatible with VGA
receiver)
Plug-and-Play Functionality
● No software or drivers required
1/5
Transmitter unit
External power supply (Input:
100–240V, 50/60 Hz, 0.5A;
Output: 5V 2A)
Plug adapters for U.S., U.K.,
Europe and Australia
IR-Out cable
3.5 mm to DB9 adapter cable
(M/F)
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Hardware included for mounting on wall, rack or pole
Compatible with all Tripp Lite B160-Series A/V over IP receivers
TAA-Compliant
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332196668
Product Type
Transceiver
Technology
DisplayPort; IR; A/V over IP; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 1280 x 720 (720p) Range (ft)
328
Max 1920 x 1080 (1080p) Range (ft)
328
Transmitter Video Input
DisplayPort
Transmitter - Number of Video
Outputs
1
Transmitter - Local Display Output
HDMI
Range Extension using other Tripp
Lite product
328ft
Recommended Cabling
N202-Series Cat6 Patch Cable
Other Tripp Lite product used to
extend range
network switch
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Maximum Signal Range (ft)
328
Maximum Signal Range (m)
100
AUDIO
Audio Input
Displayport
Audio Specification
Stereo Audio
INPUT
Bus Powered
No
2/5
Cleveland, OH 44122
United States
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 1.0A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.4
AC Plug Type
NEMA 1-15P; BS1363; CEE 7/16 Schuko; AS/NZS 3112
Power Source
Unit (Included)
Power Over Cable (PoC) Support
No
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
6.3
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
RJ45 Output (Green / Power, Orange / Signal), Channel Signal (Red), Power (Green)
PHYSICAL
Color
Black
Material of Construction
Steel
Included Mounting Accessories
Wallmount
Number of Displays
1
Optional Mounting Accessory Notes
Can DIN Mount using Tripp Lite Bracket B110-DIN-02
Form Factor/Mounting Options
Box; Wall-mount
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
2.00 x 6.30 x 10.20
Shipping Weight (lbs.)
1.70
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
Unit Weight (lbs.)
0.2
Unit Weight (kg)
0.09
Housing
Metal
ENVIRONMENTAL
3/5
Cleveland, OH 44122
United States
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85%, Non-Condensing
BTUs
21.5 BTU/Hr
COMMUNICATIONS
Signal Range (ft.)
328
Signal Range (m)
100
EDID Compatible
Yes
IR Remote Extension Support
Yes
RS-232 Serial Extension Support
Yes
Consumer Electronics Control (CEC)
Supported
Yes
Latency
2-3 seconds
USB Extension Support
No
CONNECTIONS
Number of Ports
5
Side A - Connector 1
DISPLAYPORT (FEMALE)
Side B - Connector 1
HDMI (FEMALE); RJ45 (FEMALE)
FEATURES & SPECIFICATIONS
Displayport Specification
1.2
HDCP Specification
1.4
Driver Required
No
Recommended Category Cable
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
BSMI; CB; CCC; CE; FCC; GS; PSE; RCM; TUV; UL; cUL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
4/5
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B160-001-DPSI”相匹配的价格&库存,您可以联系我们找货
