B160-101-HDSI
B160-101-HDSI
    TRIPPLITE
    HDMI/DVIAUDIO/VIDEOWITHRS-232
B160-101-HDSI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI/HDMI over IP Gigabit LAN Ethernet Extender Kit, RS-232 Serial and IR Control, 1080p 60 Hz, 328 ft. (100 m), TAA Highlights ● Units connect point-to-point without a switch up to 328.08-ft. (100 m) ● Supports video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● HDMI output on transmitter for connecting local display ● Plug and play—no software or drivers required MODEL NUMBER: B160-101-HDSI Package Includes Converts HDMI or DVI audio/video to an IP-based signal that is transmitted point-to-point to a display 328 ft. away via Cat5e/6 cable or through a dedicated Ethernet network switch. Description The B160-101-HDSI HDMI over IP Gigabit LAN Ethernet Extender Kit extends and distributes HDMI or DVI audio/video, RS-232 serial and IR (infrared) remote signals from the source to the display located up to 328.08-ft. (100 m) away, which is more than 200-ft. (60.96 m) farther than a traditional Cat5e/6 solution. By adding a chain of low-cost unmanaged network switches, such as Tripp Lite's NG5, you can continue extending the distance between source and display up to 328.08-ft. (100 m) per switch. Create a multi-in, multi-out installation with up to 64 transmitters and 255 receivers* by including dedicated managed Ethernet network switches** with Internet Group Management Protocol (IGMP), such as Tripp Lite's NSS-G16D2. With a compatible B160-Series receiver, you can send the HDMI or DVI video source (a DVI adapter cable is included) to any analog or digital display, including VGA and DisplayPort™, allowing you to mix and match technologies and use existing monitors. The IGMP-enabled switch will let you manage all connections for centralized control over which sources show on which displays. The B160-101-HDSI supports video resolutions up to 1920 x 1080 (1080p) at 60 Hz in a point-tomultipoint switch installation. It extends IR control signals that control a source, such as a Blu-ray™ player, to a remote display, as well as RS-232 signals at serial baud rates up to 57600 Bps. The transmitter and receiver units mount to a wall, rack or pole using the including hardware. *Unmanaged switch installations are limited to two transmitter units. Number of receivers is limited to number of ports remaining on unmanaged switch. **B160-Series designed for use with dedicated network switch. Connecting to a switch used with other networking equipment will result in degraded or non-functional performance. Features Extends and Distributes HDMI/DVI A/V, Serial and IR Control Signals over Cat5/6 Cabling ● Converts audio/video to an IP-based signal that is transmitted point-to-point to a display 328.08-ft. (100 m) away ● Add low-cost network switches between transmitter and receiver to continue extending distance up to 328.08-ft. (100 m) per switch ● HDMI output on transmitter for connecting a local display Create a Multi-In, Multi-Out Installation Using B160-Series Transmitters and Receivers 1/5 ● Transmitter unit ● Receiver unit ● (2) External power supplies (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V 2A) ● Plug adapters for U.S., U.K., Europe and Australia ● IR-In cable ● IR-Out cable ● (2) HDMI to DVI adapter cables ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Connect up to 64 transmitters and 255 receivers through multiple dedicated managed network switches ● IGMP-enabled switches allow centralized control over which sources show on which displays ● Video source can be sent to any analog or digital display, so you can mix and match technologies and use existing monitors Enhanced Technical Features ● Supports video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Uses H.264 video compression standard ● Transmits on 20-60 kHz IR frequency ● Extends IR control signals that control a source from a remote display ● Supports RS-232 serial baud rates up to 57600 Bps ● HDCP and 3D compatible Plug-and-Play Functionality ● No software or drivers required ● Hardware included for mounting on wall, rack or pole TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332196781 Product Type Extender Kit Technology DVI; HDMI; IR; A/V over IP; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 1280 x 720 (720p) Range (ft) 328 Max 1920 x 1080 (1080p) Range (ft) 328 Transmitter Video Input HDMI or DVI w/ adapter Transmitter - Number of Video Outputs 1 Transmitter - Local Display Output HDMI Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 328ft Recommended Cabling N202-Series Cat6 Patch Cable 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Other Tripp Lite product used to extend range network switch Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 328 Maximum Signal Range (m) 100 Maximum Signal Range Details 328 ft via Cat6275 ft via Cat5e AUDIO Audio Input HDMI Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P; BS1363; CEE 7/16 Schuko; AS/NZS 3112 Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 10 USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: RJ45 (Green / Power, Orange / Signal), Channel Signal (Red), Power (Green) PHYSICAL Color Black Material of Construction Steel 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Rackmountable Yes Receiver Unit Dimensions (hwd / in.) 1.2 x 5 x 3.9 Receiver Unit Weight (lbs.) 0.2 Shipping Dimensions (hwd / in.) 3.20 x 5.70 x 11.50 Shipping Weight (lbs.) 3.10 Transmitter Unit Dimensions (hwd / in.) 1.2 x 5 x 3.9 Transmitter Unit Weight (lbs.) 0.2 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing BTUs 34 BTU/Hr COMMUNICATIONS Signal Range (ft.) 328 Signal Range (m) 100 EDID Compatible Yes IR Remote Extension Support Yes RS-232 Serial Extension Support Yes Consumer Electronics Control (CEC) Supported Yes Latency 2-3 seconds USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 (2) HDMI (FEMALE) Side A - Connector 2 3.5MM (FEMALE); DB9 (FEMALE); RJ45 (FEMALE) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 3.5MM (FEMALE); DB9 (FEMALE); RJ45 (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable N202-Series Cat6 Patch Cable 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications BSMI; CB; CCC; CE; FCC; GS; PSE; RCM; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B160-101-HDSI 价格&库存
很抱歉,暂时无法提供与“B160-101-HDSI”相匹配的价格&库存,您可以联系我们找货
