B160-001-HDSI
B160-001-HDSI
    TRIPPLITE
    HDMI/DVIVIDEO+AUDIOWITHRS-2
B160-001-HDSI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI/HDMI over IP Extender Transmitter over Cat5/Cat6, RS-232 Serial and IR Control, 1920 x 1080 (1080p), 328 ft. (100 m), TAA Highlights ● Compatible with Tripp Lite B160-Series A/V over IP receivers ● Video source can be sent to any analog or digital display ● Supports video resolutions up to 1920 x 1080 (1080p) - Limited to maximum resolution of receiver ● HDMI output on transmitter for connecting local display ● Plug and play—no software or drivers required MODEL NUMBER: B160-001-HDSI Package Includes Converts HDMI or DVI audio/video to an IP-based signal that is transmitted point-to-point to a receiver 328 ft. away via Cat5e/6 cable or through a dedicated Ethernet network switch. Features Distributes HDMI/DVI A/V, Serial and IR Control Signals over Cat5/6 CablingConverts audio/video to an IP-based signal that is transmitted point-to-point to a display 328 ft. awayAdd low-cost network switches between transmitter and receiver to continue extending distance up to 328 ft. per switchHDMI output for connecting a local display Create a Multi-In, Multi-Out Installation Using B160-Series Transmitters and ReceiversConnect up to 64 transmitters and 255 receivers through multiple dedicated managed network switchesIGMP-enabled switches allow centralized control over which sources show on which displaysVideo source can be sent to any analog or digital display, so you can mix and match technologies and use existing monitors Enhanced Technical FeaturesSupports video resolutions up to 1920 x 1080 (1080p)Uses H.264 video compression standardTransmits on 20–60 kHz IR frequencyExtends IR control signals that control a source from a remote displaySupports RS-232 serial baud rates up to 57600 BpsHDCP and 3D compatible when used with a DisplayPort or HDMI receiver Plug-and-Play FunctionalityNo software or drivers requiredHardware included for mounting on wall, rack or poleCompatible with all Tripp Lite B160-Series A/V over IP receivers TAA-CompliantCompliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332196644 Product Type Transceiver 1/4 ● Transmitter unit ● External power supply (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V 2A) ● Plug adapters for U.S., U.K., Europe and Australia ● IR-Out cable ● HDMI-to-DVI adapter cable ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology DVI; HDMI; IR; A/V over IP; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 1280 x 720 (720p) Range (ft) 328 Max 1920 x 1080 (1080p) Range (ft) 328 Transmitter Video Input HDMI or DVI w/ adapter Transmitter - Number of Video Outputs 1 Transmitter - Local Display Output HDMI Range Extension using other Tripp Lite product 328ft Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range network switch Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 328 Maximum Signal Range (m) 100 AUDIO Audio Input HDMI Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Plug Type NEMA 1-15P; BS1363; CEE 7/16 Schuko; AS/NZS 3112 Power Source Unit (Included) Power Over Cable (PoC) Support No DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 5.8 USER INTERFACE, ALERTS & CONTROLS LED Indicators RJ45 Output (Green / Power, Orange / Signal), Channel Signal (Red), Power (Green) PHYSICAL Color Black Material of Construction Steel Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Rackmountable Yes Shipping Dimensions (hwd / in.) 2.10 x 6.30 x 10.10 Shipping Weight (lbs.) 2.00 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.2 Unit Weight (kg) 0.09 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing BTUs 19.8 BTU/Hr COMMUNICATIONS Signal Range (ft.) 328 Signal Range (m) 100 EDID Compatible Yes IR Remote Extension Support Yes 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States RS-232 Serial Extension Support Yes Consumer Electronics Control (CEC) Supported Yes Latency 2-3 seconds USB Extension Support No CONNECTIONS Number of Ports 5 Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 HDMI (FEMALE); RJ45 (FEMALE) Side B - Connector 2 (2) 3.5MM (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable N202-Series Cat6 Patch Cable 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications BSMI; CB; CCC; CE; FCC; GS; PSE; RCM; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B160-001-HDSI 价格&库存
很抱歉,暂时无法提供与“B160-001-HDSI”相匹配的价格&库存,您可以联系我们找货
