B160-001-VSI
B160-001-VSI
    TRIPPLITE
    VGAVIDEO+AUDIOWITHRS-232SE
B160-001-VSI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA over IP Extender Transmitter over Cat5/Cat6, RS-232 Serial and IR Control, 1920 x 1440 (1080p), 328 ft. (100 m), TAA Highlights ● Compatible with Tripp Lite B160-Series A/V over IP receivers ● Video source can be sent to any analog or digital display ● Supports video resolutions up to 1920 x 1440, including 1080p* ● HDMI output on transmitter for connecting local display ● Plug and play—no software or drivers required MODEL NUMBER: B160-001-VSI Package Includes Converts VGA video + audio to an IP-based signal that is transmitted point-to-point to a receiver 328 ft. away via Cat5e/6 cable or through a dedicated Ethernet network switch. Features Distributes VGA A/V, Serial and IR Control Signals over Cat5/6 Cabling ● Converts audio/video to an IP-based signal that is transmitted point-to-point to a display 328 ft. away ● Add low-cost network switches between transmitter and receiver to continue extending distance up to 328 ft. per switch ● HDMI output for connecting a local display Create a Multi-In, Multi-Out Installation Using B160-Series Transmitters and Receivers ● Connect up to 64 transmitters and 255 receivers through multiple dedicated managed network switches ● IGMP-enabled switches allow centralized control over which sources show on which displays ● Video source can be sent to any analog or digital display, so you can mix and match technologies and use existing monitors Enhanced Technical Features ● Supports video resolutions up to 1920 x 1440, including 1080p (limited to receiver’s max resolution) ● Uses H.264 video compression standard ● Transmits on 20–60 kHz IR frequency ● Extends IR control signals that control a source from a remote display ● Supports RS-232 serial baud rates up to 57600 Bps ● HDCP and 3D compatible Plug-and-Play Functionality ● No software or drivers required ● Hardware included for mounting on wall, rack or pole 1/5 ● Transmitter unit ● External power supply (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V 2A) ● Plug adapters for U.S., U.K., Europe and Australia ● IR-Out cable ● 3.5 mm to DB9 adapter cable (M/F) ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Compatible with all Tripp Lite B160-Series A/V over IP receivers TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332196682 Product Type Transceiver Technology IR; VGA/SVGA; A/V over IP; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1440 @ 60Hz Max 720P Range (ft) 328 Max 1080P Range (ft) 328 Max 1280 x 720 (720p) Range (ft) 328 Max 1920 x 1080 (1080p) Range (ft) 328 Max 1920 x 1200 Range (ft) 328 Transmitter Video Input VGA Transmitter - Number of Video Outputs 1 Transmitter - Local Display Output HDMI Range Extension using other Tripp Lite product 328ft Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range network switch Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported No Maximum Signal Range (ft) 328 Maximum Signal Range (m) 100 Maximum Signal Range Details 328 ft via Cat6275 ft via Cat5e AUDIO Audio Input 3.5mm Audio Specification Stereo Audio 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P; BS1363; CEE 7/16 Schuko; AS/NZS 3112 Power Source Unit (Included) Power Over Cable (PoC) Support No DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators RJ45 Output (Green / Power, Orange / Signal), Channel Signal (Red), Power (Green) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 2.00 x 6.40 x 10.20 Shipping Dimensions (hwd / cm) 5.08 x 16.26 x 25.91 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.2 Unit Weight (kg) 0.09 Housing Metal 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing BTUs 18.1 BTU/Hr COMMUNICATIONS Max 1024 x 768 Range (ft) 328 Max 480P Range (ft) 328 Max 1440 x 900 Range (ft) 328 Max 1080i Range (ft) 328 Max 1920 x 1440 Range (ft) 328 Max 480i Range (ft) 328 Max 640 x 480 Range (ft) 328 Max 800 x 600 Range (ft) 328 Max 1600 x 1200 Range (ft) 328 EDID Compatible No IR Remote Extension Support Yes RS-232 Serial Extension Support Yes Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 3.5MM (FEMALE); HD15 (FEMALE) Side B - Connector 1 HDMI (FEMALE); RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications BSMI; CB; CCC; CE; FCC; GS; PSE; RCM; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B160-001-VSI 价格&库存
很抱歉,暂时无法提供与“B160-001-VSI”相匹配的价格&库存,您可以联系我们找货
