USB Hubs - 4-Port USB 1.1 Self- or Bus-Powered
Ultra-Mini Hub*
Highlights
Link multiple USB devices to 1
computer with ultra-compact
MODEL NUMBER: U202-004-R
hubs
Retail packaging
System Requirements
Computer with USB port
Compatible with Windows 98 or
higher and Mac OS 8.5 or
higher
Package Includes
U202-004-R 4-Port USB Hub
with built-in Hide-away Cable
Description
Tripp Lite's 4-Port Self- or Bus-Powered Ultra-Mini USB Hub is the ideal solution for increasing the
number of available USB ports on a laptop/notebook computer. The unit features an ultra-mini pocketsized case. A hide-away USB cable connects to the computer. The hub does not require external power,
software or complicated set-up procedures. Powers most applications without use of an AC power adapter
(included). The hub features plug-and-play/hot-swappable connection of devices. Tripp Lite warrants this
product to be free from defects in materials and workmanship for life.
Features
Features 4-ports to increase the number of available USB ports on a computer
Ultra-mini, pocket-sized design is ideal for use with a laptop/notebook computer - 3"L x 2"W x .5"H
Does not require external power, software or complicated set-up procedures
Plug-and-Play/hot-swappable allows you to add or remove a device at any time
Fully rated for high-speed transmissions (12 Mbps)
Bus-powered: unit receives power from connected computer
Compatible with Windows 98 or higher and MAC OS 8.5 or higher
Hide-away USB cable included for computer connection
AC power adapter included for use with power-hungry devices
Tripp Lite warrants this product to be free from defects in materials and workmanship for life
Specifications
OVERVIEW
UPC Code
037332098634
AC Adapter
Input: 100-240V, 50/60Hz, 0.35A; Output: 5V, 2A
1/2
110V AC Adapter
Instructions
Technology
USB; USB 2.0 (High Speed)
PHYSICAL
Color
Black
Shipping Dimensions (hwd / cm)
19.05 x 16.51 x 7.62
Shipping Dimensions (hwd / in.)
7.50 x 6.50 x 3.00
Shipping Weight (kg)
0.28
Shipping Weight (lbs.)
0.61
CONNECTIONS
Ports
4
Side A - Connector 1
(4) USB A (FEMALE)
Side B - Connector 1
USB A (MALE)
WARRANTY
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U202-004-R”相匹配的价格&库存,您可以联系我们找货
