U203-004-R
U203-004-R
    TRIPPLITE
    HUB USB 1.1 4-PORT BUS-POWER
U203-004-R 数据手册
USB / FireWire ® - 4 Port USB 1.1 Bus-Powered Hub* Highlights ● Link multiple USB devices to 1 computer with ultra-compact MODEL NUMBER: U203-004-R hubs ● Description Tripp Lite's 4-port Bus-Powered USB Hub is the ideal solution for increasing the number of available USB ports on a laptop/notebook computer. The unit features a compact design that does not require external power, software, or complicated set-up procedures. The hub features per-port overcurrent protection and plug-and-play/hot-swappable connection of devices. A 6-ft. USB AB cable is included. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Retail packaging System Requirements ● Computer with USB port. ● Compatible with Windows 98 or higher and Mac OS 8.5 or Features ● Features 4-ports to increase the number of available USB ports on a computer ● Compact design is ideal for use with a laptop/notebook computer ● Does not require external power, software, or complicated set-up procedures ● Plug-and-Play/hot-swappable allows you to add or remove a device at any time ● Fully rated for high speed transmissions (12 Mbps) ● Per-port overcurrent protection ● Diagnostic LEDs indicate power and port status ● Bus-powered - Unit receives power from connected devices ● Compatible with Windows 98, Windows 98 SE, Windows 2000, Windows ME, Windows XP and Mac OS higher. Package Includes ● U203-004-R 4-Port BusPowered USB Hub ● 6-ft. USB AB Cable 8.6 or higher ● 6-ft. USB AB cable included ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332095725 AC Adapter If optional power adapter is required: 5V, 2A, DC Plug: barrel type (coaxial) plug, (1.3mm/3.5mm). (Tripp Lite does not offer) Technology USB; USB 2.0 (High Speed) PHYSICAL Color Black Shipping Dimensions (hwd / cm) 15.88 x 12.70 x 4.44 Shipping Dimensions (hwd / in.) 6.25 x 5.00 x 1.75 Shipping Weight (kg) 0.28 Shipping Weight (lbs.) 0.61 CONNECTIONS 1/2 Ports 4 Side A - Connector 1 (4) USB A (FEMALE) Side B - Connector 1 USB A (MALE) WARRANTY Product Warranty Period (Worldwide) 1-year limited warranty © 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U203-004-R 价格&库存
很抱歉,暂时无法提供与“U203-004-R”相匹配的价格&库存,您可以联系我们找货
