DESCRIPTION: 0.085 RIBBON - SOLDER CUP
SPECIFICATIONS:
ELECTRICAL:
CURRENT RATING:
INSULATION RESISTANCE:
DIELECTRIC WITHSTANDING VOLTAGE:
CONTACT RESISTANCE:
OPERATING TEMPERATURE:
DIMENSIONS(mm)
SIZE
A
B±0.25
C±0.25
14
43.90±0.30
25.50
36.00
24
54.70±0.30
36.30
46.80
36
67.75±0.30
49.00
59.74
50
82.85±0.30
64.47
74.85
MATERIALS:
INSULATION:
CONTACTS:
CONTACT PLATING:
PIN 1
12.20±0.25
-55°C TO +105°C
PBT, UL 94 V-O RATED
PHOSPHOR BRONZE
GOLD FLASH IN MATING AREA
BRIGHT TIN IN SOLDER AREA
STEEL, NICKEL PLATED
SHELL:
B
1 AMPS
1,000 MΩ MIN. @ 500 VDC
1,000 VAC FOR 1 MINUTE
30 mΩ MAX.
15.30±0.30
111-YYY-1 0 3 L 00 1
Ø3.05
2.16
C
12.30±.25
8.50
3.70±0.38
12.80±.25
A
2.16
SERIES
POSITIONS
014
024
036
050
GENDER
1 = MALE
TERMINATION
0 = SOLDER CUP
SHELL PLATING
3 = NICKEL
RoHS COMPLIANT
L = LOW TEMP. PROCESS
HARDWARE
00 = NO HARDWARE
PLATING
1 = GOLD FLASH
WILL ACCEPT 26-20 AWG WIRE
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = mm
DRAWN:
WAYNE ROBBINS
DATE:
01/16/2019
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
111-YYY-103L001
13
1.270
Ø0.120
[TYP. ALL SIZES]
Ø0.210 (REF)
[TYP. ALL SIZES]
1.420 ±0.010
14 POSITION
0.550
[TYP. ALL SIZES]
2.350 ±0.010
36 POSITION
1.696
2.800
1.840 ±0.010
2.950 ±0.010
24 POSITION
RoHS COMPLIANT
N
C
2.205
50 POSITION
UNITS = inch
DRAWN:
WAYNE ROBBINS
DATE:
01/16/2019
0.430
[TYP. ALL SIZES]
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
111-YYY-103L001
13
很抱歉,暂时无法提供与“111-036-103L001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+54.728881+7.09391
- 10+46.5456610+6.03321
- 25+43.6245125+5.65457
- 50+41.5408750+5.38449
- 240+37.18775240+4.82024
- 480+35.41379480+4.59031
- 720+34.41569720+4.46093
- 1200+33.198641200+4.30318
- 2640+31.404502640+4.07062
