111-014-103L001
111-014-103L001
    NORCOMP
    111-014-103L001
111-014-103L001 数据手册
DESCRIPTION: 0.085 RIBBON - SOLDER CUP SPECIFICATIONS: ELECTRICAL: CURRENT RATING: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: CONTACT RESISTANCE: OPERATING TEMPERATURE: DIMENSIONS(mm) SIZE A B±0.25 C±0.25 14 43.90±0.30 25.50 36.00 24 54.70±0.30 36.30 46.80 36 67.75±0.30 49.00 59.74 50 82.85±0.30 64.47 74.85 MATERIALS: INSULATION: CONTACTS: CONTACT PLATING: PIN 1 12.20±0.25 -55°C TO +105°C PBT, UL 94 V-O RATED PHOSPHOR BRONZE GOLD FLASH IN MATING AREA BRIGHT TIN IN SOLDER AREA STEEL, NICKEL PLATED SHELL: B 1 AMPS 1,000 MΩ MIN. @ 500 VDC 1,000 VAC FOR 1 MINUTE 30 mΩ MAX. 15.30±0.30 111-YYY-1 0 3 L 00 1 Ø3.05 2.16 C 12.30±.25 8.50 3.70±0.38 12.80±.25 A 2.16 SERIES POSITIONS 014 024 036 050 GENDER 1 = MALE TERMINATION 0 = SOLDER CUP SHELL PLATING 3 = NICKEL RoHS COMPLIANT L = LOW TEMP. PROCESS HARDWARE 00 = NO HARDWARE PLATING 1 = GOLD FLASH WILL ACCEPT 26-20 AWG WIRE RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: WAYNE ROBBINS DATE: 01/16/2019 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 111-YYY-103L001 13 DESCRIPTION: 0.085 RIBBON - SOLDER CUP 1.270 Ø0.120 [TYP. ALL SIZES] Ø0.210 (REF) [TYP. ALL SIZES] 1.420 ±0.010 14 POSITION 0.550 [TYP. ALL SIZES] THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 2.350 ±0.010 36 POSITION 1.696 2.800 1.840 ±0.010 2.950 ±0.010 24 POSITION RoHS COMPLIANT N C 2.205 50 POSITION UNITS = inch DRAWN: WAYNE ROBBINS DATE: 01/16/2019 0.430 [TYP. ALL SIZES] DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 111-YYY-103L001 13
111-014-103L001 价格&库存
很抱歉,暂时无法提供与“111-014-103L001”相匹配的价格&库存,您可以联系我们找货
111-014-103L001
  • 1+46.277081+5.99839
  • 10+39.3355210+5.09864
  • 25+36.8660625+4.77855
  • 90+33.6782490+4.36535
  • 180+32.07025180+4.15692
  • 270+31.16603270+4.03971
  • 540+29.67897540+3.84696
  • 1080+28.263461080+3.66349
  • 2520+26.625222520+3.45114
库存:268
111-014-103L001
  • 1+40.885601+5.20730
  • 10+34.7399010+4.42460
  • 25+32.6058025+4.15280
  • 50+29.7954050+3.79480
  • 90+28.2561090+3.59880
  • 270+27.48640270+3.50070
  • 540+26.12200540+3.32700
  • 1080+24.920801080+3.17400
  • 2520+23.474802520+2.98980
