111-036-203L001
111-036-203L001
    NORCOMP
    111-036-203L001
111-036-203L001 数据手册
DESCRIPTION: 0.085 RIBBON - SOLDER CUP SPECIFICATIONS: DIMENSIONS(mm) SIZE A±0.30 B±0.25 C±0.25 14 43.90 36.00 25.20 24 54.70 46.80 36.00 36 67.75 59.74 48.90 50 82.85 74.85 64.10 ELECTRICAL: CURRENT RATING: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: CONTACT RESISTANCE: OPERATING TEMPERATURE: MATERIALS: INSULATION: CONTACTS: CONTACT PLATING: 1 AMPS 1,000 MΩ MIN. @ 500 VDC 1,000 VAC FOR 1 MINUTE 30 mΩ MAX. -55°C TO +105°C PBT, UL 94 V-O RATED PHOSPHOR BRONZE GOLD FLASH IN MATING AREA BRIGHT TIN IN SOLDER AREA STEEL, NICKEL PLATED SHELL: 111-YYY-2 0 3 L 00 1 SERIES POSITIONS 014 024 036 050 GENDER 2 = FEMALE TERMINATION 0 = SOLDER CUP SHELL PLATING 3 = NICKEL RoHS COMPLIANT L = LOW TEMP. PROCESS HARDWARE 00 = NO HARDWARE PLATING 1 = GOLD FLASH WILL ACCEPT 26-20 AWG WIRE RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: WAYNE ROBBINS DATE: 09/15/2005 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 111-YYY-203L001 10 DESCRIPTION: 0.085 RIBBON - BOARD CUTOUT 1.270 2.205 Ø0.210 (REF) [TYP. ALL SIZES] Ø0.120 [TYP. ALL SIZES] 1.417 ±0.010 14 POSITION 0.550 [TYP. ALL SIZES] 36 POSITION 0.430 [TYP. ALL SIZES] 1.696 2.800 46.80 ±0.010 74.85 ±0.010 24 POSITION RoHS COMPLIANT N C 2.352 ±0.010 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 50 POSITION UNITS = inch DRAWN: WAYNE ROBBINS DATE: 09/15/2005 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 111-YYY-203L001 10
111-036-203L001
PDF文档中包含以下信息: 1. 物料型号:型号为“LM324”,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的四运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,其他引脚包括电源和接地。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:详细描述了运算放大器的工作原理和应用场景。
6. 应用信息:适用于信号放大、滤波器设计、传感器信号调理等。
7. 封装信息:提供多种封装选项,如SOIC、DIP等。
111-036-203L001 价格&库存
很抱歉,暂时无法提供与“111-036-203L001”相匹配的价格&库存,您可以联系我们找货
111-036-203L001
  • 1+53.407281+6.92260
  • 10+45.3466310+5.87779
  • 25+42.5067025+5.50968
  • 50+40.4761450+5.24648
  • 100+38.54245100+4.99584
  • 250+36.12997250+4.68314
  • 520+34.63360520+4.48918
库存:266
