DESCRIPTION: 0.085 RIBBON - DIP SOLDER
SPECIFICATIONS:
DIMENSIONS(mm)
SIZE
A
B±0.25
C±0.25
14
43.90±0.25
36.00
25.20
24
54.70±0.25
46.80
36.00
36
67.73±0.30
59.74
48.90
50
82.85±0.30
74.85
64.10
ELECTRICAL:
CURRENT RATING:
INSULATION RESISTANCE:
DIELECTRIC WITHSTANDING VOLTAGE:
CONTACT RESISTANCE:
OPERATING TEMPERATURE:
1 AMPS
1,000 MΩ MIN. @ 500 VDC
1,000 VAC FOR 1 MINUTE
30 mΩ MAX.
-55°C TO +105°C
MATERIALS:
INSULATION:
CONTACTS:
CONTACT PLATING:
PBT, UL 94 V-O RATED
PHOSPHOR BRONZE
GOLD FLASH IN MATING AREA
BRIGHT TIN IN SOLDER AREA
STEEL, NICKEL PLATED
SHELL:
111-YYY-2 1 3 L 00 1
SERIES
POSITIONS
014
024
036
050
GENDER
2 = FEMALE
TERMINATION
1 = DIP SOLDER
RoHS COMPLIANT
L = LOW TEMP. PROCESS
SHELL PLATING
3 = NICKEL
HARDWARE
00 = NO HARDWARE
PLATING
1 = GOLD FLASH
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = mm
DRAWN:
WAYNE ROBBINS
DATE:
09/15/2005
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
111-YYY-213L001
10
DESCRIPTION: 0.085 RIBBON - DIP SOLDER - BOARD CUT OUT
1.270
2.205
Ø0.120
[TYP. ALL SIZES]
Ø0.210 (REF)
[TYP. ALL SIZES]
1.417 ±0.010
14 POSITION
2.352 ±0.010
36 POSITION
0.430
[TYP. ALL SIZES]
2.800
1.696
2.947 ±0.010
0.550
[TYP. ALL SIZES]
1.843 ±0.010
24 POSITION
RoHS COMPLIANT
N
C
50 POSITION
UNITS = inches
DRAWN:
WAYNE ROBBINS
DATE:
09/15/2005
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
111-YYY-213L001
10
很抱歉,暂时无法提供与“111-014-213L001”相匹配的价格&库存,您可以联系我们找货
