0.5mm and 1mm Pitch, 2.55mm Height FPC/FFC Connectors
FH28 Series
Robust locking structure
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Reinforced fitting provide support and prevent
the actuator from disengaging from the connector.
Each terminal is attached to the actuator,
so the actuator is supported along its entire length.
Fig.1
■Features
1. Highly reliable connection and robust structure
The FPC positioning mechanism and FPC tabs help to
guide and hold the FPC prior to engaging the actuator
Multi-polarized connectors, reinforced body structure and
high FPC retention produced by the following features:
Reliable connection created by its unique FPC/FFC
Prevents accidental disengagement with the design of its
proprietary structure
2. Simplified operations
The flip lock structure makes it easier to engage/disengage
the actuator and reduces the required force needed to
operate. A clear tactile click is delivered upon the
successful completion of the mating process. (Fig.1)
3. Increased FPC/FFC retention force
Vertical retention force for the FPC/FFC is 2.5 times
stronger than our 0.5mm pitch connector the FH12 series.
Horizontal retention force for the FPC/FFC is 2 times
*To realize the horizontal retention force values, the use
of the FPC positioning tabs are required. FPC without
the positioning tabs will comply with the specifications
rated on the FH12 series.
Fig.2
Can also be used with straight sided, non-tabbed
FPC/FFC
4. Accepts standard 0.3mm thick FPC/FFC
It accepts 0.3mm thick products that are easy to
manufacture and have superb insertion performance.
5. Fully molded structure aids PCB layout
The bottom of this connector is enclosed by a fully
molded structure that protects the contacts and
removes any restrictions from PCB patterning and
design.
6. Supports automatic pick-n-place mounting
Offered in tape and reel packaging that is compatible with
automatic machine mounting. (2,000pcs/reel)
7. Halogen-free
All materials and substances used to produce this product
comply with Halogen-free standards.*Defined according
to IEC61249-2-21. Br : 900ppm maximum, Cl : 900ppm
maximum, Br+Cl : 1,500ppm maximum
Fig.3
8. Multiple packing options
The standard packaging is 2,000pcs/reel, but it is
also offered in a 500pcs/reel. (The outer diameter of
the reel will be Ø330mm in this case.)
2019.9④
1
FH28 Series●0.5mm and 1mm Pitch, 2.55mm Height FPC/FFC Connectors
■Product Specifications
Adaptive FPC/FFC
contact specifications
Storage Temperature Range
-10 to +50ç (Note 3)
Storage Humidity Range
Relative humidity 90% or less (no condensation should be present)
t= 0.3 ±0.05 Gold plating
Item
Operating Temperature Range
-40 to +105ç (Note 2)
Operating Humidity Range
Relative humidity 90% or less (no condensation shouldbe present)
Rated Current 0.5A (Note 1)
Rated Voltage AC 50Vrms
Ratings
Specification
Conditions
1. Insulation Resistance
Minimum of 500Mø
Measured with DC 100V
2. Withstanding Voltage
No flashover or breakdown
AC 150Vrms is applied for 1 minute.
3. Contact Resistance
Maximum of 50mø
*including FPC/FFC conductor resistance
Measured at 1mA (DC or 1,000Hz)
4. Durability
Contact Resistance : Maximum of 50mø
No damaged, cracked or looseness of parts
20 mating cycles
5. Vibration Resistance
No electrical discontinuity of 1μs or greater
No damages, cracks and looseness of parts
Frequency : 10 to 55Hz
Single amplitude of 0.75mm for 10 cycles in 3 axial
directions
6. Shock Resistance
No electric discontinuity of 1μs or greater
Acceleration of 981m/s2, 6ms duaration, sine half-wave
waveform 3 cycles in each of the 3 axis
7. Humidity Resistance
of Steady State
Insulation Resistance : Minimum of 50Mø
96 hours at temperature : 40ç and humidity : 90 to 95%
8. Temperature Cycles
Temperature : -40/+15 to +35/+105/+15 to +35ç
Time : 30/2 to 3/30/2 to 3 minutes
5 cycles
9. Solder Heat
Resistance
Should not have external deformity or loose
parts
Reflow : according to the Recommended Temperature Profile
Hand solder: 350 ±5ç for 5 seconds
Note 1 : When energizing rated current to all contacts, use 70% of rated current.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term "storage" here refers to products stored for a long period prior to board mounting and use. The operating temperature
and humidity range covers the non-energized condition of connectors after board mounting and the temporary storage.
■Materials / Finish
Component
Materials
Color/Finish
Gray
Black
Gold plating
LCP
LCP
Phosphor bronze
Brass
Insulator
Contact
Metal fitting
Pure tin plating
Remarks
UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 28 D - 50 (25) S B - 0.5 SH (05)
1
2
2
3
1
Series Name : FH
2
Series No. : 28
3
4
5
6
7
8
9
10
6
7
Contact arrangement : Single (single row)
None, D : Standard type
E : Long reinforcing fitting type
H : Space-saving type
8
Contact Pitch : 0.5mm, 1mm
4
Standard type : The number of contacts
Eccentric type : Number of contacts in 0.5mm housing
9
Mounting direction , SH...SMT horizontal mounting type
10
5
Standard type : Blank
Eccentric type : Actual number of pins
Specification : (05) …Gold plating, 2,000 pcs/reel
(10) Specification:…Partial gold plating, 2,000 pcs/reel
(07)…Gold plating (for 40 contact only.), 2,000 pcs/reel
(98)…Gold plating, 500 pcs/reel
Eccentric direction : Blank…Standard type (without eccentricity)
B…Eccentric type (contacts on the opposite side of polarity mark)
■Connector Dimensions
[Standard type] 0.5mm pitch product
A
(1.9)
0.5
(0.2)
Contact mark
No. of contacts
6.5
5.7
1
0.05MAX
(5.4)
2
2.55
1
B
(1.3) E
1.2
4.5
(2.85)
(3.65)
0.1MAX
C (FPC/FFC insertion dimensions)
D
2
0.05MAX
0.7 0.1MAX
Notes 1 The coplanarity of the metal fitting and contact is 0.1 MAX.
2 The contact lead position shows the dimension from the E surface of the case bottom.
3 This product is sold in embossed, tape and reel packaging. For details on this product please refer to the “Packaging
Specifications”located on page 9.
4 Recesses in part structure may be added to improve molding characteristics.
Black marks may appear in the mold resin, but they will not negatively affect the performance of these connectors.
5 The color of the plating may change after the reflow process, but it will not negatively affect the performance of these connectors.
■Connector dimension table [Standard type]
Part No.
FH28-10S-0.5SH(**)
HRS No.
No. of Contacts
A
Unit : mm
B
C
D
586-1861-4 **
10
4.5
9.9
5.57
9.58
FH28-15S-0.5SH(**)
586-1868-3 **
15
7
12.4
8.07
12.08
FH28D-20S-0.5SH(**)
586-1823-5 **
14.9
10.57
14.58
FH28D-28S-0.5SH(**)
586-1835-4 **
28
13.5
18.9
14.57
18.58
FH28D-30S-0.5SH(**)
586-1827-6 **
30
14.5
19.9
15.57
19.58
FH28-40S-0.5SH(**)
586-1803-8 **
40
19.5
24.9
20.57
24.58
FH28-45S-0.5SH(**)
586-1848-6 **
45
22
27.4
23.07
27.08
FH28D-50S-0.5SH(**)
586-1808-1 **
50
24.5
29.9
25.57
29.58
FH28D-55S-0.5SH(**)
586-1821-0 **
55
27.0
32.4
28.07
32.08
FH28-60S-0.5SH(**)
586-1811-6 **
60
29.5
34.9
30.57
34.58
FH28D-64S-0.5SH(**)
586-1813-1 **
64
31.5
36.9
32.57
36.58
FH28D-68S-0.5SH(**)
586-1819-8 **
68
33.5
38.9
34.57
38.58
586-1828-9 **
74
36.5
41.9
37.57
41.58
FH28D-74S-0.5SH(**)
Note 1 : This product is sold in embossed, tape and reel packaging. This product is sold in full reel quantities of either 2,000 or
500 pcs/ reels. Please place orders by full reel quantities.
3
[Standard type] 1mm pitch product
A
(3.2)
(1.9)
(2.7)
1
(0.2)
Contact mark
B
No. of contacts
1
1
2
2.55
0.05MAX
(5.4)
6.5
5.7
(1.3) E
4.5
1.2
(2.85)
(3.65)
0.1MAX
D
2
0.05MAX
0.7 0.1MAX
Notes 1 The lead flatness of metal fitting and contact is 0.1 MAX.
Specifications” located on page 9.
Part No.
HRS No.
No. of Contacts
FH28D-20(10)SB-1SH(**)
Unit : mm
A
B
C
D
586-1863-0 **
10
9
14.9
10.57
14.58
FH28D-30(15)SB-1SH(**)
586-1860-1 **
15
14
19.9
15.57
19.58
FH28-40(20)SB-1SH(**)
586-1832-6 **
24.9
20.57
24.58
FH28D-50(25)SB-1SH(**)
586-1817-2 **
25
24
29.9
25.57
29.58
FH28-60(30)SB-1SH(**)
586-1818-5 **
30
29
34.9
30.57
34.58
FH28D-64(32)SB-1SH(**)
586-1852-3 **
32
31
36.9
32.57
36.58
FH28D-68(34)SB-1SH(**)
586-1812-9 **
34
33
38.9
34.57
38.58
4
[Space-saving type]
A
(1.9)
0.5
(0.2)
Contact mark
6
5.7
1
0MAX
(5)
2
2.55
1
No. of contacts
B
0MAX
(1.3) E
0.15MAX
4.5
1.2
(2.85)
D
0.7
0.15MAX
(3.15)
■Connector dimension table [Space-saving type]
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
FH28H-80S-0.5SH(**)
586-1805-3 **
80
39.5
44.9
40.57
45.7
5
BRecommended PCB layout and metal mask dimensions for 0.5mm
pitch products
Recommended metal mask thickness: t= 0.15
1±0.05 (metal mask)
J±0.1
4.2±0.1
1.3±0.1 (land)
3.9±0.1
1.3±0.1
0.5±0.05
0.3±0.03 (land)
0.25±0.03 (metal mask)
A±0.05
H±0.1
1.8±0.1
2.2±0.1
H±0.1
J±0.1
0.5±0.05
0.3±0.03 (land)
A±0.05
Standard type (FH28, FH28D)
Space-saving type (FH28H)
BRecommended FPC/FFC dimensions for 0.5mm pitch products
C
.2
4.5MIN
W
1.4±0.1
2.8±0.1
3.5MIN
R0
AX
.2M AX
.2M
R0
X
2MA
R0.
0.5±0.05
0.3±0.03
A±0.05
0.5±0.1
AX
5M
0.
R0
1
0.3±0.05
0.5±0.1
F±0.07
G±0.1
Notes 1 The stiffener needs to be a minimum of 0.188 (7.5 mil) thick.
2 The W dimension needs to be a minimum of 0.5mm.
BRecommended PCB layout, metal mask and FPC dimensions for
Unit : mm
Part No.
6
HRS No.
No. of Contacts
F
G
H
J
FH28-10S-0.5SH(**)
586-1861-4 **
10
5.5
7.1
10.6
7
FH28-15S-0.5SH(**)
586-1868-3 **
15
8
9.6
13.1
9.5
FH28D-20S-0.5SH(**)
586-1823-5 **
12.1
15.6
12.0
FH28D-28S-0.5SH(**)
586-1835-4 **
28
14.5
16.1
19.6
16.0
FH28D-30S-0.5SH(**)
586-1827-6 **
30
15.5
17.1
20.6
17.0
FH28-40S-0.5SH(**)
586-1803-8 **
40
20.5
22.1
25.6
22.0
FH28-45S-0.5SH(**)
586-1848-6 **
45
23
24.6
28.1
24.5
FH28D-50S-0.5SH(**)
586-1808-1 **
50
25.5
27.1
30.6
27.0
FH28D-55S-0.5SH(**)
586-1821-0 **
55
28.0
29.6
33.1
29.5
FH28-60S-0.5SH(**)
586-1811-6 **
60
30.5
32.1
35.6
32.0
FH28D-64S-0.5SH(**)
586-1813-1 **
64
32.5
34.1
37.6
34.0
FH28D-68S-0.5SH(**)
586-1819-8 **
68
34.5
36.1
39.6
36.0
FH28D-74S-0.5SH(**)
586-1828-9 **
74
37.5
39.1
42.6
39.0
FH28H-80S-0.5SH(**)
586-1805-3 **
80
40.5
42.1
46.7
42.0
BRecommended PCB layout and metal mask dimensions for 1mm
pitch products
2.2±0.1
H±0.1
0.3±0.03 (land)
1±0.05
A±0.05
1.75±0.1
1.25±0.1
BRecommended FPC/FFC dimensions for 1mm pitch products
X
2MA
R0.
C
.2
4.5MIN
W
1.4±0.1
2.8±0.1
3.5MIN
AX
X
MA
.2
R0
.2M
R0
R0
1±0.05
0.6±0.03
A±0.05
0.5±0.1
AX
5M
0.
1.3±0.1
3.9±0.1
J±0.1
1
0.3±0.05
1±0.1
F±0.07
G±0.1
Note 1 : The stiffener needs to be a minimum of 0.188 (7.5 mil) thick.
Note 2 : The W dimension needs to be a minimum of 0.5mm.
1mm pitch products
Unit : mm
Part No.
HRS No.
No. of Contacts
F
G
H
J
586-1863-0 **
10
10.5
12.1
15.6
12
586-1860-1 **
15
15.5
17.1
20.6
17
586-1832-6 **
22.1
25.6
22
586-1817-2 **
25
25.5
27.1
30.6
27
586-1818-5 **
30
30.5
32.1
35.6
32
586-1852-3 **
32
32.5
34.1
37.6
34
586-1812-9 **
34
34.5
36.1
39.6
36
7
BFH28 Series FPC/FFC Material Configuration (Recommended Specifications)
1. Single-Sided FPC
FPC : Flexible Printed Circuit
Layer
Cover lay film
Materials
Polymide
Thickness (μm)
1mil
(25)
Cover adhesive
(25)
Surface treatment
Under nickel plating 1~5μm+
gold plating 0.2μm
Copper foil
Cu
Base adhesive
Heat stiffener adhesive
25
Base film
Polymide
25
Stiffener adhesive
Reinforcing film
Polymide
3
35
1oz
1mil
30
7mil
175
Total
2. Double-sided FPC
293
Layer
Cover lay film
Materials
Polymide
Thickness (μm)
1mil
(25)
Cover adhesive
Surface treatment
gold plating 0.2μm
Through hole copper
Cu
Copper foil
Cu
Base adhesive
18
Base film
Polymide
25
Base adhesive
Copper foil
Cu
Cover adhesive
25
Cover lay film
Polymide
25
Stiffener adhesive
Reinforcing film
Polymide
* Remove the copper foil on the back of double-sided FPC to avoid
damage due to FPC bending.
3. FFC
(25)
3
15
18
1/2oz
1mil
18
(18)
1/2oz
1mil
50
4mil
100
Total
297
FFC : Flexible Flat Cable
Layer
Materials
Thickness (μm)
12
Polyester film
Adhesive
Polyester thermal plasticity
Annealed copper foil (Gold plated
with under nickel plating)
Adhesive
30
35
Polyester type
30
12
Polyester
Adhesive
Polyester type
30
Reinforcing film
Polyester type
188
Total
295
Nominal thickness tolerance is approximately ±20μm.
1. These specifications are an example of the material configuration of an FPC/FFC (t= 0.3 ±0.05) used on the FH28
series.
2. Please contact the FPC/FFC manufacturer for the material configurations of their FPC/FFC.
8
BPackaging Specifications
[Common specifications for FH28 Series]
4±0.1 2±0.15 12±0.1
.1
+0
Ø1
(Q)
(N)
M±0.1
K±0.3
(3)
(0.3)
1.75±0.1
●Embossed Carrier Tape Dimensions (with a maximum tape width of 24mm)
1.75±0.1
2±0.15
12±0.1
(8.5)
1.5+0.1
Unreeling Direction
M±0.1
(8)
1.5
+0.1
L±0.1
K±0.3
(R)
(Q)
(N)
L±0.1
K±0.3
(6.6)
1.7 +0.15
1.7 +0.15
(N)
(Q)
M±0.1
(0.3)
4±0.1
(3)
(0.3)
+0
0 1
2±0.15 12±0.1
Ø1
.5
4±0.1
+0
0 1
(3)
1.75±0.1
●Embossed Carrier Tape Dimensions (with a minimum tape width of 32mm)
Ø1
.5
Unreeling Direction
3)
●Reel Dimensions
(Ø 1
(Ø80)
(S: Reel inner width)
(Ø380)
(7.1)
(8.5)
(T: Reel outer width)
End section
Empty pockets
(minimum of 10 pockets)
Loaded product section
Leader section (minimum of 400 mm)
containing product
Empty pockets
Cover tape
9
BPackaging specification dimensions [standard type] for 0.5mm pitch
products
Part No.
FH28-10S-0.5SH(**)
FH28-15S-0.5SH(**)
FH28D-20S-0.5SH(**)
FH28D-28S-0.5SH(**)
FH28D-30S-0.5SH(**)
FH28-40S-0.5SH(**)
FH28-45S-0.5SH(**)
FH28D-50S-0.5SH(**)
FH28D-55S-0.5SH(**)
FH28-60S-0.5SH(**)
FH28D-64S-0.5SH(**)
FH28D-68S-0.5SH(**)
FH28D-74S-0.5SH(**)
HRS No.
586-1861-4 **
586-1868-3 **
586-1823-5 **
586-1835-4 **
586-1827-6 **
586-1803-8 **
586-1848-6 **
586-1808-1 **
586-1821-0 **
586-1811-6 **
586-1813-1 **
586-1819-8 **
586-1828-9 **
No. of Contacts
10
15
30
40
45
50
55
60
64
68
74
K
L
24
M
N
10.3
12.8
15.3
19.3
20.3
25.3
27.8
30.3
32.8
35.3
37.3
39.3
43.3
11.5
32
28.4
14.2
44
40.4
20.2
56
52.4
26.2
Q
5.5
8
10.5
14.5
15.5
20.5
23
25.5
28.0
30.5
32.5
34.5
42.3
S
Unit : mm
T
25.4
29.4
33.4
37.4
45.4
49.4
57.4
61.4
BPackaging specification dimensions [standard type] for 1mm pitch
products
Part No.
HRS No.
586-1863-0 **
586-1860-1 **
586-1832-6 **
586-1817-2 **
586-1818-5 **
586-1852-3 **
586-1812-9 **
No. of Contacts
10
15
30
32
34
K
24
32
L
---------28.4
M
11.5
14.2
44
40.4
20.2
56
52.4
26.2
N
15.3
20.3
25.3
30.3
35.3
37.3
39.3
Q
10.5
15.5
20.5
25.5
30.5
32.5
34.5
S
25.4
33.4
Unit : mm
T
29.4
37.4
45.4
49.4
57.4
61.4
BPackaging specification dimensions [Space-saving type]
Unit : mm
Part No.
FH28H-80S-0.5SH(**)
HRS No.
586-1805-3 **
No. of Contacts
80
K
56
L
52.4
M
26.2
N
46.3
Q
45.3
R
40.5
S
57.4
T
61.4
BRecommended soldering profile
MAX 250ç
250
Temperature
230ç
200
200ç
150
150ç
(ç)
Land/metal mask dimensions Our recommendation
conditions
100
50
25ç
(60 sec.) 90 to 120 seconds
Pre-heating time
Start
Time (sec)
10
Applicable Conditions
Reflow type
: Far red/hot air reflow
Reflow furnace atmosphere : Atmosphere
Soldering
: Cream type
Sn/3.0Ag/0.5Cu
(M705-221CM5-32-10.5 made
by Senju Metal Industry Co.)
Testing PCB
: Glass epoxy 55∞150∞1.6mm
(60 sec.)
Soldering Time
This solder profile is based on the conditions provided
above.
Please check the mounting conditions before use,
conditions such as solder paste types, manufacturer,
PCB size and any other soldering materials may alter
the performance of such materials.
BOperation Methods of Connector and Precautions
Operation Methods
1. FPC/FFC insertion method
1 Rotate the actuator upward to unlock it
The actuator can be easily operated with
the use of a thumb nail or index finger.
Precautions for use
1 The actuator on the FH28 series connector is
designed to open to a maximum of 116 degrees, trying
to open it farther than that will lead to damage.
116˚
2 Insert the FPC/FFC into the insertion slot
as show below. Improper insertion can
lead to damage and ultimately malfunction.
2 Insert the FPC/FFC with the contact sur-
face facing down. FH28 is a bottom contact
type connector.
Insert FPC/FFC from the diagonally left
side of the connector. Insert the FPC/FFC
at a diagonal angle and lay it into position.
Insert it until the FPC/FFC is securely
hooked on the positioning area. Check to
see if it is retained by pulling lightly on it.
For detail, refer to the next page.
Positioning part
3 Do not pull on the FPC/FFC in an upward
direction, doing this can damage the connector as it is not equipped to handle a
large amount of force in this direction.
3 Rotate the actuator downward.
4 When dealing with a higher contact count (80 posi-
tions), be sure to use two fingers to close the actuator
on both sides. Using one finger might not close it
completely and leave an incomplete connection.
2. Removing the FPC/FFC
1 Rotate the actuator upward, then angle the
FPC/FFC upward after the actuator has been
released and remove the FPC/FFC straight out.
5 When inserting FPC/FFC, do not rub it hard on the lower sur-
face of the insertion slot of the connector. Otherwise, the contact hits hard on the FPC/FFC, and may cause the deformation
of the contact or conductor separation etc. of the FPC/FFC.
During the insertion of the FPC/FFC, make sure that
11
BCautions when mating FFFC/FPC with positioning tabs
Operation Methods
Precautions for use
1. Position for insertion
2 PC/FFC must not over lap
Insert the cable into the gap (
) between the side walls
) on both sides of the cable insertion port' and the 'guide
walls (
) on both sides of the inner part of the connector'
putting the tab of the cable on the gap.
Do not close the actuator until the FPC/FFC has been
placed into its correct position. If it is sitting on the guides
and the actuator closes onto it, it can cause damage and
alter its performance.
Incorrectly placed onto
the left guide
the right guide
2. Cautions during insertion/mating
1 Do not insert the FPC/FFC at an skewed angle (as
shown), this type of action may cause the corner of the
cable to get hooked and deform its contacts.
Normal insertion
Skwed insertion
Do not close the actuator with
the cable sitting on either guide.
Insert the cable straight into the connector opening and
hook the cable tab onto the guide.
Pull the cable towards yourself with a slight force after
insertion, and close the actuator after confirming that the
cable tab is completely secured.
If it cannot be pulled to out, the cable can be determined to
be inserted into the correct position.
Recommended mating method
In case you accidentally close the lock with the cable sitting
on the guides, do not move the cable around to make it
seat. Open the actuator immediately and reposition the
cable as explained in “1. Position for insertion” noted
above.
1 Insert the cable
straight from the
diagonally left
side.
2 Pull the cable lightly to
yourself and check if
the tab is secured.
Pulling direction
3 Close the actuator.
12
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 09/2019. Contents are subject to change without notice for the purpose of improvements.
