111-024-113L001
111-024-113L001
    NORCOMP
    插件
    111-024-113L001
111-024-113L001 数据手册
DESCRIPTION: 0.085 RIBBON - DIP SOLDER SPECIFICATIONS: DIMENSIONS(mm) SIZE A B±0.25 C±0.25 14 43.90±0.25 36.00 25.20 24 54.70±0.25 46.80 36.30 36 67.75±0.30 59.74 49.00 50 83.10±0.30 74.85 64.47 ELECTRICAL: CURRENT RATING: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: CONTACT RESISTANCE: OPERATING TEMPERATURE: 1 AMPS 1,000 MΩ MIN. @ 500 VDC 1,000 VAC FOR 1 MINUTE 30 mΩ MAX. -55°C TO +105°C MATERIALS: INSULATION: CONTACTS: CONTACT PLATING: PBT, UL 94 V-O RATED PHOSPHOR BRONZE GOLD FLASH IN MATING AREA BRIGHT TIN IN SOLDER AREA STEEL, NICKEL PLATED SHELL: 111-YYY-1 1 3 L 00 1 SERIES POSITIONS 014 024 036 050 GENDER 1 = MALE TERMINATION 1 = DIP SOLDER RoHS COMPLIANT L = LOW TEMP. PROCESS SHELL PLATING 3 = NICKEL HARDWARE 00 = NO HARDWARE PLATING 1 = GOLD FLASH RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: WAYNE ROBBINS DATE: 09/21/1998 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 111-YYY-113L001 11 DESCRIPTION: 0.085 RIBBON - BOARD CUTOUT 1.227 2.131 Ø0.210 (REF) [TYP. ALL SIZES] Ø0.120 [TYP. ALL SIZES] 1.417 ±0.010 2.352 ±0.010 36 POSITION 14 POSITION 0.532 [TYP. ALL SIZES] 1.639 2.706 1.843 ±0.010 2.947 ±0.010 24 POSITION RoHS COMPLIANT N C 0.416 [TYP. ALL SIZES] THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 50 POSITION UNITS = inch DRAWN: WAYNE ROBBINS DATE: 09/21/1998 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 111-YYY-113L001 11
111-024-113L001 价格&库存
很抱歉,暂时无法提供与“111-024-113L001”相匹配的价格&库存,您可以联系我们找货
