FH33-4S-1SH(99)
FH33-4S-1SH(99)
    HRS(广濑)
FH33-4S-1SH(99) 数据手册
0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors FH33 Series Increased FPC retention force 1.2mm ●Small size 2.5mm [ 30 pos. ] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 17mm Metal fittings (Leadless) ■Features 1. Low-profile, small PCB mounting area ●Can be mounted over conductive traces. Narrow width of only 2.5 mm reduced the board footprint by approximately 17% to 57%, as compared to several similar FH Series HRS connectors. 2. Various contact pitch (0.4mm, 0.5mm, 1mm pitch) available In addition to standard 0.5mm pitch, 0.4mm pitch, 1mm pitch also available. 3. Increased FPC/FFC retention force _ In the horizontal direction: Approximately 2.0 times (compared to 0.5mm pitch FH12 series.) _ In the vertical direction: Approximately 1.7 times (compared to 0.5mm pitch FH19 series.) 4. Conductive traces on the PCB can run under the connector No exposed contacts on the bottom of the connector ●Simple operation q Open the actuator w Insert FPC No exposed contacts on the bottom of the connector. Actuator 5. One finger operation of the actuator 1 Proven (in several other Hirose’s connectors) FlipLock® rotating actuator assures reliable mechanical and electrical connection with FPC/FFC, confirming it with a definite tactile feel. 6. Easy FPC insertion and reliable electrical connection Proven Flip Lock actuator allows easy insertion of FPC/FFC and provides a tactile sensation when fully closed, confirming complete electrical and mechanical connection. 7. Accepts standard FPC thickness 0.3mm thick standard Flexible Printed Circuit (FPC) and Flexible Flat Cable (FFC) can be used. 8. Board placement equipment with automatic Flat upper surface and tape and reel packaging facilitate vacuum pick-up and placement. Standard reel packaging contains 5000 connectors. 9. Halogen-free* (FH33J Series) *As defined by IEC61249-2-21 Br-900ppm maximum, Cl-900ppm maximum, Cl + Br combined-1,500ppm maximum 2 FPC ●Locked condition e Close the actuator r FPC connected 3 3 4 2013.11w 1 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Product Specifications Current rating 0.5 A Operating temperature range -55 ç to +85ç (Note 1) (0.4mm pitch type 0.4A) Operating humidity range Relative humidity 90% max. Voltage rating 50 V AC (No condensation) (0.4mm pitch type 40V AC) Ratings Thickness = 0.3 ± 0.05mm gold plated (under 30 pos.), 0.3 ± 0.03mm gold plated (over 31 pos.) Recommended FPC Item Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Storage temperature range -10ç to +50ç (Note 2) Storage humidity range Relative humidity 90% max. (No condensation) Specification Conditions 1. Insulation resistance 500 Mø min. 100 V DC 2. Withstanding voltage No flashover or insulation breakdown. 150 V AC /one minute, 120 V AC /one minute(0.4mm pitch type) 3. Contact resistance 50 mø max. 100 mø max(0.4mm pitch type). * Including FPC conductor resistance 1 mA 4. Durability (insertion/ withdrawal) Contact resistance: 50 mø max. 100 mø max(0.4mm pitch type). No damage, cracks, or parts dislocation. 20 cycles No electrical discontinuity of 1μs or more. Contact resistance: 50 mø max. 100 mø max(0.4mm pitch type). No damage, cracks, or parts dislocation. 5. Vibration 6. Shock 7. Humidity (Steady state) Contact resistance: 50 mø max. 100 mø max(0.4mm pitch type). Insulation resistance: 50 Mø min. No damage, cracks, or parts dislocation. 8. Temperature cycle 9. Resistance to soldering heat Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 10 cycles in each of the 3 directions. Acceleration of 981 m/s2, 6 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 96 hours at 40ç and humidity of 90% to 95%. Temperature : -55ç/+15ç to +35ç/+85ç/+15ç to +35ç Time : 30 / 2 to 3 / 30 / 2 to 3 (Minutes) 5 cycles Reflow : At the recommended temperature profile Manual soldering: 350ç ± 10ç for 5 seconds No deformation of components affecting performance. Note 1: Includes temperature rise caused by current flow. Note 2: The term ”storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation. ■Materials Part Material Finish Color:Beige Color:Deep brown Color:Beige Color:Black Color:Beige Color:Deep brown Color:Beige Color:Black Gold flash plated Pure tin reflow plated PA FH33 series LCP PPS LCP PA LCP PPS FH33J series Insulator FH33M series FH33MHJ series Contacts Metalfittings Phosphor bronze Remarks UL94V-0 --------- ■Ordering information FH 33 M H J - 12 (6) S B - 1 SH (10) 1 2 3 4 5 6 7 8 9 10 11 1 Series name:FH 4 Blank:Width 3.0mm(standard) 7 Standard type:Blank H:Width 3.5mm(long actuator type) Eccentric type:Number of 2 Series No:33 contacts 3 Blank:0.5mm pitch,1mm pitch 5 Blank:Standard M:0.4mm pitch J:Halogen-free 8 Contact alignment:S: single Flame retardance UL94V-0 9 Eccentric direction: Blank:standard type 6 Standard type:Number of contacts Eccentric type:Number of contacts in 1mm housing 2 B:Eccentric type 12 10 Contact pitch: 0.4mm,0.5mm,1mm 11 SH:SMT horizontal mounting 12 Plating specifications: Blank:Gold plated (10)...Gold plating with nickel barrier 5,000pieces/reel (99)...Gold plating with nickel barrier 500pieces/reel FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Connector Dimensions ●0.4mm pitch, 0.5mm pitch type A±0.15 B G (1) T ∞Number of contacts (0.15) 0.15 G 2.25±0.15 Lot No. indicator U A** HRS mark Cav No. Number of contacts indicator (0.15) F (C: FPC insertion slot dimension) D±0.1 0.35±0.1 Notes 1 The coplanarity of each terminal lead is within 0.1 max. 2 The contact terminal lead position indicates the dimension from the bottom a surface of the insulator body. 3 Difference of each terminal lead is within 0.1 max. 4 Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. 5 After reflow, the terminal plating may change color, however this does not represent a quality issue. 0 1 2 0.5±0.1 a (1.1) 0.15MAX 0.55±0.1 1.73±0.2 2.2±0.15 1.2±0.1 (1 20 ˚) F (1.8) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Polarizing mark indicator 0.25±0.1 0 0.15MAX 1 2 0.3+0.15 3 – 0.1 Unit: mm Part Number CL No. Number of Contacts A B C D T U FH33-6S-0.5SH (**) FH33-9S-0.5SH (**) FH33-10S-0.5SH (**) FH33-12S-0.5SH (**) FH33-14S-0.5SH (**) FH33-19S-0.5SH (**) FH33-20S-0.5SH (**) FH33-26S-0.5SH (**) FH33-28S-0.5SH (**) FH33-30S-0.5SH (**) FH33-32S-0.5SH (**) FH33-36S-0.5SH (**) FH33-40S-0.5SH (**) FH33-45S-0.5SH (**) FH33M-16S-0.4SH (**) FH33J-4S-0.5SH (**) FH33J-10S-0.5SH (**) FH33J-12S-0.5SH (**) FH33J-16S-0.5SH (**) FH33J-18S-0.5SH (**) FH33J-19S-0.5SH (**) FH33J-40S-0.5SH (**) FH33MHJ-65S-0.4SH (**) 580-1301-1-** 580-1303-7-** 580-1304-0-** 580-1302-4-** 580-1305-2-** 580-1307-8-** 580-1317-1-** 580-1306-5-** 580-1300-9-** 580-1312-8-** 580-1310-2-** 580-1311-5-** 580-1308-0-** 580-1316-9-** 580-1319-7-** 580-1329-0-** 580-1324-7-** 580-1328-8-** 580-1331-2-** 580-1334-0-** 580-1332-5-** 580-1330-0-** 580-1325-0-** 6 9 10 12 14 19 20 26 28 30 32 36 40 45 16 4 10 12 16 18 19 40 65 5 6.5 7 8 9 11.5 12 15 16 17 18 20 22 24.5 8.3 4 7 8 10 11 11.5 22 27.9 2.5 4 4.5 5.5 6.5 9 9.5 12.5 13.5 14.5 15.5 17.5 19.5 22 6 1.5 4.5 5.5 7.5 8.5 9 19.5 25.6 3.57 5.07 5.57 6.57 7.57 10.07 10.57 13.57 14.57 15.57 16.57 18.57 20.57 23.07 6.87 2.57 5.57 6.57 8.57 9.57 10.07 20.57 26.47 4.35 5.85 6.35 7.35 8.35 10.85 11.35 14.35 15.35 16.35 17.35 19.35 21.35 23.85 7.65 3.35 6.35 7.35 9.35 10.35 10.85 21.35 27.25 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.4 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.4 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.95 Note 1: Embossed reel packaging (5,000 pieces/reel, 500 pieces/reel). Order by number of reels. 3 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Connector Dimensions ●1mm pitch type A±0.15 (1.75) B 1 G ∞Number of contacts (0.15) 0.15 G (1) Lot No. indicator A** △ HRS mark Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cav No. (0.45) Polarizing mark indicator 2.25±0.15 (V) Number of contacts indicator (0.15) (C: FPC insertion slot dimension) D±0.1 F 0.35±0.1 (1.8) Notes 1 The coplanarity of each terminal lead is within 0.1 max. 2 The contact terminal lead position indicates the dimension from the bottom a surface of the insulator body. 3 Difference of each terminal lead is within 0.1 max. 4 Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. 5 After reflow, the terminal plating may change color, however this does not represent a quality issue. 1 2 0 0.5±0.1 a (1.1) 0.15MAX 0.55±0.1 1.73±0.2 1.2±0.1 (1 20 ˚) F 0.25±0.1 0 0.15MAX 1 2 +0 15 Unit: mm Part Number CL No. Number of Contacts FH33-4S-1SH(**) 580-1322-1-** 4 FH33-12(6)SB-1SH(**) 580-1323-4-** 6 FH33J-12(6)SB-1SH(**) 580-1326-2-** 6 Note 1: Embossed reel packaging (5,000 pieces/reel, 500 pieces/reel). Order by number of reels. 4 A B C D V 6.5 8 8 3 5 5 5.07 6.57 6.57 5.85 7.35 7.35 1.75 1.25 1.25 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Recommended PCB mounting pattern and metal mask dimensions 0.65±0.05 ●0.4mm pitch, 0.5mm pitch type B H (0.2) (0.2) (2.45) (0.15) 0.8±0.05 (0.2) J±0.1 (2.15) 0.25±0.05(Metal mask) (0.15) 0.1 H 2.8±0.05 T ∞Number of contacts 0.3±0.05(Land) K±0.1 *Recommended metal mask thickness = 0.1mm ■Recommended FPC/FFC dimensions ●0.4mm pitch, 0.5mm pitch type L±0.05 B±0.03 .2 0.35±0.03(FPC) 0.3±0.03(FFC) 0.27±0.03(0.4mm pitch) 0.3±0.05 0.3±0.03 R0 T±0.03 E 3.3MIN(Stiffener) 2- T±0.07 2.3±0.3(Exposed area) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (A) Note 1: If the stiffener is less than 3.3 mm, E dimension must be 0.5 mm min. Unit: mm Part Number CL No. Number of Contacts A B J K L T FH33-6S-0.5SH (**) FH33-9S-0.5SH (**) FH33-10S-0.5SH (**) FH33-12S-0.5SH (**) FH33-14S-0.5SH (**) FH33-19S-0.5SH (**) FH33-20S-0.5SH (**) FH33-26S-0.5SH (**) FH33-28S-0.5SH (**) FH33-30S-0.5SH (**) FH33-32S-0.5SH (**) FH33-36S-0.5SH (**) FH33-40S-0.5SH (**) FH33-45S-0.5SH (**) FH33M-16S-0.4SH (**) FH33J-4S-0.5SH (**) FH33J-10S-0.5SH (**) FH33J-12S-0.5SH (**) FH33J-16S-0.5SH (**) FH33J-18S-0.5SH (**) FH33J-19S-0.5SH (**) FH33J-40S-0.5SH (**) FH33MHJ-65S-0.4SH (**) 580-1301-1-** 580-1303-7-** 580-1304-0-** 580-1302-4-** 580-1305-2-** 580-1307-8-** 580-1317-1-** 580-1306-5-** 580-1300-9-** 580-1312-8-** 580-1310-2-** 580-1311-5-** 580-1308-0-** 580-1316-9-** 580-1319-7-** 580-1329-0-** 580-1324-7-** 580-1328-8-** 580-1331-2-** 580-1334-0-** 580-1332-5-** 580-1330-0-** 580-1325-0-** 6 9 10 12 14 19 20 26 28 30 32 36 40 45 16 4 10 12 16 18 19 40 65 5 6.5 7 8 9 11.5 12 15 16 17 18 20 22 24.5 8.3 4 7 8 10 11 11.5 22 27.9 2.5 4 4.5 5.5 6.5 9 9.5 12.5 13.5 14.5 15.5 17.5 19.5 22 6 1.5 4.5 5.5 7.5 8.5 9 19.5 25.6 3.8 5.3 5.8 6.8 7.8 10.3 10.8 13.8 14.8 15.8 16.8 18.8 20.8 23.3 7.1 2.8 5.8 6.8 8.8 9.8 10.3 20.8 26.7 4.9 6.4 6.9 7.9 8.9 11.4 11.9 14.9 15.9 16.9 17.9 19.9 21.9 24.4 8.2 3.9 6.9 7.9 9.9 10.9 11.4 21.9 27.8 3.5 5 5.5 6.5 7.5 10 10.5 13.5 14.5 15.5 16.5 18.5 20.5 23 6.8 2.5 5.5 6.5 8.5 9.5 10 20.5 26.4 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.4 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.4 5 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Recommended PCB mounting pattern and metal mask dimensions ●1mm pitch type (0.2) 2.8±0.05 (0.15) 0.1 H Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.8±0.05 (0.2) W±0.1 1.15±0.1 (0.2) (2.45) 1 H 0.3±0.05(Land) 0.25±0.05(Metal mask) (0.15) ∞Number of contacts (2.15) 0.65±0.05 B J±0.1 K±0.1 (A) *Recommended metal mask thickness = 0.1mm ■Recommended FPC/FFC dimensions ●1mm pitch type L±0.1 X±0.1 B±0.1 1±0.1 0.3±0.05 0.3±0.03 0.65±0.1 1±0.1 .2 R0 E 3.3MIN(Stiffener) 2.3±0.3(Exposed area) 2- Unit: mm Part Number FH33-4S-1SH(**) FH33-12(6)SB-1SH(**) FH33J-12(6)SB-1SH(**) 6 CL No. Number of Contacts A B J K L W X 580-1322-1-** 580-1323-4-** 580-1326-2-** 4 6 6 6.5 8 8 3 5 5 5.3 6.8 6.8 6.4 7.9 7.9 5 6.5 6.5 1.15 0.65 0.65 1 0.5 0.5 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■FH33 Series FPC/FFC Construction (Recommended Specifications) 1. Using Single-sided FPC Material Name Covering film layer Cover adhesive Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Surface treatment Material Thickness (μm) Polyimide 1 mil thick (25) (25) Nickel under plated 1 to 5μm / Gold plated 0.2μm Copper foil Base adhesive Base film Reinforcement material adhesive Stiffener Cu 1oz Heat-hardened adhesive Polyimide 1 mil thick Heat-hardened adhesive Polyimide 7 mil thick Total Material Name Material 3 35 25 25 30 175 293 2. Using Double-sided FPC Covering film layer Cover adhesive Surface treatment Through-hole copper Copper foil Base adhesive Base film Base adhesive Copper foil Cover adhesive Covering film layer Reinforcement material adhesive Stiffener Thickness (μm) (25) (25) Polyimide 1 mil thick Nickel under plated 1 to 5μm / Gold plated 0.2μm 3 15 18 18 25 18 18 25 25 50 100 297 Cu Cu 1/2oz Heat-hardened adhesive Polyimide 1 mil thick Heat-hardened adhesive Cu 1/2oz Polyimide 1 mil thick Heat-hardened adhesive Polyimide 4 mil thick Total 3. Using FFC Material Name Material Thickness (μm) (12) Polyester film polyester thermoplastic type Adhesive Gold plated, soft copper film Adhesive (30) 35 Polyester Polyester 30 12 Adhesive Polyester 30 Stiffener Polyester 188 Total 295 π Practical tolerance of thickness dimension is ±20 μm 4. Precautions 1. This specification is a recommendation for the construction of the FH33 Series FPC and FFC (t=0.3 ± 0.05). 2. For details about the construction, please contact the FPC/FFC manufacturers. 7 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Packaging Specifications ●Embossed Carrier Tape Dimensions ●Embossed Carrier Tape Dimensions (Tape width 32mm and over) (1) P±0.1 1.7+0.15 0 M±0.3 1.75±0.1 (Q) M±0.3 (Q) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (3) (3.8) 1.75±0.1 8±0.1 (0.3) N±0.1 + 0 0 .1 Ø1 .5 4±0.1 2±0.15 (1.7) 8±0.1 (0.3) N±0.1 4±0.1 2±0.15 (1.7) Ø1 .5 + 0 0 .1 (Tape width up to 24mm) Flat surface for placement with automatic equipment 1.5+0.1 0 (3) (3.8) Unreeling direction Flat surface for placement with automatic equipment (1) Unreeling direction (Ø1 3) ●Reel Dimensions (Ø80) (Ø380) (R:INSIDE) (S:OUTSIDE) End section Blank section (10 pockets min.) Mounting section Embossed carrier tape Lead section (400 mm min.) Blank section (10 pockets min.) Note: 5,000 pieces per reel. Embossed tape 32 mm or wider will have perforated feed holes on two sides. 8 Top cover tape FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit: mm Part Number CL No. Number of Contacts M N P Q R S FH33-6S-0.5SH (**) FH33-9S-0.5SH (**) FH33-10S-0.5SH (**) FH33-12S-0.5SH (**) FH33-14S-0.5SH (**) FH33-19S-0.5SH (**) FH33-20S-0.5SH (**) FH33-26S-0.5SH (**) FH33-28S-0.5SH (**) FH33-30S-0.5SH (**) FH33-32S-0.5SH (**) FH33-36S-0.5SH (**) FH33-40S-0.5SH (**) FH33-45S-0.5SH (**) FH33M-16S-0.4SH (**) FH33J-4S-0.5SH (**) FH33J-10S-0.5SH (**) FH33J-12S-0.5SH (**) FH33J-16S-0.5SH (**) FH33J-18S-0.5SH (**) FH33J-19S-0.5SH (**) FH33J-40S-0.5SH (**) FH33MHJ-65S-0.4SH (**) FH33-4S-1SH (**) FH33-12(6)S-1SH (**) FH33J-12(6)S-1SH (**) 580-1301-1-** 580-1303-7-** 580-1304-0-** 580-1302-4-** 580-1305-2-** 580-1307-8-** 580-1317-1-** 580-1306-5-** 580-1300-9-** 580-1312-8-** 580-1310-2-** 580-1311-5-** 580-1308-0-** 580-1316-9-** 580-1319-7-** 580-1329-0-** 580-1324-7-** 580-1328-8-** 580-1331-2-** 580-1334-0-** 580-1332-5-** 580-1330-0-** 580-1325-0-** 580-1322-1-** 580-1323-4-** 580-1326-2-** 6 9 10 12 14 19 20 26 28 30 32 36 40 45 16 4 10 12 16 18 19 40 65 4 6 6 16 16 16 16 16 24 24 24 24 24 32 32 44 44 24 16 16 16 24 24 24 44 44 16 16 16 7.5 7.5 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 20.2 20.2 11.5 7.5 7.5 7.5 11.5 11.5 11.5 20.2 20.2 7.5 7.5 7.5 ----------------------------------------------------------------------28.4 28.4 40.4 40.4 -------------------------------------------------40.4 40.4 ---------------------- 5.3 6.8 7.3 8.3 9.3 11.8 12.3 15.3 16.3 17.3 18.3 20.3 22.3 24.8 8.6 4.3 7.3 8.3 10.3 11.3 11.8 22.3 28.2 6.8 8.3 8.3 17.4 17.4 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 45.4 45.4 25.4 17.4 17.4 17.4 25.4 25.4 25.4 45.4 45.4 17.4 17.4 17.4 21.4 21.4 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 49.4 49.4 29.4 21.4 21.4 21.4 29.4 29.4 29.4 49.4 49.4 21.4 21.4 21.4 9 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Recommended Temperature Profile ●Using Lead-free Solder paste HRS test conditions MAX 250ç Solder method : Reflow, IR/hot air Environment 250 230ç : Room air Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu Temperature (Senju Metal Industry, Co., Ltd.’s Part Number: M705200 200ç 221CM5-32-10.5) Test board : Glass epoxy 25mm∞50mm∞0.8mm thick Land dimensions : Contacts lead 0.3mm∞0.65mm 150 150ç Metal fittings 0.55mm∞0.8mm (ç) Metal mask : Contacts lead 0.25mm∞0.65mm∞0.1mm thick 100 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Metal fittings 0.55mm∞0.8mm∞0.1mm thick 50 25ç (60 sec.) 90 to 120 sec. (60 sec.) Preheating Sodering This temperature profile is based on the above conditions. In individual applications the actual temperature may vary, 0 Start Time (Seconds) depending on solder paste type, volume/thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. 10 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Operation and Precautions Operation 1.FPC insertion procedure. Connector installed on the board. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 Lift up the actuator. Use thumb or index finger. 2 Fully insert the FPC in the connector paral- lel to mounting surface, with the exposed conductive traces facing down. FPC conductor surface (Bottom side) 3 Rotate down the actuator until firmly closed. It is critical that the inserted FPC is not moved and remains fully inserted. 2.FPC removal 1 Lift up the actuator. Carefully withdraw the FPC. 11 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors Precautions Exercise care when handling connectors. Follow recommendations given below. PC board flexing SPC board connector mounting area Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The connectors are straight within 0.1 mm max. Make sure that the PC board connector mounting area flatness can accept the connector terminals without causing any failure of the solder joints. SHandling before mounting on PCB Insertion of the FPC or operation of the actuator prior to mounting on the PCB is NOT RECOMMENDED. SPC Board handling Exercise caution when handling boards with the connectors installed. Do not apply any forces affecting soldered joints. Connector PCB Precautions When Inserting or Removing FPC Pay attention to the following points when inserting FPC. SActuator operation 1 Do not apply excessive force when opening the actuator prior to FPC insertion. When opening make sure that the force is applied only to the actuator itself, avoiding touching of the contacts. Damege to the contacts Damage to the contacts 2 Axis of rotation 0˚) (12 Axis of rotation Assure free rotation of the actuator 3 The actuator will rotate 120 degrees maximum. Do not force it to rotate further. 12 0° 12 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors Precautions 4 When operating the actuator, do so at the center portion. 5 As illustrated, do not attempt removal or re- Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. positioning of the actuator. S FPC Insertionq The FPC should be aligned parallel with the board surface and perpendicular with the connector (as shown), then completely inserted. Actuator Perpendicular with the connector FPC To assure correct electrical and mechanical connection do not insert FPC at angle. It must be fully inserted. Make sure that the FPC is NOT MOVED during the closing of the actuator. SFPC Insertionw When inserting the FPC, do not forcefully rub against the bottom surface of the connector insertion entrance. Doing so will result in the contacts and FPC making strong contact and may cause deformation of the contacts, peeling of the FPC conductor, and other problems. Peeling of FPC conductor 13 FH33 Series●0.4mm,0.5 mm,1mm Pitch, 1.2 mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors Precautions SVerification of the fully closed actuator. The actuator should be fully closed (as illustrated) and the FPC held firmly in the connector. Do not press against the actuator when is fully closed. Max force applied to the fully closed actuator should not exceed 1 N. Routing the FPC (FPC fully inserted/ actuator closed) SFPC Load Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Do not apply force in excess of 0.15N max. in the upward direction (as illustrated). Do not bend the FPC too close to the actuator. Load: 0.15N max. Removing the FPC Rotate the actuator to the open position (maximum open angle of 120°). Carefully withdraw the FPC. 0° 12 Other Precautions SHand Soldering Precautions When hand soldering: 1 Do not perform reflow or hand soldering with the FPC inserted in the connector. 2 Do not apply excessive heat or touch the soldering iron anywhere other than the connector leads. 3 Do not use excessive amount of solder or flux compounds. Operation of the actuator and contacts may be affected by excessive amounts of solder or flux compounds. 14 FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. NOTES : 15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH33 Series●0.4mm,0.5mm,1mm Pitch, 1.2mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. Headquarters 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : 1-805-522-7958 Fax : 1-805-522-3217 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. North California Office 20400 Stevens Creek Blvd., Ste 250, Cupertino, CA 95014 Phone : 1-408-253-9640 Fax : 1-408-253-9641 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : 1-734-542-9963 Fax : 1-734-542-9964 http://www.hiroseusa.com GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : 49-711-4560-02-1 Fax : 49-711-4560-02-299 http://www.hirose.de THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : 31-20-6557460 Fax : 31-20-6557469 http://www.hiroseeurope.com UK: HIROSE ELECTRIC EUROPE B.V. UK BRANCH First Floor, St Andrews House, Caldecotte Lake Business Park, Milton Keynes MK7 8LE Phone : 44-1908-369060 Fax : 44-1908-369078 http://www.hirose.co.uk CHINA: HIROSE ELECTRIC CO., LTD. BEIJING REPRESENTATIVE OFFICE A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, Chao Yang District, Beijing, 100025 Phone : 86-10-5165-9332 Fax : 86-10-5908-1381 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1501-02, Cross Tower Building, 318 Fuzhou Road, Huang Pu District, Shanghai 200001 Phone : 86-21-6391-3355 Fax : 86-21-6335-0767 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC CO., LTD. SHENZHEN OFFICE Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre 5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008 Phone : 86-755-8207-0851 Fax : 86-755-8207-0873 http://www.hirose-china.com.cn HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Unit 1102 A&B, Energy Plaza, 92 Granville Road, Tsim Sha Tsui East, Kowloon Phone : 852-2803-5338 Fax : 852-2591-6560 http://www.hirose-hongkong.com.hk TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : 886-2-2555-7377 Fax : 886-2-2555-7350 http://www.hirose-taiwan.com.tw SINGAPORE: HIROSE ELECTRIC CO., LTD. 10 Anson Road #26-16 International Plaza 079903 Phone : 65-6324-6113 Fax : 65-6324-6123 http://www.hirose-singapore.com.sg KOREA: HIROSE KOREA CO., LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do 429-450 Phone : 82-31-496-7000,7124 Fax : 82-31-496-7100 http://www.hirose.co.kr ® 16 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the pur pose of improvements.
FH33-4S-1SH(99) 价格&库存
很抱歉,暂时无法提供与“FH33-4S-1SH(99)”相匹配的价格&库存,您可以联系我们找货
