0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors
FH36 Series
1.0mm MAX
●Space saving (51 positions shown)
2.7mm
[51 Positions]
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
16.9mm
■Features
Metal fittings do not protrude outside of the connector body
1. Low-profile and light weight
Weight: Reduced approximately 30%
Board footprint: Reduced approximately 15%
(As compared with Hirose Electric's FH26 Series
connectors (51 positions)
●Can be mounted over conductive traces
2. Easy solderability on the PC board
The soldering leads are on 0.6 mm pitch, exiting on
front and back of the connector.
3. Conducive traces on the PCB can run
under the connector
No exposed contacts on the bottom of the connector.
4. Easy FPC insertion and reliable
electrical connection
Proven Flip Lock actuator allows easy insertion of
FPC and provides a tactile sensation when fully
closed, confirming complete electrical and
mechanical connection.
the connector
●Operation
(1) Actuator open
(2) Insert FPC
Actuator
FPC
5. FPC position hold
Tabs on each side of the FPC assure correct
placement and hold in the connector prior to
closing of the actuator.
(3) Close the actuator
(4) FPC connected
6. Accepts standard FPC thickness
0.2mm thick standard Flexible Printed Circuit (FPC)
can be used. This is the only ultra-low profile ZIF
connector using standard FPC.
7. Board placement with automatic
equipment
Flat upper surface and tape and reel packaging
facilitate vacuum pick-up and placement.
Standard reel packaging contains 5,000
connectors.
●FPC temporary hold
8. Halogen-free *
(FH36W Series)
*As defined by IEC61249-2-21
Br-900ppm maximum, Cl-900ppm maximum,
Cl + Br combined-1,500ppm maximum
2013.11②
1
FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors
■Specifications
Operating
Current rating 0.2 A DC (Note 1)
-55 to +85°C (Note 2)
temperature range
Operating
Relative humidity 90%
Voltage rating 30 Vrms AC
humidity range
max. (No condensation)
Rating
Recommended FPC
Storage
-10 to +50°C (Note 3)
temperature range
Storage
humidity range
Thickness: 0.2±0.03mm Gold plated
Item
Specification
1.Insulation resistance 50 Mø min
2.Withstanding voltage No flashover or insulation breakdown
100 mø max.
3.Contact resistance
* Including FPC conductor resistance
Contact resistance: 100 mø max.
4.Durability
No damage, cracks, or parts dislocation
No electrical discontinuity of 1 μs or longer
5.Vibration
6.Shock
7.Humidity
Insulation resistance: 50 Mø min.
(Steady state)
8.Temperature cycle
Conditions
100 V DC
90 Vrms AC / one minute
9.Resistance to
soldering heat
1) Reflow: At the recommended temperature profile.
2) Manual soldering: 350ç ± 10ç for 5 seconds
1 mA
10 cycles
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm
10 cycles in each of the 3 directions
Acceleration of 981m/s2, 6 ms duration,
sine half-wave, 3 cycles in each of the 3 axis
96 hours at a temperature of 40°C and
humidity of 90 to 95%
Temperature:-55ç➝+15ç to +35ç➝+85ç➝+15ç to +35ç
Time: 30➝ 2 to 3 ➝ 30➝ 2 to 3 minutes
5 cycles
No deformation of components affection performance.
Note 1: When passing the current through all of the contacts, use 70% of the rated current.
Note 2: Includes temperature rise caused by current flow.
Note 3: The term "storage" refers to products stored for a long period prior to mounting and use.
The operating temperature and humidity range covers the non-conducting condition of installed connectors in
storage, shipment or during transportation.
■Materials
Part
Material
Insulator
LCP
Actuator
Finish
Color: Beige
FH36 series: Dark brown
PA
Contacts
UL94V-0
FH36W series: Light brown
UL94HB
Gold plating
Pure tin reflow plating
Phosphor bronze
Metal fittings
Remarks
■Ordering information
FH 36 W - 51S - 0.3 SHW (50)
1
2
3
4
5
6
7
1 Series name
: FH
4 Number of positions : 11 to 61
2 Series No.
: 36
5 Contact pitch : 0.3mm
3 Blank :Standard
W :Halogen-free
(Flame retardance UL94HB).
6 Termination type: SMT horizontal staggered mounting type
7 specifications
(50)…Gold plating with nickel barrier 5,000 pieces/reel
(99)…Gold plating with nickel barrier 500 pieces/reel
2
■Connector Dimensions
A±0.15
B±0.1
0.3±0.1
0.6±0.1
(0.12)
(2.75)
(1)
Lot No. indicator
A**
HRS mark
0.6±0.1
Cav No.
Number of contacts indicator
(0.12)
(1.0 MAX)
C±0.1
(0.47)
(D: FPC insertion slot dimension)
E±0.1
1
(0.25)
1
0.1
0.1
(2.7)
Note 1 : The coplanarity of each terminal lead is within 0.1.
Note 2 : Packaged on tape and reel only. Check packaging specification.
Note 3 : Slight discoloration in color of the plastic compounds does not affect form, fit or function of the connector.
Note 4 : After reflow, the terminal plating may change color, however this does not represent a quality issue.
All dimensions: mm
Part Number
FH36-15S-0.3SHW(50)
FH36-17S-0.3SHW(50)
FH36-19S-0.3SHW(50)
FH36-25S-0.3SHW(50)
FH36-29S-0.3SHW(50)
FH36-33S-0.3SHW(50)
FH36-35S-0.3SHW(50)
FH36-45S-0.3SHW(50)
FH36-51S-0.3SHW(50)
FH36-61S-0.3SHW(50)
FH36W-11S-0.3SHW(50)
FH36W-15S-0.3SHW(50)
FH36W-17S-0.3SHW(50)
FH36W-19S-0.3SHW(50)
FH36W-23S-0.3SHW(50)
FH36W-27S-0.3SHW(50)
FH36W-31S-0.3SHW(50)
FH36W-33S-0.3SHW(50)
FH36W-39S-0.3SHW(50)
FH36W-51S-0.3SHW(50)
FH36W-61S-0.3SHW(50)
CL No.
580-1618-8-50
580-1606-9-50
580-1607-1-50
580-1619-0-50
580-1613-4-50
580-1615-0-50
580-1604-3-50
580-1617-5-50
580-1601-5-50
580-1600-2-50
580-1625-3-50
580-1623-8-50
580-1616-2-50
580-1612-1-50
580-1614-7-50
580-1608-4-50
580-1609-7-50
580-1622-5-50
580-1620-0-50
580-1605-6-50
580-1611-9-50
Number of contacts
15
17
19
25
29
33
35
45
51
61
11
15
17
19
23
27
31
33
39
51
61
A
6.1
6.7
7.3
9.1
10.3
11.5
12.1
15.1
16.9
19.9
4.9
6.1
6.7
7.3
8.5
9.7
10.9
11.5
13.3
16.9
19.9
B
3.6
4.2
4.8
6.6
7.8
9
9.6
12.6
14.4
17.4
2.4
3.6
4.2
4.8
6
7.2
8.4
9
10.8
14.4
17.4
C
4.2
4.8
5.4
7.2
8.4
9.6
10.2
13.2
15
18
3
4.2
4.8
5.4
6.6
7.8
9
9.6
11.4
15
18
D
4.83
5.43
6.03
7.83
9.03
10.23
10.83
13.83
15.63
18.63
3.63
4.83
5.43
6.03
7.23
8.43
9.63
10.23
12.03
15.63
18.63
E
5.59
6.19
6.79
8.59
9.79
10.99
11.59
14.59
16.39
19.39
4.39
5.59
6.19
6.79
7.99
9.19
10.39
10.99
12.79
16.39
19.39
Tape and reel packaging (5,000 pieces/reel, 500 pieces/reel).
Order by number of reels.
3
(Recommended metal mask thickness: t=0.1)
B±0.05
(0.2)
(0.3)
0.3±0.05
(0.3:Metal mask)
0.6±0.05
0.3±0.03
(0.23:Metal mask)
0.4±0.05
0.535±0.05
C±0.05
■Recommended FPC Dimensions
2.2±0.3
S
0.1±0.02
(0.2)
0.3
0.9±0.2
0.2±0.03
B±0.03
J±0.05
A
+0.04
– 0.03
0.9±0.2
B
Detail S
MAX R0.2
2.4±0.1
1.65±0.05
1.15±0.05
0.3
R
0±0.03
*RELATIVE POSITIONS OF
POINT A and B
0.3±0.07
+0.04
– 0.03
3.3±0.3 (Stiffener)
disengagement shift
(0.07)
0.1±0.15
0.75±0.1
0.85±0.1
1.45±0.1
0.6±0.02
0.3±0.02
Detail R
(Lead plated 0.1 MAX)
F±0.1
G±0.1
H±0.05
C±0.03
0.3±0.07
(0.7:Metal mask)
0.95±0.05
0.03±0.05
1.67±0.05
0.3±0.05
(0.5)
0.6±0.05
0.3±0.03
(0.23:Metal mask)
0.8±0.05
(0.65:Metal mask)
(3.07)
0.6±0.05
(0.5:Metal mask)
■Recommended PCB mounting pattern and metal mask dimensions
R0.2±0.05
R0.2±0.1
(0.15)
R0.2±0.05
(R0.2)
(R0.2)
R0.2±0.05
All dimensions: mm
Part Number
FH36-15S-0.3SHW(50)
FH36-17S-0.3SHW(50)
FH36-19S-0.3SHW(50)
FH36-25S-0.3SHW(50)
FH36-29S-0.3SHW(50)
FH36-33S-0.3SHW(50)
FH36-35S-0.3SHW(50)
FH36-45S-0.3SHW(50)
FH36-51S-0.3SHW(50)
FH36-61S-0.3SHW(50)
4
CL No.
580-1618-8-50
580-1606-9-50
580-1607-1-50
580-1619-0-50
580-1613-4-50
580-1615-0-50
580-1604-3-50
580-1617-5-50
580-1601-5-50
580-1600-2-50
580-1625-3-50
580-1623-8-50
580-1616-2-50
580-1612-1-50
580-1614-7-50
580-1608-4-50
580-1609-7-50
580-1622-5-50
580-1620-0-50
580-1605-6-50
580-1611-9-50
Number of contacts
15
17
19
25
29
33
35
45
51
61
11
15
17
19
23
27
31
33
39
51
61
B
3.6
4.2
4.8
6.6
7.8
9
9.6
12.6
14.4
17.4
2.4
3.6
4.2
4.8
6
7.2
8.4
9
10.8
14.4
17.4
C
4.2
4.8
5.4
7.2
8.4
9.6
10.2
13.2
15
18
3
4.2
4.8
5.4
6.6
7.8
9
9.6
11.4
15
18
F
6.04
6.64
7.24
9.04
10.24
11.44
12.04
15.04
16.84
19.84
4.84
6.04
6.64
7.24
8.44
9.64
10.84
11.44
13.24
16.84
19.84
G
5.6
6.2
6.8
8.6
9.8
11
11.6
14.6
16.4
19.4
4.4
5.6
6.2
6.8
8
9.2
10.4
11
12.8
16.4
19.4
H
4.8
5.4
6
7.8
9
10.2
10.8
13.8
15.6
18.6
3.6
4.8
5.4
6
7.2
8.4
9.6
10.2
12
15.6
18.6
J
4.6
5.2
5.8
7.6
8.8
10
10.6
13.6
15.4
18.4
3.4
4.6
5.2
5.8
7
8.2
9.4
10
11.8
15.4
18.4
■Recommended FPC construction
●Contact FPC manufacturer for specific details.
1. Using Single-sided FPC
Connecting side
Material
Material Name
Covering film layer
Polyimide
1 mil thick.
(25)
(25)
Cover adhesive
Material Thickness
(μm)
Surface treatment
0.2μm thick gold plated over 1 to 5μm
thick nickel underplating
Copper foil
Cu
Base adhesive
Thermosetting adhesive
25
Base film
Polyimide
25
1oz
1 mil thick
3
35
Reinforcement material adhesive Thermosetting adhesive
40
Stiffener
Polyimide 3 mil thick
75
Total
203
Back side
2. Using Double-sided FPC
Connecting side
Material Name
Covering layer film
Material
Polyimide
1 mil thick
(25)
(25)
Cover adhesive
Back side
Material Thickness
(μm)
Surface treatment
Through-hole copper
Cu
Copper foil
Cu
Base adhesive
18
Base film
Polyimide
25
3
15
1/2oz
1 mil thick
18
Base adhesive
Copper foil
Cu
Cover adhesive
25
Covering film layer
Polyimide
25
1/2oz
1 mil thick
18
(18)
25
Stiffener
25
Polyimide
1 mil thick
Total
197
* To prevent release of the FPC due to its bending, use of the double sided FPC with copper foil on the back side is NOT
RECOMMENDED.
3.Precautions
1. This specification is a recommendation for the construction of the FH36 Series FPC (t=0.2 ± 0.03)
2. For details about the construction, please contact the FPC manufacturers.
5
■Packaging Specification
(3.85)
(1)
1.75±0.1
1.5 +0.1
Flat surface, for placement
with automatic equipment.
Unreeling direction
(Ø1
3)
●Reel Dimensions
K±0.3
M±0.1
(N)
(2.95)
L±0.1
8±0.1
4±0.1 2±0.15
1.7 +0.15
(0.3)
Ø1
.5
Ø
(N)
M±0.1
(1.5)
(0.3)
.1
+0 0
5
1.
1.75±0.1
8±0.1
K±0.3
4±0.1 2±0.15
●Embossed Carrier Tape Dimensions
(Tape width of 32mm min.)
+0
0 .1
(Tape width of 24mm max.)
(Ø80)
(Ø380)
(P:INSIDE)
(Q:OUTSIDE)
End section
No connector inserted
(25 pockets min.)
Lead section (400mm min.)
Mounting section
Embossed carrier tape
(25 pockets min.)
Top cover tape
All dimensions: mm
Part Number
FH36-15S-0.3SHW(50)
FH36-17S-0.3SHW(50)
FH36-19S-0.3SHW(50)
FH36-25S-0.3SHW(50)
FH36-29S-0.3SHW(50)
FH36-33S-0.3SHW(50)
FH36-35S-0.3SHW(50)
FH36-45S-0.3SHW(50)
FH36-51S-0.3SHW(50)
FH36-61S-0.3SHW(50)
6
CL No.
580-1618-8-50
580-1606-9-50
580-1607-1-50
580-1619-0-50
580-1613-4-50
580-1615-0-50
580-1604-3-50
580-1617-5-50
580-1601-5-50
580-1600-2-50
580-1625-3-50
580-1623-8-50
580-1616-2-50
580-1612-1-50
580-1614-7-50
580-1608-4-50
580-1609-7-50
580-1622-5-50
580-1620-0-50
580-1605-6-50
580-1611-9-50
Number of contacts
15
17
19
25
29
33
35
45
51
61
11
15
17
19
23
27
31
33
39
51
61
K
16
16
16
24
24
24
24
24
32
32
16
16
16
16
24
24
24
24
24
32
32
L
------------------------28.4
28.4
---------------------------28.4
28.4
M
7.5
7.5
7.5
11.5
11.5
11.5
11.5
11.5
14.2
14.2
7.5
7.5
7.5
7.5
11.5
11.5
11.5
11.5
11.5
14.2
14.2
N
6.3
6.9
7.5
9.3
10.5
11.7
12.3
15.3
17.1
20.1
5.1
6.3
6.9
7.5
8.7
9.9
11.1
11.7
13.5
17.1
20.1
P
17.4
17.4
17.4
25.4
25.4
25.4
25.4
25.4
33.4
33.4
17.4
17.4
17.4
17.4
25.4
25.4
25.4
25.4
25.4
33.4
33.4
Q
21.4
21.4
21.4
29.4
29.4
29.4
29.4
29.4
37.4
37.4
21.4
21.4
21.4
21.4
29.4
29.4
29.4
29.4
29.4
37.4
37.4
■Temperature Profile
●Using Lead-free Solder Paste
MAX 250ç
250
230ç
Temperature
(ç)
200
200ç
150
150ç
100
50
25ç (60sec.) 90 sec. to 120 sec.
Preheating
(60sec.)
Soldering
HRS test condition
Solder method
:Reflow, IR/hot air
Environment
:Room air
Solder composition :Paste,
96.5%Sn/3.0%Ag/0.5%Cu
(Senju Metal Industry, Co.,
Ltd.'s
Part Number:M705-221CM532-10.5)
Test board
:Glass epoxy
25mm∞50mm∞0.8mm thick
Land dimensions :0.3mm∞0.6mm,
0.3mm∞0.8mm
Metal mask
:0.23∞0.5, 0.23∞0.65∞0.1mm
thick
Start
Time (Seconds)
The temperature profiles shown are based on the
above conditions.
In individual applications the actual temperature may
vary,
depending on solder paste type, volume / thickness
and board size / thickness. Consult your solder
paste and equipment manufacturer for specific
recommendations.
7
■Operation and Precautions
Operation
1. FPC insertion procedure. Connector installed on the board.
1 Lift up the actuator.
Use thumb or index finger.
2 Insert the FPC (contact surfaces facing down) at
angle of approximately 10° to the board surface ①,
making sure that the FPC positioning tabs clear the
protrusions on both sides of the connector. Lower
the FPC down ②, parallel to the board surface.
FPC contact surface
faces downward
①
10°
②
Protrusions for
the FPC positioning.
3 Rotate down the actuator until firmly closed.
2. FPC removal
Pull up the FPC at an angle of approximately 10° ① and
than withdrew it from the connector ②.
125
②
10°
①
Protrusions for FPC positioning
8
Precautions
Exercise care when handling connectors. Follow recommendations given below.
[ Precautions when mounting connectors on the PCB ]
◆Handling before mounting on PCB
Insertion of the FPC or operation of the actuator prior to mounting on the PCB is NOT RECOMMENDED.
◆When braking the large PC board into individual boards exercise care NOT to damage the installed
connectors.
◆When attaching the boards or other components with the screws make sure that any stresses will NOT
cause board deflections affecting the mounting areas of the connector.
0.5MAX
◆Bending of the board
For a board width of 100 mm, bending of the board must be 0.5 mm max. (Ref to Fig. 1)
0.6
100
Connector
F
Board
F
Board
0.6
Connector
0.5MAX
◆PC board warpage
Minimize the warpage as much as possible. The connector is straight within 0.1 mm max. Make sure that
the mounting area flatness can accept the connector terminals without causing any failure of the solder
joints.
100
Fig. 1
[ Precautions during FPC insertion and mating ]
Pay attention to the following points when inserting FPC.
◆Actuator operation
1 Do not apply excessive force when opening the actuator prior to FPC insertion. When opening make
sure that the force is applied only to the actuator itself, avoiding touching of the contacts.
Actuator
Damage to the actuator
2 Axis of rotation
Assure free rotation of the actuator.
9
Precautions
3 The actuator will rotate 125ç. Do not apply force to rotate
12
further.
5°
4 When opening or closing the actuator, do so at
the center section.
5 Do not grasp or and lift the actuator (Fig. 2) nor insert
the nail from the back of it (Fig. 3).
Fig. 2
◆FPC insertion
Do not insert the FPC at any high angle from above.
10°
10
Fig. 3
Precautions
As illustrated (Fig. 4) angle insertion may cause electrical discontinuity when the FPC is deflected in use.
Opening of the FPC pattern
Fig. 4
• To avert insertion of the FPC at an angle, consideration should be given to securing enough
insertion space when designing the board lay-out. Insertion will be difficult when the FPC is too
short.
• Contact FPC manufacturer for information about the bending specifications.
◆Verification of the fully closed actuator
The FPC should be fully inserted, with its positioning tabs fully behind the protrusions on both sides of
the connector’s insertion slot (Fig. 5).
FPC positioning tab
Protrusions FPC positioning
Fig. 5
[ Routing of the FPC (FPC fully inserted / actuator closed) ]
◆Do not apply any pull or upward-directed force to the FPC.
Do not make any sharp bends of FPC close to the immediate exit from the connector (Fig. 6)
Fig. 6
11
Precautions
[ Removing of the FPC ]
◆Rotate the actuator to the fully open position (max. angle of 125ç)
Lift the FPC approximately 10ç (making sure that the positioning tabs clear the protrusions on both
sides) and carefully withdraw it from the connector.
125
10°
[ Other Precautions ]
◆Hand Soldering Precautions
When hand soldering:
1 Do not perform reflow or hand soldering with the FPC inserted in the connector.
2 Do not apply excessive heat or touch the soldering iron anywhere other than the connector leads.
3 Do not use excessive amount of solder or flux compounds.
Operation of the actuator or contacts may be affected by excessive amounts of solder or flux com-
12
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the purpose of improvements.
