DESCRIPTION: 0.085 RIBBON - SOLDER CUP
SPECIFICATIONS:
ELECTRICAL:
CURRENT RATING:
INSULATION RESISTANCE:
DIELECTRIC WITHSTANDING VOLTAGE:
CONTACT RESISTANCE:
OPERATING TEMPERATURE:
DIMENSIONS(mm)
SIZE
A
B
C
36
49.30±0.25 62.00±0.30 12.30±0.25
50
64.47±0.25 77.60±0.30 12.20±0.25
MATERIALS:
INSULATION:
CONTACTS:
CONTACT PLATING:
PIN 1
1 AMPS
1,000 MΩ MIN. @ 500 VDC
1,000 VAC FOR 1 MINUTE
30 mΩ MAX.
-55°C TO +105°C
PBT, UL 94 V-O RATED
PHOSPHOR BRONZE
GOLD FLASH IN MATING AREA
BRIGHT TIN IN SOLDER AREA
STEEL, NICKEL PLATED
SHELL:
A
15.30±0.30
111-YYY-1 0 3 L 10 1
B
12.80±0.25
8.50±0.25
C
2.16
3.50±0.38
4.75±0.25
SERIES
POSITIONS
036
050
GENDER
1 = MALE
TERMINATION
0 = SOLDER CUP
RoHS COMPLIANT
L = LOW TEMP. PROCESS
SHELL PLATING
3 = NICKEL
HARDWARE
10 = BAIL LATCH RECEPTACLE
PLATING
1 = GOLD FLASH
WILL ACCEPT 26-20 AWG WIRE
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = mm
DRAWN:
WAYNE ROBBINS
DATE:
09/15/2005
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
1
111-YYY-103L101
7
很抱歉,暂时无法提供与“111-014-103L101”相匹配的价格&库存,您可以联系我们找货
