111-036-113L101
111-036-113L101
    NORCOMP
    111-036-113L101
111-036-113L101 数据手册
DESCRIPTION: 0.085 RIBBON - DIP SOLDER SPECIFICATIONS: DIMENSIONS(mm) SIZE A (±0.30) B (±0.25) 36 62.00 49.30 50 77.60 64.47 ELECTRICAL: CURRENT RATING: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: CONTACT RESISTANCE: OPERATING TEMPERATURE: MATERIALS: INSULATION: CONTACTS: CONTACT PLATING: 1 AMPS 1,000 MΩ MIN. @ 500 VDC 1,000 VAC FOR 1 MINUTE 30 mΩ MAX. -55°C TO +105°C PBT, UL 94 V-O RATED PHOSPHOR BRONZE GOLD FLASH IN MATING AREA BRIGHT TIN IN SOLDER AREA STEEL, NICKEL PLATED SHELL: 111-YYY-1 1 3 L 10 1 SERIES POSITIONS 036 050 GENDER 1 = MALE TERMINATION 1 = DIP SOLDER RoHS COMPLIANT L = LOW TEMP. PROCESS SHELL PLATING 3 = NICKEL HARDWARE 10 = BAIL LATCH RECEPTACLE PLATING 1 = GOLD FLASH RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: WAYNE ROBBINS DATE: 09/15/2005 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 1 111-YYY-113L101 8
111-036-113L101 价格&库存
很抱歉,暂时无法提供与“111-036-113L101”相匹配的价格&库存,您可以联系我们找货
