MKT-E-07005F_1
FH19D / FH19SD Series
0.5mm Pitch, 0.9mm Height Connector for FPC
Black actuator
Brown actuator
FH19D
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
FH19SD
Features
1. Small size
2. Improved connection reliability with FPC side-catches
3. Advanced FPC locking system for easy and secure lock
4. Highly reliable actuator retention
5. Board surface under the connector is available for PCB patterning
6. Two choices of applicable FPC thickness
FH19D: 0.2 mm, FH19SD: 0.3 mm
7. Nickel barrier type is available for solder wicking prevention
8. RoHS compliant
Small size: FH19D & FH19SD
7.0
(10
pos
*Image: FH19SD
All dimensions in millimeters
Light weight: 0.028 g
(FH19SD)
FPC
Metal fitting catches
FPC tab in place
Pitch: 0.5
Contact protrusion
(FH19SD only)
0.03
0.9
3.4
FH19D height: 0.90 mm
FPC thickness: 0.2 mm
FH19SD height: 0.93 mm
FPC thickness: 0.3 mm
Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities.
© 2008 HIROSE ELECTRIC CO., LTD. All rights reserved.
Issued: Nov. 19, 2008
很抱歉,暂时无法提供与“FH19SDJ-10S-0.5SH”相匹配的价格&库存,您可以联系我们找货
