Description:
Dimensions (inch/mm)
0.283" Right Angle / Machined
Pins
9
A
±0.008
15
B
± 0.008
25
Ø 0.120
2-PLS
C
± 0.008
37
0.031 (0.80)
±0.008
50
F
±0.008
D
±0.008
Pin 1
C
D
E
F
1.213
30.80
1.543
39.20
2.089
53.05
2.732
69.40
2.638
67.00
0.984
25.00
1.311
33.30
1.852
47.05
2.500
63.50
2.402
61.00
0.665
16.90
0.994
25.25
1.533
38.95
2.181
55.40
2.079
52.80
0.327
8.30
0.327
8.30
0.327
8.30
0.327
8.30
0.429
10.90
0.240
6.10
0.240
6.10
0.240
6.10
0.240
6.10
0.236
6.00
0.492
12.50
0.492
12.50
0.492
12.50
0.492
12.50
0.602
15.30
173-EYY-11YRYY1
E
±0.008
0.433 (11.00)
±0.012
Material:
Shell:
Insulator:
Process Temperature:
Contact:
Nickel Plated Steel
UL 94V-O Rated, White PA6T
260°C
Precision Machined Copper Alloy
Electrical:
5 AMPS
10 mOhms Max.
5 GOhms Min.
1000 VAC for 1 minute
250V
-55° C TO +125° C
RoHS COMPLIANT
N
C
B
0.118 (3.00)
TYP.
Ø 0.026 (0.65)
Current Rating:
Contact Resistance:
Insulation Resistance:
Dielectric Withstanding Voltage:
Working Voltage:
Temperature:
A
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
Series
Position
E09
E15
E25
E37
E50
Gender
1 = Male
Termination
1 = PCB Mounting
Shell Plating
3 = Nickel
RoHS Compliant
Hardware Options
00 = No Hardware
0A = 0.098" Clinch Nut (Board Side)
14 = Standard Bracket with 4-40 Screwlock
24 = Standard Bracket with 4-40 Captive Screw
46 = Boardlock Bracket with 4-40 Insert
Plating Options
1 = Gold Flash
2 = 30 " Gold
3 = 50 " Gold
UNITS = inch [mm]
DRAWN:
PAM JENKINS
DATE:
11/28/2005
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
3
173-EYY-11YRYY1
24
Description: PCB Layout
9 POSITION
15 POSITION
25 POSITION
0.984
1.312
1.852
CL
CL
0.492
0.378
0.216
0.270
0.108
0.112 (9, 15, 25, 37 POSITON)
0.162
0.054
0.339
0.283
CL
Ø 0.126
Minimum
see page (3)
for Bracket
Hole Location
0.656
0.926
0.652
0.544
0.435
0.326
0.218
0.109
0.108
0.162
Ø 0.043
0.216
0.054
PCB Edge
Typical for
9,15,25,37 Position
0.324
0.055
0.163
0.272
0.381
0.489
0.598
37 POSITION
50 POSITION
2.500
2.406
CL
CL
1.250
0.978
0.870
0.870
Typical Suggested Size
0.761
0.761
* May Not Be Suitable For All Applications
0.652
0.652
0.544
0.544
0.435
0.435
0.326
0.326
0.224
0.218
0.218
0.109
0.109
0.055
0.112
0.163
0.272
0.489
0.598
PCB Edge
0.598
0.707
0.707
0.815
0.815
0.924
0.395
0.283
0.163
0.381
0.489
RoHS COMPLIANT
0.055
0.272
0.381
N
C
UNITS = inch
1.203
DRAWN:
PAM JENKINS
DATE:
11/28/2005
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
3
173-EYY-11YRYY1
24
Description: Hardware Options
0A Hardware Option
1
2
3
4
0.142 [3.60]
Description
NorComp Part Number
4-40 Screwlock
Bracket
Lock Washer
4-40 Nut
SFSO4401NR
K501CZ
LW1-T
N4401N
1
2
3
4
2
1
0.098 [2.50]
Clinch Nut has 4-40 Internal Threads
24 Hardware Option
14 Hardware Option
Description
NorComp Part Number
4-40 Captive Screw
Bracket
Lock Washer
4-40 Nut
SSH4401T
K501CZ
LW1-T
N4401N
2
1
3
3
4
4
**Search Hardware Part Number To Obtain Technical Specifications.
46 Hardware Option
Boardlock Bracket and 4-40 Insert
#4-40 Threaded Insert
50 Position Connector Boardlock Bracket
** 50 Position Comes With Locator Plate
9-37 Position Connector Boardlock Bracket
Hole C/L
0.339 [8.62]
Hole C/L
0.395 [10.03]
Boardlock Brackets Come Assembled On Connector
RoHS COMPLIANT
N
C
UNITS = inch [mm]
DRAWN:
PAM JENKINS
DATE:
11/28/2005
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
3
173-EYY-11YRYY1
24
很抱歉,暂时无法提供与“173-E15-113R001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+58.550521+7.56761
- 10+49.7775210+6.43371
- 25+46.6568925+6.03037
- 50+44.4279250+5.74228
- 100+42.30605100+5.46803
- 250+39.65752250+5.12571
- 560+37.46532560+4.84237
- 1120+35.678921120+4.61148
