DESCRIPTION: MICRO D-SUB CONNECTOR - MALE
SPECIFICATIONS:
ELECTRICAL:
INSULATOR RESISTANCE:
SIGNAL CONTACT RESISTANCE:
CONTACT CURRENT RATING:
D.W.V.:
OPERATING TEMPERATURE:
1000 MOHMS MIN.
45 mOHMS MAX.
1 AMP
500VAC
-55°C TO 85°C
MATERIALS:
INSULATOR:
PBT UL94V-0, BLK
230°C MAX PROCESS TEMP
ZINC ALLOY
15u" GOLD PLATED BERYLLIUM COPPER MATING AREA
TIN PLATED ON SOLDER AREA
SHELL:
CONTACTS:
DIMENSIONS(mm) ±0.15
SIZE
A
B
C
D
E
9
19.55
14.35
5.08
3.81
8.20
15
23.36
18.20
8.89
7.62
12.00
25
29.70
24.55
15.24
13.97
18.35
380-YYY-11YL001
SERIES
POSITIONS
009
015
025
PCB CONTACT LENGTH
3 = 2.50mm
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = mm
DRAWN:
M. SIGMON
DATE:
08/18/2011
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
380-YYY-113L001
5
9 POSITION
15 POSITION
CL
CL
HOLE SIZED DETERMINED
BY FASTENER USED*
25 POSITION
CL
*TYPICAL
RoHS COMPLIANT
N
C
UNITS = mm
DRAWN:
M. SIGMON
DATE:
08/18/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
380-YYY-113L001
5
很抱歉,暂时无法提供与“380-015-113L001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+161.155611+20.82924
- 国内价格
- 1+98.49407
- 25+95.53655
- 50+94.09944
- 250+92.68315
- 500+91.29811
