The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
HD SERIES SOLDER TYPE D SUBMINIATURE CONNECTOR
General
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
H D Series subminiature connectors with stamped contacts are easy to solder to a wide variety of stranded and
single conductor cables. 9, 15, 25, 37 and 50-contact models available.
Features
(1) Compact and sturdy due to metal shell.
(2) Large solder cup enables use of wire up to 20
AWG.
(3) Glass filled P.B.T. resin insulator offers excellent
resistance to heat and chemicals.
(4) Available in various plug cases such as CTF and
CTH. A wide variety of combinations available,
such as straight dipping (SD), right angle dipping
(RD), crimping (CD), and ribbon IDC termination
(FD).
Application
Computers, peripherals and terminals, control equipment, radio equipment, and measuring instruments.
51
04/2009
Electrical and Environmental
Electrical and Environmental Characteristics
Current capacity
3A
Rated voltage
400V AC
Insulation
resistance
5000mΩ min.
at 500V DC
Contact
resistance
7mΩ max.
at 100mA DC
Withstand
voltage
1250Vrms AC for 1 minute
Material and finish
Shell
Insulator
Male
Steel
Nickel plating
PBT(GE Valox)
Black
Coppor alloy
Contact
Selective Gold + Nickel
Female Phosphor bronze
Ordering Informations
HD
(1)
52
B
B − 25
(2) (3)
P
F (05)
(4) (5) (6) (7)
(1)
(2)
(3)
(4)
(5)
Model number symbol HD: D sub-soldering type
Shell size: E, A, B, C and D
Serial symbols by type of connector unit:
Number of poles: 9, 15, 25, 37 and 50
Terminal opening shape symbol
P: male terminal
S: female terminal
(6) F: shell dimple machined
(7) Specification contents
(05): Shell: Nickel plating
Termination of contact: Nickel plating+gold flash
plating
04/2009
Solder Cup dimension: φ1.1
Note 1: Soldering should be made within 4 seconds using
a soldering iron of 40 W or less.
Note 2: The figure shows a 25-contact model (HDBB-25P
(05))
Unit: mm
HDBB-25P(05)
HRS No
No.of pin
Part No.
A
B
C
D
E
F
CL211-0232-6-05
CL211-0234-1-05
CL211-0215-7-05
9
15
25
HDEB-9P(05)
HDAB-15P(05)
HDBB-25P(05)
30.81 24.99 16.9
39.14 33.32 25.24
53.04 47.04 39.01
CL211-0236-7-05
CL211-0393-5-05
37
50
HDCB-37P(05)
HDDB-50P(05)
G
8.34
8.34
8.4
1.2
1.2
1.3
5.99
5.99
5.87
12.55
12.55
12.55 YES
RoHS
69.32 63.5 55.47 8.4
66.93 61.11 52.85 11.13
1.4
1.5
5.87
5.87
12.55
15.37
Note 2: The figure shows a 25-contact model (HDBB-25PF
(05))
HDBB-25PF(05)
Unit: mm
HRS No
No.of pin
Part No.
A
B
C
CL211-0566-1-05
CL211-0563-3-05
9
15
HDEB-9PF(05)
HDAB-15PF(05)
30.81 24.99 16.9
39.14 33.32 25.24
CL211-0564-6-05
CL211-0567-4-05
25
37
HDBB-25PF(05)
HDCB-37PF(05)
53.04 47.04 39.01
69.32 63.5 55.47
D
E
F
8.34
1.2
5.99
8.4
1.3
1.4
5.87
G
RoHS
12.55 YES
53
04/2009
Note 2: The figure shows a 25-contact model (HDBB-25S
(05))
Unit: mm
HDBB-25S(05)
HRS No
No.of pin
Part No.
A
CL211-0233-9-05
CL211-0235-4-05
CL211-0216-0-05
9
15
25
HDEB-9S(05)
HDAB-15S(05)
HDBB-25S(05)
CL211-0237-0-05
CL211-0394-8-05
37
50
HDCB-37S(05)
HDDB-50S(05)
B
C
D
E
F
G
RoHS
30.81 24.99 16.4
39.14 33.32 24.59
53.04 47.04 38.3
1.2
1.2
1.2
7.82
7.82
7.82
12.55
12.55
12.55
6.17
6.17
6.17
YES
69.32 63.5 54.76
66.93 61.11 52.35
1.2
1.2
7.82 12.55
10.63 15.37
6.17
6.17
Mounting Cutout
Unit: mm
54
Shell Size
a
b
c
E
24.99
20.2
11.5
A
33.32
28.6
11.5
B
47.04
42.3
11.5
C
63.5
58.7
11.5
D
61.11
56
14.3
04/2009
很抱歉,暂时无法提供与“HDDB-50S(05)”相匹配的价格&库存,您可以联系我们找货
