L117DEFRA09S
L117DEFRA09S
    ARDUINO
    CONN DSUB RCPT 9POS STR IDC
L117DEFRA09S 数据手册
DFR D-Sub connectors - Stamped and Formed Contacts • Connectors according to MIL C24308 • UL File: E232356 Materials and Platings Shells Insulator Contacts Rear insert Screwlock DESCRI PTI ON Specifications These connectors are suitable for compact requirement of modern peripheral equipment. APPLI CATI ONS • Industrial Steel with nickel plating Glass-filled thermoplastic, UL 94V-0 Brass, selected gold in mating area; 2.54µm (100µ") min. tin on termination area over 1.27µm (50µ") min. nickel Brass, 2.54µm (100µ") min. nickel plated Brass, 2.54µm (100µ") min. nickel plated Special contact design allows usage of standard 1.27mm (.05") flat cable. Suitable with all standard D-Sub hoods. Electrical Data Current rating Voltage rating Withstanding voltage Insulation resistance Contact resistance 5A 250V AC/rms 60Hz 1000V AC/rms 60Hz for one minute 1000MΩ 20mΩ max Climatic Data Operating temperature -40°C to +125°C Mechanical Data Single contact insertion force Single contact withdrawal force Mating and unmating force Unit: kg ( lb) 0.54kg (1.19lb) max 0.06kg (0.13lb) min No. of Cts Mate (max) Unmate (min) 9 (size E) 15 (size A) 25 (size B) 37 (size C) 3.05 (6.74) 5.09 (11.24) 8.44 (18.66) 12.51 (27.65) 0.36 (0.79) 0.46 (1.01) 0.81 (1.8) 1.1 (2.47) Standard plating thicknesses • gold flash • 0.4µm (15µ") gold • 0.76 µm (30µ") gold • Telecom • Any industry standard I / O connections DFR / E12 CHARACTERI STI CS FLAT RIBBON D-SUB CONNECTORS D±0.13 (.005) E±0.05 (.002) POSITION #1 10° 12.55±0.38 (.494±.015) 7.9±0.13 (.311±.005) C±0.13 (.005) 2.84 (.112) 8.38±0.13 (.33±.005) B±0.13 (.005) 17.68 (.696) 5.8 (.228) 6.0 (.236) X 17.48 (.688) DIMENSIONS mm (inch) B C D Nb OF CONTACTS A 9 30.84 (1.21) 24.99 (.984) 16.92 (.666) 15 39.24 (1.54) 33.32 (1.31) 25 53.04 (2.09) 37 69.32 (2.73) E X 16.24 (.639) 11.09 (.437) 2.77 24.70 (.972) 24.56 (.967) 19.39 (.763) 2.77 47.04 (1.85) 38.96 (1.53) 38.38 (1.51) 33.24 (1.31) 2.77 63.50 (2.50) 55.42 (2.18) 54.76 (2.16) 49.86 (1.96) 2.77 4.7 (.185) STRAIN RELIEF 7.8 (.307) OVERALL DIMENSIONS A±0.38 (.015) 3.4 (.134") M3 or #4-40 TECHNICAL DATA Panel mounting option ø3.05 (.120") Standard rivet ø 3.05mm no digit Threaded rear insert B/D 5.8 (.228") M3 or #4-40 screwlock Front female screwlock A/C DFR / E12 Tool Support for hand termination tool: 974MC L ... ... FR ... ... ... ... C309 17D Flash gold contact plating 117D 0.4µm (15µ") gold contact plating Shell size E,A,B,C Flat ribbon cable type Mounting options No digit = Standard rivet ø 3.05mm A = Front screwlock M3 C = Front screwlock 4-40 B = Rear insert M3 D = Rear insert 4-40 Plating option Valid only for 0.76µm (30µ") part number must be written as follow: L 17D……………C309 Contact type P = Plug S = Socket Configuration 09, 15, 25, 37 Type A = Front metal shell- tin plated B = All plastic : Standard options A,B,C & D only available with type A connector with metal shell. Do not hesitate to contact us for further information Amphenol IT & Communication Products Block A3/A4, The 4th Industrial District of Industrial Headquarters, Dong Keng Road Gong Ming Town, Shen Zhen China Fax:+86(0)755 2754 9955 Technical Support Tel:+86(0)755 2717 7945 Info-dsub@amphenol.com.cn http://www.dsubconnector.com The information given in this document are as a guideline only. We reserve the right to modify our products in any way we deem necessary. Any duplication is prohibited, unless approved in writing. RoHS Compliant E12/H NOTES How to order
L117DEFRA09S 价格&库存
很抱歉,暂时无法提供与“L117DEFRA09S”相匹配的价格&库存,您可以联系我们找货
