DESCRIPTION: FEMALE - SOLDER CUP / MACHINED - ECONOMY
DIMENSIONS(mm)
SIZE
A+0.39
-0.39
B+0.25
-0.25
C+0.25
-0.25
D+0.25
-0.34
E+0.38
-0.38
F+0.25
-0.25
9
30.81
24.99
16.33
7.90
12.55
10.80
15
39.19
33.32
24.66
7.90
12.55
10.80
25
53.04
47.04
38.38
7.90
12.55
10.80
37
69.32
63.50
54.84
7.90
12.55
10.80
50
67.00
61.10
52.20
10.90
15.40
13.30
172-EYY-20YRYY1
WILL ACCEPT 26-20 AWG WIRE
MATERIAL:
SHELL:
INSULATOR:
PROCESS TEMP.:
CONTACT:
NICKEL OR TIN PLATED STEEL
PA6T, UL 94 V-0
260°C
BRASS
ELECTRICAL:
CURRENT RATING: 5 AMPS
CONTACT RESISTANCE: 15 mOhms Max.
INSULATION RESISTANCE: 1,000 MOhms min.
VOLTAGE: 500VAC FOR 1 MINUTE
TEMPERATURE: -55° C TO 125° C
RoHS COMPLIANT
SERIES
POSITIONS
E09
E15
E25
E37
E50
GENDER
2 = FEMALE
TERMINATION
0 = SOLDER CUP
SHELL PLATING
2 = TIN (N/A FOR HW "01" / "02" / "03")
3 = NICKEL
RoHS COMPLIANT
HARDWARE OPTIONS
00 = NO HARDWARE
01 = .098" CLINCH NUT (SOLDER SIDE)
02 = .236" CLINCH NUT (SOLDER SIDE)
03 = .236" CLINCH NUT (MATING SIDE)
05 = .237" 4-40 BOARD LOCK
91 = .237" 4-40 SPACER/ BOARD LOCK
PLATING OPTIONS
1 = GOLD FLASH
2 = 30µ" GOLD
UNITS = mm
DO NOT SCALE FROM DRAWING
N
C
NorComp
PAM JENKINS
NTS
11-28-05
1
2
172-EYY-20YRYY1
15
DESCRIPTION: CLINCH NUT HARDWARE
TOLERANCE:
ALL DIMENSIONS ARE ±0.010
ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS
01X ..... 0.098" (SOLDER SIDE)
02X ..... 0.236" (SOLDER SIDE)
03X..... 0.236" (MATING SIDE)
0.236
0.141
0.279
0.098
0.279
0.236
05X ..... 0.237" (SOLDER SIDE)
91X ..... 0.237" (SOLDER SIDE)
0.234
0.506
0.280
0.237
0.237
NOTE: 4-40 FEMALE SCREW LOCK IS REMOVABLE
UNITS = INCH
N
C
RoHS COMPLIANT
NorComp
PAM JENKINS
NTS
11-28-05
2
2
172-EYY-20YRYY1
15
很抱歉,暂时无法提供与“172-E15-202R001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+21.66396250+2.80381
