173-E37-113R141
173-E37-113R141
    NORCOMP
173-E37-113R141 数据手册
Description: Dimensions (inch/mm) 0.283" Right Angle / Machined Pins 9 A ±0.008 15 B ± 0.008 25 Ø 0.120 2-PLS C ± 0.008 37 0.031 (0.80) ±0.008 50 F ±0.008 D ±0.008 Pin 1 C D E F 1.213 30.80 1.543 39.20 2.089 53.05 2.732 69.40 2.638 67.00 0.984 25.00 1.311 33.30 1.852 47.05 2.500 63.50 2.402 61.00 0.665 16.90 0.994 25.25 1.533 38.95 2.181 55.40 2.079 52.80 0.327 8.30 0.327 8.30 0.327 8.30 0.327 8.30 0.429 10.90 0.240 6.10 0.240 6.10 0.240 6.10 0.240 6.10 0.236 6.00 0.492 12.50 0.492 12.50 0.492 12.50 0.492 12.50 0.602 15.30 173-EYY-11YRYY1 E ±0.008 0.433 (11.00) ±0.012 Material: Shell: Insulator: Process Temperature: Contact: Nickel Plated Steel UL 94V-O Rated, White PA6T 260°C Precision Machined Copper Alloy Electrical: 5 AMPS 10 mOhms Max. 5 GOhms Min. 1000 VAC for 1 minute 250V -55° C TO +125° C RoHS COMPLIANT N C B 0.118 (3.00) TYP. Ø 0.026 (0.65) Current Rating: Contact Resistance: Insulation Resistance: Dielectric Withstanding Voltage: Working Voltage: Temperature: A THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Series Position E09 E15 E25 E37 E50 Gender 1 = Male Termination 1 = PCB Mounting Shell Plating 3 = Nickel RoHS Compliant Hardware Options 00 = No Hardware 0A = 0.098" Clinch Nut (Board Side) 14 = Standard Bracket with 4-40 Screwlock 24 = Standard Bracket with 4-40 Captive Screw 46 = Boardlock Bracket with 4-40 Insert Plating Options 1 = Gold Flash 2 = 30 " Gold 3 = 50 " Gold UNITS = inch [mm] DRAWN: PAM JENKINS DATE: 11/28/2005 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 173-EYY-11YRYY1 24 Description: PCB Layout 9 POSITION 15 POSITION 25 POSITION 0.984 1.312 1.852 CL CL 0.492 * 0.378 0.216 0.270 0.108 0.112 (9, 15, 25, 37 POSITON) 0.162 0.054 0.339 0.283 CL Ø 0.126 Minimum see page (3) for Bracket Hole Location 0.656 0.926 0.652 0.544 0.435 0.326 0.218 0.109 0.108 0.162 Ø 0.043 0.216 0.054 PCB Edge Typical for 9,15,25,37 Position 0.324 * 0.055 0.163 0.272 0.381 0.489 0.598 37 POSITION 50 POSITION 2.500 2.406 CL CL 1.250 0.978 0.870 0.870 Typical Suggested Size 0.761 0.761 * May Not Be Suitable For All Applications 0.652 0.652 0.544 0.544 0.435 0.435 0.326 0.326 0.224 0.218 0.218 0.109 0.109 0.055 0.112 0.163 0.272 0.489 0.598 PCB Edge 0.598 0.707 0.707 0.815 0.815 0.924 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 0.395 0.283 0.163 0.381 0.489 RoHS COMPLIANT 0.055 0.272 0.381 N C UNITS = inch 1.203 DO NOT SCALE FROM DRAWING DRAWN: PAM JENKINS DATE: 11/28/2005 NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 173-EYY-11YRYY1 24 Description: Hardware Options 0A Hardware Option 1 2 3 4 0.142 [3.60] Description NorComp Part Number 4-40 Screwlock Bracket Lock Washer 4-40 Nut SFSO4401NR K501CZ LW1-T N4401N 1 2 3 4 2 1 0.098 [2.50] Clinch Nut has 4-40 Internal Threads 24 Hardware Option 14 Hardware Option 0.098" Clinch Nut (Board Side) Description NorComp Part Number 4-40 Captive Screw Bracket Lock Washer 4-40 Nut SSH4401T K501CZ LW1-T N4401N 2 1 3 3 4 4 **Search Hardware Part Number To Obtain Technical Specifications. **Search Hardware Part Number To Obtain Technical Specifications. 46 Hardware Option Boardlock Bracket and 4-40 Insert #4-40 Threaded Insert 50 Position Connector Boardlock Bracket ** 50 Position Comes With Locator Plate 9-37 Position Connector Boardlock Bracket Hole C/L 0.339 [8.62] Hole C/L 0.395 [10.03] Boardlock Brackets Come Assembled On Connector RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inch [mm] DRAWN: PAM JENKINS DATE: 11/28/2005 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 173-EYY-11YRYY1 24
173-E37-113R141 价格&库存
很抱歉,暂时无法提供与“173-E37-113R141”相匹配的价格&库存,您可以联系我们找货
173-E37-113R141
  • 1+131.591431+17.02487
  • 10+111.8698010+14.47335
  • 32+103.0480932+13.33202
  • 64+98.1285764+12.69555
  • 128+93.44715128+12.08989
  • 256+92.97001256+12.02816
库存:9
173-E37-113R141
