DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67
ELECTRICAL:
INSULATOR RESISTANCE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
POWER CONTACT AMPERAGE:
1.543 [39.20]
5 GΩ MIN.
250V
-55°C TO +125°C
1.0 mΩ MAX.
SEE P/N KEY
1.311 [33.30]
MECHANICAL:
4.5 Kg MAX.
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE: 0.3 Kg MIN.
0.994 [25.25]
A1
SHELL:
BRACKET:
BOARD LOCK:
SEAL:
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
F08 FLEXIBLE ADHESIVE
230°C PROCESS TEMP.
0.492 [12.50]
4
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
A2
1 2
3
MATERIALS:
CONTACTS:
INSULATOR:
5
0.327 [8.30]
MEETS IP67 STANDARDS
(SEE PAGE 3 FOR SEALING DETAILS)
0.240
[6.10]
0.031 [0.80]
684S7W2103LYYY
00 = 40 AMP POWER // NO BRACKET // STANDARD PCB TAILS
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
M. SIGMON
DATE:
04/22/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
3
684S7W2103L461
3
RIGHT ANGLE BRACKET
DIMENSIONS(in/mm)
0.269
OPTION
#4-40 INSERT
1.311
0.043
5-PLACES
0.269
S
P
0.146
0.185
46
3.70
4.70
0.087
0.087
2.22
2.22
62
Ø 0.130
2-PLACES
Ø 0.165
2-PLACES
0.0545
0.109
[2.77]
TYP.
0.420 [10.67]
SIGNAL CONTACTS
0.100
POWER CONTACTS
0.370
PCB EDGE
0.520
Ø 0.026 [Ø 0.65]
0.420
S
Ø 0.148 [Ø 3.75]
P
0.370 [9.40]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
04/22/2013
0.520 [13.20]
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
3
684S7W2103L461
3
A
A
FRONT SEAL APPLIED OVER INSULATOR
AND BETWEEN FRONT & REAR SHELLS
DETAIL A-A
SHOWN FOR REFERENCE ONLY
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
04/22/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
3
684S7W2103L461
3
很抱歉,暂时无法提供与“684S7W2103L461”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+122.86245
- 20+120.14444
- 40+116.55167
- 国内价格 香港价格
- 1+181.448121+23.39217
- 10+154.2111610+19.88080
- 25+144.5510025+18.63542
- 70+134.4236670+17.32981
- 140+128.01152140+16.50316
- 280+121.90744280+15.71622
- 560+116.09603560+14.96702
