DESCRIPTION: Vertical Mount Female Low Profile/Plastic Back Press Fit
Dimensions (mm)
Size
A
B
C
09
30.81
24.99
16.33
15
39.20
33.30
24.70
25
53.05
47.04
38.40
37
69.40
63.50
54.80
Material:
Insulator:
Contact:
Shell:
Nylon 6T, UL94V-0, 260°C Process Temp, Black
Phosphor Bronze
Nickel Plated Steel
Electrical:
Current Rating:
Contact Resistance:
Insulation Resistance:
Working Voltage:
Operating Temperature:
5 AMPS
20 mOhms Max.
1000 MOhms Min.
250V
-55° C TO +125° C
191-YYY-223RYYY
1.42
2.77
Series
Position
009
015
025
037
Gender
2 = Female
Termination
2 = Press Fit
Shell Plating
3 = Nickel
Hardware Options
00 = No Hardware
55 = 4-40 Insert
56 = 4-40 Insert with Board Locks
57 = 4-40 Standoff with Board Locks
59 = 4-40 Standoff
Plating Options
1 = Gold Flash mating area, Tin plated tails
2 = 30 " Gold mating area, Tin plated tails
View A
2.84
∅3.3 x 2
∅1.05 ±0.02
Recommended PCB Layout
RoHS COMPLIANT
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = mm
DRAWN:
Pam Jenkins
DATE:
9/15/2003
Tolerance
X.
.X
.XX
±0.38
±0.25
±0.13
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
191-YYY-223RYYY
7
DESCRIPTION: Hardware Options
RoHS COMPLIANT
UNITS = mm
DRAWN:
Pam Jenkins
DATE:
9/15/2003
Tolerance
X.
.X
.XX
±0.38
±0.25
±0.13
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
191-YYY-223RYYY
7
很抱歉,暂时无法提供与“191-015-223R001”相匹配的价格&库存,您可以联系我们找货
