172-009-283L011
172-009-283L011
    NORCOMP
172-009-283L011 数据手册
DESCRIPTION: FEMALE // DIP SOLDER // HIGH PROFILE DIMENSIONS (mm) POSITIONS A B C D E(REF) F 9 30.81 24.99 16.33 7.90 15.45 11.45 15 39.19 33.32 24.66 7.90 24.50 11.45 25 53.04 47.04 38.38 7.90 37.83 11.45 37 69.32 63.50 54.84 7.90 54.45 11.45 50 67.00 61.10 52.20 10.90 51.85 11.40 MATERIAL: SHELL: INSULATOR: PROCESS TEMP: CONTACTS: HARDWARE: STEEL, NICKEL PLATED UL 94V-O RATED, PBT-BLACK 230°C BRASS - GOLD PLATED NICKEL PLATED BRASS ELECTRICAL: CURRENT RATING: 5 AMPS CONTACT RESISTANCE: 10 mOhms Max. INSULATION RESISTANCE: 5,000 MOhms min. WORKING VOLTAGE: 250VAC RMS OPERATING TEMPERATURE: -55°C TO 100°C 172-YYY-28YLYY1 SERIES POSITIONS 009 015 025 037 050 GENDER 2 = FEMALE TERMINATION 8 = HIGH PROFILE VERTICAL SHELL PLATING 3 = NICKEL (GROUND INDENTS) RoHS COMPLIANT HARDWARE OPTIONS 00 = NO HARDWARE 01 = 2.50mm CLINCH NUT (BOARD SIDE) 02 = 5.80mm CLINCH NUT (BOARD SIDE) 03 = 5.80mm CLINCH NUT (MATING SIDE) PLATING OPTIONS 1 = GOLD FLASH RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: W. ROBBINS DATE: 08/23/1998 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 172-YYY-28YLYY1 22 DESCRIPTION: FEMALE // DIP SOLDER // HIGH PROFILE 1.312 CL 0.984 CL 0.656 0.378 CL 0.492 0.216 0.108 0.112 (9, 15, 25, 37 POSITON) 0.270 0.162 0.054 0.054 * Ø 0.043 0.926 0.652 0.544 0.435 Ø 0.126 MINIMUM 0.108 0.216 0.324 0.162 0.326 0.218 0.109 * 0.055 0.163 0.272 0.381 0.489 0.598 15 POSITION 9 POSITION 2.500 2.406 CL CL 1.250 0.978 0.870 0.761 0.652 0.544 0.435 0.326 0.218 0.109 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 0.224 0.055 0.163 0.272 0.381 0.489 0.598 0.707 0.815 * HARDWARE MOUNTING HOLES MAY NOT BE REQUIRED DEPENDING ON MOUNTING METHOD TO PCB TYP. SUGGESTED SIZE MAY NOT BE SUITABLE FOR ALL APPLICATIONS 50 POSITION 37 POSITION RoHS COMPLIANT 25 POSITION 1.203 0.870 0.761 0.652 0.544 0.435 0.326 0.218 0.109 0.055 0.163 0.272 0.381 0.489 0.598 0.707 0.815 0.924 N C 1.852 UNITS = inch DRAWN: W. ROBBINS DATE: 08/23/1998 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 172-YYY-28YLYY1 22
172-009-283L011 价格&库存
很抱歉,暂时无法提供与“172-009-283L011”相匹配的价格&库存,您可以联系我们找货
172-009-283L011
    • 1+87.608831+11.35578
    • 10+74.4323410+9.64785
    • 25+69.7694625+9.04345
    • 50+66.4379850+8.61163
    • 100+63.26679100+8.20058
    • 300+58.54967300+7.58915
    • 500+56.47916500+7.32078
    • 1000+53.786381000+6.97174
    库存:1339
