171-025-103L011
171-025-103L011
    NORCOMP
171-025-103L011 数据手册
DESCRIPTION: MALE // SOLDER CUP // STAMPED D 0.109 [2.77] 0.236±0.006 [6.00] (50 PIN DIMENSION) 0.240±0.006 [6.10] [0.90±0.3] SPECIFICATIONS: MATERIALS: SHELL: NICKEL OR TIN PLATED STEEL INSULATOR: PBT +30% GF, UL 94V-0, BLACK CONTACTS: COPPER ALLOY, GOLD PLATED ELECTRICALS: CURRENT RATING: 5 AMPS CONTACT RESISTANCE: 15 mOHMS MAX INSULTOR RESISTANCE: 1000 MOHMS MIN VOLTAGE: 500V AC FOR 1 MINUTE WORKING VOLTAGE: 250 VAC TEMPERATURE: -50°C TO +100°C A±0.015 B±0.004 0.161 [4.09] ±0.006 C±0.010 E±0.010 F±0.010 PIN #1 171-YYY-10YLYY1 SERIES POSITIONS 009 015 025 037 050 GENDER 1 = MALE TERMINATION 0 = SOLDER CUP SHELL PLATING 2 = TIN (NOT AVAILABLE FOR HW OPTIONS) 3 = NICKEL (GROUND INDENTS) HARDWARE OPTIONS 00 = NO HARDWARE 01 = .098" 4-40 CN (SOLDER SIDE) 02 = .236" 4-40 CN (SOLDER SIDE) 03 = .236" 4-40 CN (MATING SIDE) 05 = .237" 4-40 BOARD LOCK (.063" PCB) 91 = .237" 4-40 JACK SCREW / BOARD LOCK (.063" PCB) PLATING OPTIONS 1 = GOLD FLASH 2 = 30u" GOLD MATING AREA // GF TAILS 0.429 ±0.010 [10.90] Ø0.120 [3.05] 0.178±0.010 [4.52] DIMENSIONS (in/mm) POS. 9 15 25 37 50 A B 1.213 0.984 30.80 24.99 C D E 0.666 0.756 0.329 0.496 16.92 19.20 8.36 12.60 1.541 1.312 0.994 1.091 0.329 0.496 39.15 33.32 25.25 27.70 8.36 12.60 2.087 1.853 1.534 1.618 0.329 0.496 53.00 47.04 38.96 41.10 8.36 12.60 2.728 2.500 2.181 2.256 0.329 0.496 69.30 63.50 55.42 57.30 8.36 12.60 2.638 2.406 2.079 2.169 0.436 0.602 67.00 61.00 52.80 55.10 11.07 15.30 RoHS COMPLIANT N C F THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. WILL ACCEPT 28-20 AWG CONDUCTORS UNITS = INCHES [MM] DRAWN: J. KADEL DATE: 07/24/2018 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 171-YYY-10YLYY1 15 DESCRIPTION: CLINCH NUT HARDWARE TOLERANCE: ALL DIMENSIONS ARE ±0.010 ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS 01X ..... 0.098" (SOLDER SIDE) 02X ..... 0.236" (SOLDER SIDE) 03X..... 0.236" (MATING SIDE) 0.279 0.141 0.279 0.098 0.236 0.236 05X ..... 0.237" (SOLDER SIDE) 91X ..... 0.237" (SOLDER SIDE) 0.234 0.280 0.506 0.063 0.237 RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. NOTE: 4-40 FEMALE SCREW LOCK IS REMOVABLE 0.063 0.237 UNITS = INCHES DRAWN: J. KADEL DATE: 07/24/2018 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 171-YYY-10YLYY1 15
171-025-103L011
物料型号:171-YYY-10YLYY1
器件简介:这是一个男性端子,具有焊接杯。
引脚分配:文档提供了50个引脚的尺寸,但具体的引脚分配未在摘要中提及。
参数特性: - 材料:外壳为镀镍或镀锡钢,绝缘体为PBT+30% GF,符合UL 94V-0标准,黑色。 - 电气特性:电流额定值为5安培,接触电阻最大为15毫欧姆,绝缘体电阻最小为1000兆欧姆。 - 接触材料:铜合金,金镀层。 - 电压:AC 500V,持续1分钟的工作电压为250V AC。 - 工作温度范围:-50°C至+100°C。
功能详解:文档中未提供具体的功能详解,但根据参数特性,该连接器适用于高电流和高电压的应用。
应用信息:文档中未明确提供应用信息,但根据其电气特性,可能适用于工业或商业电子设备。
封装信息:文档提供了详细的尺寸信息,包括位置、A、B、C、D、E和F尺寸,以及用于接受28-20 AWG导体的规格。
171-025-103L011 价格&库存
很抱歉,暂时无法提供与“171-025-103L011”相匹配的价格&库存,您可以联系我们找货
171-025-103L011
  • 1+28.390221+3.67992
171-025-103L011
