172-025-212R911
172-025-212R911
    NORCOMP
172-025-212R911 数据手册
DESCRIPTION: FEMALE - DIP SOLDER / MACHINED - PREMIUM MATERIAL: SHELL: INSULATOR: PROCESS TEMP.: CONTACT: DIMENSIONS(mm) SIZE A±.36 B±.10 C±.15 D±.15 E±.38 F±.25 G±.25 9 30.80 24.99 16.30 8.00 19.20 12.60 10.90 15 39.15 33.32 24.60 8.00 27.70 12.60 10.90 25 53.04 47.04 38.40 8.00 41.10 12.60 10.90 37 69.32 63.50 54.80 8.00 57.30 12.60 10.90 50 66.93 61.11 52.30 10.80 55.10 15.20 13.60 A (2X) Ø3.05 B 0.80 C F PINS Ø0.60 D G Pin 1 5.23 5.80 (50P 6.20mm) 4.88 STEEL, TIN UL 94V-O RATED, PA6T 260°C BRASS (FLOATING CONTACTS) ELECTRICAL: CURRENT RATING: 5 AMPS CONTACT RESISTANCE: 15 mOhms Max. INSULATION RESISTANCE: 1,000 MOhms Min. VOLTAGE: 500VAC FOR 1 MINUTE TEMPERATURE: -50° C TO 100° C 172-YYY-212RYY1 SERIES POSITIONS 009 015 025 037 050 GENDER 2 = FEMALE TERMINATION 1 = DIP SOLDER SHELL PLATING 2 = TIN RoHS COMPLIANT HARDWARE OPTIONS 00 = NO HARDWARE 01 = .065" NUT (PCB SIDE) 02 = .250" NUT (PCB SIDE) 03 = .250" NUT (MATING SIDE) 05 = .237" 4-40 BOARD LOCK 90 = .237" 4-40 BOARD LOCK FOR 0.093" BOARD MAX. 91 = .237" 4-40 SPACER/ BOARD LOCK 92 = .237" 4-40 SPACER/ BOARD LOCK FOR 0.093" BOARD MAX. PLATING OPTIONS 1 = GOLD FLASH 2 = 30MICRO-INCH GOLD DO NOT SCALE FROM DRAWING E RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OF SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. NorComp UNITS = mm PAM JENKINS NTS 09-12-05 1 3 172-YYY-212RYY1 21 DESCRIPTION: PCB LAYOUT - STANDARD DSUB 1.312 CL 0.984 1.852 CL 0.656 0.378 CL 0.492 0.216 0.108 0.270 0.162 0.054 0.112 (9, 15, 25, 37 POSITON) * Ø 0.126 MINIMUM 0.326 0.218 0.109 CL 0.162 0.108 0.216 0.324 0.056 (9, 15, 25, 37 POSITON) 0.054 Ø 0.043 0.926 0.652 0.544 0.435 * 0.055 0.163 0.272 0.381 0.489 0.598 15 POSITION 9 POSITION 2.500 2.406 CL CL 1.250 0.978 0.870 0.761 0.652 0.544 0.435 0.326 0.218 0.109 25 POSITION 1.203 0.870 0.761 0.652 0.544 0.435 0.326 0.218 0.109 0.224 CL 0.055 0.163 0.272 0.381 0.489 0.598 0.707 0.815 0.924 37 POSITION 0.055 0.163 0.272 0.381 0.489 0.598 0.707 0.815 50 POSITION N C 0.112 * UNITS = inch TYP. SUGGESTED SIZE MAY NOT BE SUITABLE FOR ALL APPLICATIONS DO NOT SCALE FROM DRAWING THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OF SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. NorComp PAM JENKINS NTS 09-12-05 2 3 172-YYY-212RYY1 21 DESCRIPTION: CLINCH NUT HARDWARE TOLERANCE: ALL DIMENSIONS ARE ±0.010 UNLESS OTHERWISE SPECIFIED ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS **NOTE: 90 & 92 OPTION FOR 0.093" MAX. BOARD THICKNESS "02" // PCB SIDE "01" // PCB SIDE "03" // MATING SIDE 0.293 0.293 0.108 0.065 0.250 0.250 "91" // PCB SIDE "05" // PCB SIDE "90" // PCB SIDE ** 0.234 REF ONLY 0.506 +0.000 -0.030 0.280 +0.005 -0.025 0.280 +0.005 -0.025 0.237 REF ONLY 0.237 REF ONLY 0.237 REF ONLY NOTE: 4-40 FEMALE SCREW LOCK IS REMOVABLE "92" // PCB SIDE ** 0.234 REF ONLY 0.506 +0.000 -0.030 UNITS = inch N C 0.237 REF ONLY RoHS COMPLIANT DO NOT SCALE FROM DRAWING THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OF SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. NorComp PAM JENKINS NTS 09-12-05 3 3 172-YYY-212RYY1 21
172-025-212R911 价格&库存
很抱歉,暂时无法提供与“172-025-212R911”相匹配的价格&库存,您可以联系我们找货
172-025-212R911
  • 1+85.446981+11.08668
  • 10+72.6027110+9.42015
  • 25+68.0493125+8.82935
库存:31
