DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED
5 GΩ MIN.
250V
-55°C TO +125°C
1.543 [39.20]
1.0 mΩ MAX.
10 mΩ MAX.
1.311 [33.30]
SEE P/N KEY
5 AMPS
0.994 [25.25]
4.5 Kg MAX.
0.3 Kg MIN.
0.492 [12.50]
A1
3 4
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
A2
1 2
230°C PROCESS TEMP.
5
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
0.327 [8.30]
10°
0.240
[6.10]
0.031 [0.80]
684M7W2103LYYY
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
P. JENKINS
DATE:
08/22/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
684M7W2103L461
5
RIGHT ANGLE BRACKET
DIMENSIONS(in/mm)
0.269
OPTION
#4-40 INSERT
1.311
0.043
5-PLACES
0.269
S
P
0.146
0.185
3.70
4.70
0.087
0.087
2.22
2.22
46
62
Ø 0.165
2-PLACES
0.0545
0.109
[2.77]
TYP.
0.100
0.420 [10.67]
SIGNAL CONTACTS
0.370
Ø 0.130
2-PLACES
POWER CONTACTS
PCB EDGE
0.520
Ø 0.026 [Ø 0.65]
0.420
S
Ø 0.148 [Ø 3.75]
P
0.370 [9.40]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
P. JENKINS
DATE:
08/22/2011
0.520 [13.20]
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
684M7W2103L461
5
很抱歉,暂时无法提供与“684M7W2103L461”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+79.94703
- 18+78.72861
- 35+77.01033
