681S5W5103L001
681S5W5103L001
    NORCOMP
    5(电源) 位 D-Sub,组合式 插头,公引脚 连接器, 通孔 焊接
681S5W5103L001 数据手册
DESCRIPTION: POWER - VERTICAL BOARD - MALE - MACHINED SPECIFICATIONS: ELECTRICAL: INSULATION RESISTANCE: 2.089 [53.05] Ø 0.120 [3.05] 2-PLACES 1.852 [47.05] 1.533 [38.95] 0.570 [14.48] A1 0.570 [14.48] A3 A2 A4 5 GΩ MIN. 1000 VAC FOR 1 MIN 250V -55°C TO +125°C 1.0 mΩ MAX. 40 AMPS MECHANICAL: CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 4.5 Kg MAX. 0.3 Kg MIN. MATERIALS: CONTACTS: INSULATOR: PBT UL94V-0 RATED SEAL: SHELL: HARDWARE: F08 FLEXIBLE ADHESIVE NICKEL PLATED STEEL NICKEL PLATED BRASS COPPER ALLOY, GOLD FLASH 230°C PROCESS TEMP. A5 0.270 [6.86] 10° 0.492 [12.50] DIELECTRIC WITHSTANDING VOLTAGE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: POWER PINS: 0.330 [8.38] 0.327 [8.30] 0.270 [6.86] 0.240 [6.10] 681S5W5103LYYY 0 = 40 AMP 0.433 [11.00] 0 1 2 3 4 5 0.031 [0.80] SEE SHEET 2 FOR DETAILS 1.496 [38.00] 1 = GOLD FLASH MEETS IP67 STANDARDS 1.618 [41.10] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. = NO HARDWARE = 0.098" CN PCB SIDE = 0.236" CN PCB SIDE = 0.236" CN MATING SIDE = 0.237" BOARDLOCK PCB SIDE = 0.224" BOARDLOCK PCB SIDE (SEE PAGE 2 FOR SEALING DETAILS) UNITS = INCHES [MM] DRAWN: P. JENKINS DATE: 09/13/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 681S5W5103LYYY 2 DESCRIPTION: 681 SERIES CONTACTS NOTE: POWER CONTACTS COME PRE-LOADED INTO INSULATORS 0.209 ± 0.012 [5.30 ± 0.30] 0.031 ± 0.012 [0.80 ± 0.30] A Ø 0.148 [3.75] 0.059 ± 0.012 [1.50 ± 0.30] POWER CONTACTS A 1.852 ± 0.010 [47.05 ± 0.25] 0.926 [23.52] FRONT SEAL APPLIED OVER INSULATOR AND BETWEEN FRONT & REAR SHELLS CL 0.570 [14.48] Ø 0.130 ]3.30] 2-PLACES 0.030 [0.76] 0.330 [8.38] Ø 0.166 [4.22] 5-PLACES DETAIL A-A SHOWN FOR REFERENCE ONLY 0.570 [14.48] 0.270 [6.86] 0.270 [6.86] RECOMMENDED PCB LAYOUT TOLERANCE ± 0.002 [0.05] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES [MM] DRAWN: P. JENKINS DATE: 09/13/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 681S5W5103LYYY 2 DESCRIPTION: CLINCH NUT HARDWARE TOLERANCE: ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS 0 ..... NO HARDWARE 2 ..... 0.236" PCB SIDE 4 ..... 0.237" PCB SIDE 1 ..... 0.098" PCB SIDE 3 ..... 0.236" MATING SIDE 5 ..... 0.224" PCB SIDE RoHS COMPLIANT N C ALL DIMENSIONS ARE ±0.010 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES [MM] DRAWN: P. JENKINS DATE: 09/13/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 681S5W5103LYYY 2
681S5W5103L001 价格&库存
很抱歉,暂时无法提供与“681S5W5103L001”相匹配的价格&库存,您可以联系我们找货
681S5W5103L001
  • 1+140.083901+16.74711
  • 10+121.4219510+14.51606
  • 25+115.0837425+13.75833
  • 50+113.4158850+13.55893
  • 100+100.07358100+11.96385
  • 250+93.40206250+11.16627
  • 450+91.40058450+10.92699
  • 950+86.73051950+10.36868
库存:11
