DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED
1.543 [39.20]
5 GΩ MIN.
250V
-55°C TO +125°C
1.311 [33.30]
1.0 mΩ MAX.
SEE P/N KEY
4-40 THREADED INSERT
2-PLACES
0.994 [25.25]
A1
A2
4.5 Kg MAX.
0.3 Kg MIN.
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
A3
0.327 [8.30]
0.492 [12.50]
230°C PROCESS TEMP.
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
10°
0.240 [6.10]
0.433 [11.00]
0.031 [0.80]
684M3W3K103LYYY
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
M. SIGMON
DATE:
04/19/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
684M3W3K103L461
3
RIGHT ANGLE BRACKET
DIMENSIONS(in/mm)
1.311 [33.30]
OPTION
#4-40 INSERT
P
0.185
46
0.270 [6.86]
4.70
0.270 [6.86]
0.087
Ø0.130 [Ø3.30]
2-PLACES
0.520 [13.20]
62
2.22
0.420 [10.67]
Ø0.165 [4.20]
3-PLACES
0.420 [10.67]
POWER CONTACTS
RECOMMENDED PCB LAYOUT
BOARD EDGE
Ø 0.148 [Ø 3.75]
P
0.520 [13.20]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
04/19/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
684M3W3K103L461
3
很抱歉,暂时无法提供与“684M3W3K103L461”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+125.864231+16.22633
- 10+106.9755210+13.79121
- 25+100.2785625+12.92784
- 70+93.2495570+12.02167
- 140+88.80114140+11.44818
- 280+84.56537280+10.90211
- 560+80.53376560+10.38236
- 1050+77.044671050+9.93255
