684M13W3103L461
684M13W3103L461
    NORCOMP
    13(10 + 3 电源) 位 D-Sub,组合式 插头,公引脚 连接器, 通孔 焊接
684M13W3103L461 数据手册
DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED 5 GΩ MIN. 250V -55°C TO +125°C 2.089 [53.05] 1.0 mΩ MAX. 10 mΩ MAX. 1.852 [47.05] SEE P/N KEY 5 AMPS 1.533 [38.95] 4.5 Kg MAX. 0.3 Kg MIN. 0.492 [12.50] A3 A2 5 4 3 10 9 2 A1 1 8 7 COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED 6 230°C PROCESS TEMP. NICKEL PLATED STEEL NICKEL PLATED STEEL NICKEL PLATED BRASS 10° 0.327 [8.30] 0.240 [6.10] 0.031 [0.80] 684M13W3103LYYY 46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS 62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS SEE SHEET 2 FOR CONTACT & BRACKET DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 = GOLD FLASH UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: P. JENKINS DATE: 08/22/2011 NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 684M13W3103L461 4 DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED RIGHT ANGLE BRACKET 1.852 DIMENSIONS(in/mm) 0.572 OPTION #4-40 INSERT 0.572 Ø0.043 10-PLACES Ø 0.165 3 PLACES S P 0.146 0.185 3.70 4.70 0.087 0.087 2.22 2.22 46 0.307 62 0.109 TYP. Ø0.130 2-PLACES 0.420 [10.67] 0.0545 SIGNAL CONTACTS 0.100 0.520 POWER CONTACTS 0.370 [9.40] PCB EDGE Ø 0.026 [Ø 0.65] 0.420 S Ø 0.148 [Ø 3.75] P 0.370 [9.40] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: P. JENKINS DATE: 08/22/2011 0.520 [13.20] NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 684M13W3103L461 4
684M13W3103L461
1. 物料型号:文档中提到了型号“684M13W3103L461”。
2. 器件简介:该器件是NorComp公司生产的,具有“POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED”的描述,意味着它是一个用于电源或信号传输的直角男性机器加工连接器。
3. 引脚分配:文档中提到了“PCB EDGE”和“#4-40 INSERT”,但没有提供具体的引脚分配图或列表。
4. 参数特性: - 电阻:最小5 GΩ,最大1.0 mΩ。 - 电流:最大5安培。 - 温度范围:-55°C 至 +125°C。 - 重量:最大4.5 Kg,最小0.3 Kg。
5. 功能详解:文档中没有提供详细的功能解释,但根据描述,该连接器适用于电源或信号传输。
6. 应用信息:文档中没有明确提供应用信息,但根据其描述,它可能用于需要直角连接的电源或信号传输场合。
7. 封装信息:文档提供了一些尺寸信息,如“Ø0.130”、“0.572 0.572”、“1.852”等,但没有提供完整的封装信息
684M13W3103L461 价格&库存
很抱歉,暂时无法提供与“684M13W3103L461”相匹配的价格&库存,您可以联系我们找货
684M13W3103L461
