L777HDA26P
L777HDA26P
    ARDUINO
    CONNDSUBHDPLUG26POSSTRSLDR
L777HDA26P 数据手册
HD D-Sub connectors - Stamped and Formed Contacts RIGHT ANGLE HIGH DENSITY CONNECTORS Materials and Platings Shells Insulator Contacts Rear insert Boardlock Screwlock Steel, tin over nickel plating Glass-filled thermoplastic, UL 94V- 0 Brass, selected gold in mating area; 2.54µm (100 µ") min.tin on termination area over 1.27µm (50µ") min.nickel Brass, 2.54µm (100µ") min.nickel plated Phosphor bronze or Brass, 2.54µm (100µ") min.nickel plated Brass, 2.54µm (100µ") min.nickel plated DESCRI PTI ON • Connectors according to: MIL C24308 • UL File: E149426 Economical right angle PCB mount connectors Electrical Data Current rating Voltage rating Withstanding voltage Insulation resistance Contact resistance Amphenol’s high density D-Sub connectors complement Amphenol’s extensive D-Sub connector line. This line offers many superior features, high performance level and low installation cost. The decreased contact spacing accommodates greater signal density in comparison to conventional D-Sub connectors. 3A 250V AC/ rms 50Hz 1000V AC/rms 50Hz for one minute 5000MΩ at 500V DC 10mΩ max Climatic Data Mechanical Data Single contact insertion force Single contact withdrawal force 0.34kg (0.75lb) max. 0.02kg (0.044lb) min. Mating and unmating force Unit: kg ( lb) No. of Cts Mate (max) Unmate (min) 15 3.81 (8.42) 0.52 (1.14) 26 5.95 (13.16) 1.05 (2.32) 44 9.26 (20.46) 1.37 (3.02) 62 13.48 (29.78) 1.76 (3.88) Standard plating thickness • Gold flash • 0.4µm (15µ") Gold • 0.76 µm (30µ") Gold • Industrial • Telecom • Any industry standard I / O connections HD / E19 Operating temperature -55°C to +125°C Salt spray 24 hours APPLI CATI ONS MAI N CHARACTERI STI CS Specifications Plug 6.0 [.236] Socket ' 5.8 [.228] OVERALL DIMENSIONS Shell size dimensions Nb OF DIMENSIONS mm (inch) CONTACTS A B C C' D 15 30.84 (1.214) 24.99 (.984) 16.92 (.661) 16.26 (.640) 2.29 (.090) 26 39.24 (1.545) 33.32 (1.312) 25.25 (.994) 24.56 (.967) 2.29 (.090) 44 53.04 (2.088) 47.04 (1.852) 38.96 (1.534) 38.30 (1.508) 2.29 (.090) 62 69.34 (2.730) 63.50 (2.500) 55.42 (2.182) 54.76 (2.156) 2.41 (.095) B B 24.71 (.973) 0.25 (.010) 0.89 (.035) 0.63 (.025) 22.3 (.878) 23.5 (.925) 24.75 (.974) 62 PIN B B 8.63 (.340) 16.51 (.650) 0.64 (.025) 2.54 (.100) ø3.05 (.120) 2.54 (.100) ø3.05 (.120) ø1.19 (.047) 0.64 (.025) 14.23 (.560) 9.78 (.385) 8.5 (.335) 15.49 (.610) 0.51 (.020) D 2.54 (.100) 0.51 (.020) D 7.37 (.290) ø1.19 (.047) 15 PIN 9.65 (.380) ø1.19 (.047) ø3.05 (.120) 4.33 (.171) 4.83 (.190) 0.59 (.023) 26 PIN 2.54 (.100) D 2.54 (.100) 2.54 (.100) D 23.54 (.927) 2.54 (.100) 5.47 (.215) 15.36 (.605) 2.54 (.100) 3.69 (.145) ø3.05 (.120) ø1.19 (.047) TECHNICAL DATA P.C.B. Layout 16.64 (.655) 44 PIN PCB layout for socket connector, top view Panel mounting option HD / E19 # 4-40 or M3 5.8 (.228) # 4-40 or M3 screwlock Front female screwlock Threaded rear insert 4F / 3F 4R / 3R L ... HD ... ... ... ... ... C309 RoHS Compliant Gold flash 77: tinned shell for receptable 717: tinned shell + dimples for plug 0.4µm (15µ") 177: tinned shell for receptable 777: tinned shell + dimples for plug Series High density valid only for 0.76µm (30µ") part numbers to be written as follow: or 77...................C309 717.................C309 Front mounting option Blank = 3.05mm (.120”) rivet 4R = 4-40 rear insert 4F = 4-40 front screwlock 3R = M3 rear insert 3F = M3 front screwlock C4 Contact type C3 P = Plug S = Socket L 717 HD E15 P D1 CH 4R C309 L 177 HD A26 S D0 CO 3F = Grounding bracket = Grounding bracket + PCB boardlock = Grounding bracket + PCB 4-40 insert = Grounding bracket + PCB M3 insert Footprint option D0 = 1.5mm (.059”) D1 = 8.89mm (.350”) D2 = 5.08mm (.200”) D3 = 2.50mm (.098”) For special request, please consult factory Do not hesitate to contact us for further information Amphenol IT & Communication Products Block A3/A4, The 4th Industrial District of Industrial Headquarters, Dong Keng Road Gong Ming Town, Shen Zhen China Fax:+86(0)755 2754 9955 Technical Support Tel:+86(0)755 2717 7945 Info-dsub@amphenol.com.cn http://www.dsubconnector.com The information given in this document are as a guideline only. We reserve the right to modify our products in any way we deem necessary. Any duplication is prohibited, unless approved in writing. Grounding option CO CH Configuration E15, A26, B44, C62 Examples: Plating option E19/H TECHNI CAL DATA How to order Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Amphenol: L77HDC62SD1CO L77HDE15SD1CO4RC309F L77HDE15SD1CO L77HDB44SD1C4R L77HDD78SD1CH4RC309 L77HDE15SD1CO4F L77HDD78SD1CH4FC309 L77HDD78SD1CO3F L77HDD78SD1CO3FC309 L77HDE15SD1CO4R L77HDE15SD1CO4RC309 L77HDC62SD1CO4R L77HDC62SD1CO4RC309 L77HDD78SD1CH3F L77HDD78SD1CH3FC309 L77HDD78SD1CH3R L77HDD78SD1CH3RC309 L777HDD78PD1CO3R L777HDD78PD1CO4F L777HDD78PD1CO4R L777HDE15PD1CO3F L777HDE15PD1CO3R L777HDE15PD1CO4F L77HDA26SD1CO4F L77HDA26SD1CO4FC309 L77HDA26SD1CO4R L77HDA26SD1CO4RC309 L77HDB44SD1CO3F L777HDD78PD1CO3F L77HDE15SD1CO3RC309 L77HDE15SD1CO4FC309 L77HDA26SD1CO3F L77HDA26SD1CO3FC309 L77HDA26SD1CO3R L77HDA26SD1CO3RC309 L77HDD78SD1CO4FC309 L77HDD78SD1CO4R L77HDD78SD1CO4RC309 L77HDE15SD1CO3F L77HDE15SD1CO3FC309 L77HDE15SD1CO3R L77HDC62SD1CO3RC309 L77HDC62SD1CO4F L77HDC62SD1CO4FC309 L77HDD78SD1CO3R L77HDD78SD1CO3RC309 L77HDD78SD1CO4F L77HDB44SD1CO4FC309 L77HDB44SD1CO4R L77HDB44SD1CO4RC309 L77HDC62SD1CO3F L77HDC62SD1CO3FC309 L77HDC62SD1CO3R L777HDD78PD1CH4R L777HDE15PD1CO4R L77HDB44SD1CO3FC309 L77HDB44SD1CO3R L77HDB44SD1CO3RC309 L77HDB44SD1CO4F L777HDC62PD1CO3R L777HDC62PD1CO4F L777HDC62PD1CO4R L777HDD78PD1CH3F L777HDD78PD1CH3R L777HDD78PD1CH4F L777HDA26PD1CO4R L777HDB44PD1CO3F L777HDB44PD1CO3R L777HDB44PD1CO4F L777HDB44PD1CO4R L777HDC62PD1CO3F L777HDA26PD1CO3F L777HDA26PD1CO3R L777HDA26PD1CO4F
L777HDA26P 价格&库存
很抱歉,暂时无法提供与“L777HDA26P”相匹配的价格&库存,您可以联系我们找货
