L77TWB17W2SP3SY
L77TWB17W2SP3SY
    ARDUINO
    CONNDSUBRCPT17POSVERTSOLDER
L77TWB17W2SP3SY 数据手册
TW Materials and platings Shells Steel-Tin plating Insulators High temperature black thermoplastic Signal contacts Female: machined bronze Material Male: machined brass Plating finish 16µ “Au over 79µ” Ni min. Or 30µ” Au over 79µ” Ni min. Shielded contacts Female: machined bronze Material Male: machined brass Plating Inner conductor 16µ “Au or 30µm Au over 79µ” Ni Outer ring 10µ “Au over 79µ” Ni Terminations Tinned Except solder cup and crimp terminations gold flash Power contacts Female: machined bronze Material Male: machined brass Plating Contacts 16µ “Au or 30µ” Au over 79µ” Ni Terminations Tinned Except solder cup and crimp terminations gold flash Brackets Steel-Tin plating Front jackscrews Brass-Tin plating Rear clinch nuts Brass-Tin plating Boardlocks Bronze-Tin plating Stand-off Brass-Tin plating Electrical Data Current rating Signal contacts 7.5 A. with 10 A. peaks Power contacts PCB terminations 10 to 40 A. Solder cup terminations 10 to 40 A. Crimp terminations 10 to 40 A. Shielded contacts 0.5 A. Voltage rating Signal and power contacts 300 V.R.M.S. at 50 Hz Shielded contacts 150 V.R.M.S. at 50 Hz Shielded contacts Frequency range 0-1 GHz Attenuation 0.2dB V. S. W. R. 1.4(+0.04/GHz) Characteristic impedance 50 Ohms Dielectric withstanding voltage ≥ 1000 V.R.M.S. at 50Hz Insulation resistance ≥ 5000 M Ohms at 500 VDC Contact resistance ≤ 5m Ohms Shell resistance ≤ 1m Ohm (electrical grounding) Climatic Data Operating temperature -55˚C + 155˚C (with peaks up to 180˚C) Damp heat 56 days (40˚C - 95% HR) Salt spray 48 hours Mechanical data Shells With or without dimples Contact retention force in dielectric material > 40N Maximum mating and unmating force With dimples E size = 70 N A size = 80 N B size = 100 N C size = 150 N D size = 180 N Without dimples E size = 30 N A size = 50 N B size = 80 N C size = 120 N D size = 160 N Compatible with process IR - Air convectioned 260˚ for 20 s. Resistance to solder iron heat 260˚C for 30 s. Mating cycles ≥ 200 (classe ll) or 500 (classe l) Blind mating system Available upon request Polarization Available with locking accessories Consult factory Amphenol D’Sub TW Hybrid Series permits a mix of contacts including signal, power, shielded, high voltage and fiber optics in the same housing with 18 different contacts arrangements. This economic series was fist developed from our military series, and has improved features: - new contacts - new high temperature black thermoplastic insert - PCB configurations come preloaded with fixed contacts and brackets. These connectors are supplied with screw machined contacts which are fixed in the insulator. Acomplete range of housings are also available for cable application. A full range of arrangements compatible with reflow process • Commercial • Medical • Industrial • Telecom • Any application requiring optimization of space TW / E1 • Connectors according to: MIL C24308 - NFC93425 - HE507 DESCRIPTION Specifications APPLICATIONS CONTENT Hybrid D’Sub series TECHNICAL DATA Shell and contacts plating CLASS ll 0.4µm (16µ”) Au contacts gold plating 200 mating cycles Types 77 TW 717 TW Shells and plating Tin plated shell *Male and female Tin plated shell with dimples Male only CLASS l 0.76µm (30µ”) Au contacts gold plating 500 mating cycles Types 177 TW 777 TW Shells and plating Tin plated shell *Male and female Tin plated shell with dimples Male only Housing arrangements Male front view Arrangement ...... Shell size ............ 5W1 E 7W2 A 11W1 A Arrangement ...... Shell size ............ 3W3 A 5W5 B 9W4 B Arrangement ...... Shell size ............ 13W3 B 17W2 B 21W1 B Arrangement ...... Shell size ............ 27W2 C 13W6 C 17W5 C Arrangement ...... Shell size ............ 21W4 C 8W8 C 25W3 C Arrangement ...... Shell size ............ 24W7 D 36W4 D 43W2 D 2 F 1.5 10˚ H A B B’ 0.9 J D’ D E G ø 3.1 Shell size Contact P: Pin S: Socket S P A S P B S P C S P D B 0/-0.20 (0/-.008) B‘ +0.20/0 (+.008/0) C D ±0.10 (±.004) 0/-0.25 (0/-.010) 16.8 (.661”) 25.0 30.7 (.984”) 8.0 (1.209”) 16.4 (.315”) (.646”) 25.1 (.988”) 33.3 39.0 (1.311”) 8.0 (1.535”) 24.8 (.315”) (.976”) 38.8 (1.528”) 47.0 52.9 (1.850”) 8.0 (2.083”) 38.5 (.315”) (1.513”) 55.3 (2.177”) 63.5 69.2 (2.500”) 8.0 (2.724”) 54.9 (.315”) (2.161”) 52.7 (2.075”) 61.1 66.8 (2.406”) 10.9 (2.630”) 52.5 (.429”) (2.067”) P E A ±0.25 (±.010) S TECHNICAL DATA Shell size dimensions G D‘ +0.25/0 (+.010/0) 8.2 (.323”) 8.2 (.323”) 8.2 (.323”) 8.2 (.323”) 11.0 (.433”) E ±0.20 (±.008) F F‘ G +0.05/-0.20 +0.10/-0.20 +0.10/-0.20 (+.002/-.008) (+.004/-.008) (+.004/-.008) 12.4 (.488”) 12.4 (.488”) 12.4 (.488”) 12.4 (.488”) 15.2 (.598”) 11.1 (.437) 11.1 (.437) 11.1 (.437) 11.1 (.437) 11.1 (.437) 10.9 (.429”) 10.9 (.429”) 11.0 (.433”) 11.0 (.433”) 11.0 (.433”) 6.2 (.244”) 6.2 (.244”) 6.2 (.244”) 6.2 (.244”) 6.2 (.244”) G‘ J H ±0.10 (±.004) 5.9 (.232”) 5.9 (.232”) 5.8 (.228”) 5.8 (.228”) 5.8 (.228”) 0/-0.50 (0/-.020) +0.10/-0.40 (+.004/-.016) 19.4 11.0 (.764”) (.433”) 27.7 11.0 (1.091”) (.433”) 41.4 11.0 (1.630”) (.433”) 57.9 11.0 (2.280”) (.433”) 55.5 13.8 (2.185”) (.543”) Panel cutouts D E A B 3 C D Mounting method Front Rear Front Rear Front Rear Front Rear Front Rear 10˚ A ±0.20 (±.008) 22.2 (.874”) 20.5 (.807”) 30.5 (1.201”) 28.8 (1.134”) 44.3 (1.744”) 42.5 (1.673”) 60.7 (2.390”) 59.1 (2.327”) 58.3 (2.295”) 56.3 (2.217”) B ±0.20 (±.008) 11.1 (.437”) 10.2 (.402”) 15.3 (.602”) 14.4 (.567”) 22.1 (.870”) 21.3 (.839”) 30.4 (1.197”) 29.5 (1.161”) 29.2 (1.150”) 28.2 (1.110”) 10˚ G H C F D R Rd Rading J C Shell size Standard cutout A B D ±0.20 (±.008) ±0.20 (±.008) 25.0 (.984”) 12.5 (.492”) 33.3 (1.311”) 16.7 (.657”) 47.0 (1.850”) 23.5 (.925”) 63.5 (2.500”) 31.7 (1.248”) 61.1 (2.406”) 30.6 (1.205”) Rd Rading J C E ±0.20 (±.008) 13.0 (.512”) 11.4 (.449”) 13.0 (.512”) 11.4 (.449”) 13.0 (.512”) 11.4 (.449”) 13.0 (.512”) 11.4 (.449”) 15.8 (.622”) 14.1 (.555”) F ±0.20 (±.008) 6.5 (.256”) 5.7 (.224”) 6.5 (.256”) 5.7 (.224”) 6.5 (.256”) 5.7 (.224”) 6.5 (.256”) 5.7 (.224”) 7.9 (.311”) 7.1 (.280”) E G H ±0.20 (±.008) ±0.20 (±.008) 3.0 (.118”) 1.5 (.059”) 3.0 (.118”) 1.5 (.059”) 3.0 (.118”) 1.5 (.059”) 3.0 (.118”) 1.5 (.059”) 3.0 (.118”) 1.5 (.059”) J ±0.20 (±.008) 2.1 (.083”) 3.4 (.0134”) 2.1 (.083”) 3.4 (.0134”) 2.1 (.083”) 3.4 (.0134”) 2.1 (.083”) 3.4 (.0134”) 2.1 (.083”) 3.4 (.0134”) TW / E1 Optimal cutout for rear mounting A B øG TECHNICAL DATA Straight connector footprint 1 2 A 3 A B A B B Signal tail 0.6 mm Dia. (.0236”) 1.6 mm (.063”)PCB For other PCB thickness: consult factory. Dimensions Description Power (.126” tail dia.) 1 Power (.0787” tail dia.) 1 Shielded 3 Signal 2 a 4.80 mm (.198”) 4.80 mm (.198”) 4.00 mm (.157”) 5.00 mm (.196”) b 7.2 mm (.283”) 7.2 mm (.283”) 7.2 mm (.283”) 11.50 mm (.453”) Straight contact combinations Arrangement with signal contacts Arrangement without signal contacts 3W3 - 5W5 - 8W8 See above dimensions Size 8 and 20 Contacts See above dimensions Size 8 Contacts P 3SY Power 3.2 mm DIA. (.126”) (20 to 40 A) and signal P 3Y Power only 3.2 mm DIA. (.126”) (20 to 40 A) P 2SY Power 2 mm DIA. (.0787”) (10 to 20 A) and signal P 2Y Power only 2 mm DIA. (.0787”) (10 to 20 A) CY Shielded only CSY Shielded and signal SY Signal only No reference Signal (Size 20) with solder cup terminations Housing preloaded with contacts 4 1 2 B C 3 B C B C A A Signal tail 0.6 mm Dia. (.0236”) 1.6 mm (.063”) PCB For other PCB thickness: consult factory. Description TECHNICAL DATA Right angle connector footprint A Europe HE 5 pattern = - Europ. height - Europ. footprint pitch between 2 rows: .100” Mix Mixed pattern = - MIL height - Europ. footprint pitch between 2 rows: .100” a b c a - - - b MIL MIL pattern = - MIL height - MIL footprint pitch between 2 rows: .112” c a b c 10.30mm 6.30mm 10.00mm 10.30mm 6.30mm 10.00mm (.406”) (.248”) (.394”) (.406”) (.248”) (.394”) Shielded 1 Signal 2 10.30mm 7.20mm 11.20mm 10.30mm 6.30mm 9.50mm 8.10mm 6.30mm 9.50mm (.406”) (.283”) (.441”) (.406”) (.248”) (.374”) (.319”) (.248”) (.374”) Power (.0787” tail dia.) 3 11.57mm 7.20mm 10.50mm 11.57mm 6.30mm 9.50mm 9.52mm 6.30mm 9.50mm (.456”) (.283”) (.413”) (.456”) (.248”) (.374”) (.375”) (.248”) (.374”) Power (.126” tail dia.) 3 21.46mm 7.20mm 10.50mm 21.46mm 6.30mm 9.50mm 21.46mm 6.30mm 9.50mm (.845”) (.283”) (.413”) (.845”) (.248”) (.374”) (.845”) (.248”) (.374”) Note: above dimensions correpond to sizes E to C. Consult factory for D sizes. Connector comes equiped with contacts and brackets. Right angle contacts combinations 5 Arrangement without signal contacts 3W3 - 5W5 - 8W8 European footprint Mixed footprint MIL (U.S.) footprint Size 8 and 20 Contacts European footprint Mixed footprint MIL (U.S.) footprint Size 8 contacts only EP3SV HP3SV MP3SV Power 3.2 mm DIA. (.126”) (20 to 40 A) and signal EP3V HP3V MP3V Power only 3.2 mm DIA. (.126”) (20 to 40 A) EP2SV HP2SV MP2SV Power 2 mm DIA. (.0787”) (10 to 20 A) and signal EP2V HP2V MP2V Power only 2.0 mm DIA. (.0787”) (10 to 20 A) - HCSV MCSV Shielded and signal - HCV MCV Shielded only ESV HSV MSV Signal only TW / E1 Arrangement with signal contacts Right angle version Connectors come equiped with metal brackets BLANK: 3.10mm (.122”) dia mounting hole RM6: metal brackets + boardlock Metal bracket RM6 Straight version BLANK: 3.10mm (.122”) dia mounting hole RM54: RM5 4.40 threaded RM53: RM5 M3 threaded 1.5 max. (.059 max.) 7.2 (.283) RM5 RM8 RM84: RM8 4.40 threaded RM83: RM8 M3 threaded A514: blind mating system FM: float mounting system ø2.2 (.086) 3.6 max. (.141 max.) + 0.25 3.5 (.137) 19.9 (.783) ø2.25 (.088) ø3 0 (.118) Straight and right angle version 4R: 4.40 rear nut 3R: M3 rear nut 4F: 4.40 front female screwlock 3F: M3 front female screwlock (.1 3.4 34 ) TECHNICAL DATA Mounting options 7.1 9) 7 (.2 6 TECHNICAL DATA 4.80 (.189”) 5.20 (.205”) 5.20 (.205”) 4.80 (.189”) High power contacts 22 (.866”) øA 22 (.866”) øA øB P/N Plug øB 16 (.622”) Solder cup version Current Socket Dimensions A mm (inch) B mm (inch) L 17DM 53745-8 L 17DM 53744-7 10 to 20 Amp. 1.80 (.071”) 2.55 (.100”) L 17DM 53745-7 L 17DM 53744-6 20 to 30 Amp. 2.80 (.110”) 3.70 (.145”) L 17DM 53745-1 L 17DM 53744-1 30 to 40 Amp. 4.80 (.189”) 5.60 (.220”) Trim dimensions: 7.5 mm (.295”) Crimp version Plug P/N øA øB Socket Current Dimensions A mm (inch) B mm (inch) L 17DM 53745-208 L 17DM 53744-207 10 to 20 Amp. 1.80 (.071”) 2.55 (.100”) L 17DM 53745-207 L 17DM 53744-206 20 to 30 Amp. 2.80 (.110”) 3.70 (.145”) L 17DM 53745-201 L 17DM 53744-201 30 to 40 Amp. 4.80 (.189”) 5.60 (.220”) Trim dimensions: 7.5 mm (.295”) Crimping tool for all sizes L17D479SP 7 Extraction tool for sizes 8 cts TW / E1 22 (.866”) øA 16 (.622”) øB 22 (.866”) TECHNICAL DATA Straight shielded contacts Crimp ferrule and inner solder A B øD B øD F Type P/N plug plug plug plug socket socket socket socket L17DM 53740 L17DM 53740-1 L17DM 53740-3 L17DM 53740-5 L17DM 53742 L17DM 53742-1 L17DM 53742-3 L17DM 53742-5 Cable - RG Dimensions (inch) B D A Max 178 B/U 18.8 (740”) 23.6 (.929”) 1.0 (.039”) 18.8 (740”) 23.6 (.929”) 1.7 (.066”) 179 B/U 316 B/U 180 B/U 21.5 (846”) 23.6 (.929”) 2.8 (.110”) 58 C/U 21.5 (846”) 23.6 (.929”) 3.2 (.126”) 178 B/U 18.8 (740”) 23.6 (.929”) 1.0 (.039”) 18.8 (740”) 23.6 (.929”) 1.7 (.066”) 179 B/U 316 B/U 180 B/U 21.5 (846”) 23.6 (.929”) 2.8 (.110”) 58 C/U 21.5 (846”) 23.6 (.929”) 3.2 (.126”) E G Trim dimensions (inch) F G E 7.9 (.311”) 6.3 (.248”) 2 (.078”) 7.9 (.311”) 6.3 (.248”) 2 (.078”) 9.5 (.374”) 7.9 (.311”) 2 (.078”) 9.5 (.374”) 7.9 (.311”) 2 (.078”) 7.9 (.311”) 6.3 (.248”) 2 (.078”) 7.9 (.311”) 6.3 (.248”) 2 (.078”) 9.5 (.374”) 7.9 (.311”) 2 (.078”) 9.5 (.374”) 7.9 (.311”) 2 (.078”) Ferrule and inner solder A B øD B øD F Type P/N Dimensions (inch) Cable - RG A Max B D short plug L17DM 53740-5000 17.0 (669”) 21.8 (.858”) 1.0 (.039”) 178 B/U plug L17DM 53740-5001 18.8 (740”) 23.6 (.929”) 1.7 (.066”) 179 B/U 316 B/U plug L17DM 53740-5002 21.5 (846”) 26.3 (1.035”) 2.8 (.110”) 180 B/U plug L17DM 53740-5005 21.5 (846”) 26.3 (1.035”) 3.2 (.126”) 58 C/U plug L17DM 53740-5008 18.8 (740”) 23.6 (.929”) 1.0 (.039”) 178 B/U short socket L17DM 53742-5000 17.0 (669”) 21.8 (.858”) 1.0 (.039”) 178 B/U socket L17DM 53742-5001 18.8 (740”) 23.6 (.929”) 1.7 (.066”) 179 B/U 316 B/U socket L17DM 53742-5002 21.5 (846”) 26.3 (1.035”) 2.8 (.110”) 180 B/U socket L17DM 53742-5004 21.5 (846”) 26.3 (1.035”) 3.2 (.126”) 58 C/U socket L17DM 53742-50060 18.8 (740”) 23.6 (.929”) 1.0 (.039”) 178 B/U E G Trim dimensions (inch) E F G 7.9 (.311”) 6.3 (.248”) 2 (.078”) 7.9 (.311”) 6.3 (.248”) 2 (.078”) 9.5 (.374”) 7.9 (.311”) 2 (.078”) 9.5 (.374”) 7.9 (.311”) 2 (.078”) 7.9 (.311”) 6.3 (.248”) 2 (.078”) 7.9 (.311”) 6.3 (.248”) 2 (.078”) 7.9 (.311”) 6.3 (.248”) 2 (.078”) 9.5 (.374”) 7.9 (.311”) 2 (.078”) 9.5 (.374”) 7.9 (.311”) 2 (.078”) 7.9 (.311”) 6.3 (.248”) 2 (.078”) 8 TECHNICAL DATA Right angled shielded contact Crimp ferrule and inner solder A F E G A Type P/N plug plug plug plug socket socket socket socket L17DM 53741 L17DM 53741-1 L17DM 53741-3 L17DM 53741-4 L17DM 53743-2 L17DM 53743-3 L17DM 53743-5 L17DM 53743-6 Cable - RG Dimensions (inch) Trim dimensions (inch) G A Max B D E F 13.5 (.531”) 18.6 (.732”) 1.0 (.039”) 178 B/U 9.5 (.374”) 5.9 (.232”) 1.6 (.062”) 13.5 (.531”) 18.6 (.732”) 1.7 (.066”) 179 B/U 316 B/U 9.5 (.374”) 5.9 (.232”) 1.6 (.062”) 13.5 (.531”) 18.6 (.732”) 2.8 (.110”) 180 B/U 10.7 (.421”) 7.9 (.311”) 2.4 (.094”) 13.5 (.531”) 18.6 (.732”) 3.2 (.126”) 58 C/U 10.7 (.421”) 7.9 (.311”) 2.4 (.094”) 13.5 (.531”) 18.6 (.732”) 1.0 (.039”) 178 B/U 9.5 (.374”) 5.9 (.232”) 1.6 (.062”) 13.5 (.531”) 18.6 (.732”) 1.7 (.066”) 179 B/U 316 B/U 9.5 (.374”) 5.9 (.232”) 1.6 (.062”) 10.7 (.421”) 7.9 (.311”) 2.4 (.094”) 13.5 (.531”) 18.6 (.732”) 2.8 (.110”) 180 B/U 10.7 (.421”) 7.9 (.311”) 2.4 (.094”) 13.5 (.531”) 18.6 (.732”) 3.2 (.126”) 58 C/U Ferrule and inner solder B B C F E G C øD Type P/N plug plug plug plug socket socket socket socket L17DM 53741-5000 L17DM 53741-5001 L17DM 53741-5003 L17DM 53741-5004 L17DM 53743-5000 L17DM 53743-5001 L17DM 53743-5003 L17DM 53743-5004 øD Dimensions (inch) D Cable - RG A Max B 178 B/U 13.5 (.531”) 18.6 (.732”) 1.0 (.039”) 13.5 (.531”) 18.6 (.732”) 1.7 (.066”) 179 B/U 316 B/U 180 B/U 13.5 (.531”) 18.6 (.732”) 2.8 (.110”) 58 C/U 13.5 (.531”) 18.6 (.732”) 3.2 (.126”) 178 B/U 13.5 (.531”) 18.6 (.732”) 1.0 (.039”) 13.5 (.531”) 18.6 (.732”) 1.7 (.066”) 179 B/U 316 B/U 180 B/U 13.5 (.531”) 18.6 (.732”) 2.8 (.110”) 58 C/U 13.5 (.531”) 18.6 (.732”) 3.2 (.126”) Trim dimensions (inch) F E G 9.5 (.374”) 5.9 (.232”) 1.6 (.062”) 9.5 (.374”) 5.9 (.232”) 1.6 (.062”) 10.7 (.421”) 7.9 (.311”) 2.4 (.094”) 10.7 (.421”) 7.9 (.311”) 2.4 (.094”) 9.5 (.374”) 5.9 (.232”) 1.6 (.062”) 9.5 (.374”) 5.9 (.232”) 1.6 (.062”) 10.7 (.421”) 7.9 (.311”) 2.4 (.094”) 10.7 (.421”) 7.9 (.311”) 2.4 (.094”) Crimping tool 9 RG cables MIL reference Amphenol P/N RG 58 C/U RG 178 B/U RG 179 B/U RG 180 B/U M 22 520/5-05 M 22 520/5-03 M 22 520/5-03 M 22 520/5-05 227 1221-05 227 1221-03 227 1221-03 227 1221-05 Extraction tool Extraction tool for sizes 8 cts L17D429SP dim. between 2 flat surface cavity A cavity B 5.41 2.67 3.25 4.52 TW / E1 Hand crimp tool 227-0944 (without dies) (M 22 520/5-01) ASSEMBLY INSTRUCTIONS Cabling instructions for shielded contacts Straight crimp shielded contacts: inner solder contact outer crimp contact soft solder outer ring coaxial shell outer ring braided shield crimp 3.20 inner sleeve Right angle crimp shielded contacts: inner solder contact outer crimp contact inner sleeve coaxial shell outer ring outer ring soft solder crimp 3.20 soft solder cap into shell after cable assembly on 90˚ type coaxes Assembly method - Slide the outer ring over the cable jacket. Trim the cable according to the recommended dimensions. - Insert the cable dielectric and the center conductor inside the inner sleeve. - Solder the central conductor to the shielded center contacts. - Slide the outer ring towards the inner sleeve ans recover the braid. - Using crimp hand tool equipped with the appropriate dies, crimp in the area defined. Solder straight shielded contacts: soft solder outer ring outer ring braided shield inner sleeve coaxial shell solder Solder right angle shielded contacts: inner sleeve outer ring coaxial shell outer ring solder soft solder soft solder cap into shell after cable assembly on 90˚ type coaxes Assembly method - Slide the outer ring over the cable jacket. Trim the cable according to the recommended dimensions. - Insert the cable dielectric and the center conductor inside the inner sleeve. - Solder the central conductor to the shielded center contacts. - Slide the outer ring towards the inner sleeve ans recover the braid. - Solder by introducing metal through the outer ring hole. 10 ... TW ... ... ... ... ... ... RoHS Compliant Contacts and Shell Contact Plating 0.4µm(16µ”) Au 0.76µm(30µ”) Au Tinned 77 177 Shell Tinned & Indents; Plug only 717 777 Shell size and Configuration: E5W1, A3W3, A7W2, A11W1, B5W5, B9W4, B13W3, B17W2, B21W1, C8W8, C13W6, C17W5, C21WA4 C25W3, C27W2, D24W7, D36W4, D43W2 Gender: P: Pin S: Socket Contacts: For straight BLANK: Solder-cup signal contacts only P3SY: 20-40 Amp power & signal mix P2SY: 10-20 Amp power & signal mix CSY: Coax & signal mix SY: Signal only P3Y: 20-40 Amp power only (3W3, 5W5, 8W8) P2Y: 10-20 Amp power only (3W3, 5W5, 8W8) CY: Coax only (3W3, 5W5, 8W8) For right angle MP3SV: US Footprint, 20-40 Amp power & signal mix MP2SV: US Footprint, 10-20 Amp power & signal mix MCSV: US Footprint, Coax & signal mix MSV: US Footprint, Signal only MP3V: US Footprint, 20-40 Amp power only (3W3, 5W5, 8W8) MP2V: US Footprint, 10-20 Amp power only (3W3, 5W5, 8W8) MCV: US Footprint, Coax only (3W3, 5W5, 8W8) EP3SV: European Footprint, 20-40 Amp power & signal mix EP2SV: European Footprint, 10-20 Amp power & signal mix ESV: European Footprint, Signal only EP3V: European Footprint, 20-40 Amp power only (3W3, 5W5, 8W8) EP2V: European Footprint, 10-20 Amp power only (3W3, 5W5, 8W8) HP3SV: Mixed Footprint, 20-40 Amp power & signal mix HP2SV: Mixed Footprint, 10-20 Amp power & signal mix HCSV: Mixed Footprint, Coax & signal mix HSV: Mixed Footprint, Signal only HP3V: Mixed Footprint, 20-40 Amp power only (3W3, 5W5, 8W8) HP2V: Mixed Footprint, 10-20 Amp power only (3W3, 5W5, 8W8) HCV: Mixed Footprint, Coax only (3W3, 5W5, 8W8) 11 Special Deviations Please consult factory Board Mounting Options For Straight Blank: .120”(3.05mm) Clear Hole RM53: M3 Threaded (panel side) standoff with boarlock RM54: 4-40UNC Threaded (panel side) standoff with boardlock RM84: Non-Removable M3 screwlock, with standoff and boardlock For Right Angle RM6: Metal bracket with boardlocks Panel Mounting Options For right angle & cable mount Blank: .120”(3.05mm) Clear Hole 3F: M3 Front Screwlock 3R: M3 Rear Threaded Insert 4F: #4-40 Front Screwlock 4R: #4-40 Threaded Rear Insert FM: Float mount system A514: Blind Mate Guide Pin TW / E1 L HOW TO ORDER How to build your part number Amphenol IT & Communication Products Block A3/A4, The 4th Industrial District of Industrial Headquarters, Dong Keng Road Gong Ming Town, Shen Zhen China Fax:+86(0)755 2754 9955 Technical Support Tel:+86(0)755 2717 7945 Info-dsub@amphenol.com.cn http://www.dsubconnector.com The information given in this document are as a guideline only. We reserve the right to modify our products in any way we deem necessary. Any duplication is prohibited, unless approved in writing. Do not hesitate to contact us for further information E13/B NOTES Memo 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Amphenol: L77TWB17W2SHP3SVRM6 L77TWC8W8SMP2V4R L77TWC21WA4SCSYRM54A514 L77TWB17W2SHCSV L77TWE5W1SMP2SV L77TWP2W2SC770 L77TWP3W3SC702 L77TWA11W1SMCSVRM6 L77TWA3W3PMP3V4RRM6 L77TWA3W3SEP2V4RRM6 L77TWA3W3SEP2VRM6 L77TWA3W3SFM L77TWA3W3SHP3V4FRM6 L77TWA3W3SMCV4FRM6 L77TWA3W3SMCV4RRM6 L77TWA3W3SP2Y4R L77TWA7W2SEP2SV4RRM6 L77TWA7W2SESV L77TWA7W2SHCSV L77TWA7W2SMCSV4RRM6 L77TWA7W2SMP2SV4R L77TWA7W2SMP2SVRM6 L77TWA7W2SMP3SV4RRM6 L77TWA7W2SMSV4RRM6 L77TWA7W2SP3SYRM84 L77TWA7W2SSY L77TWA7W2SSYRM54 L77TWAH3W3S L77TWB13W3S4R L77TWB13W3SEP2SV4RRM6 L77TWB13W3SEP2SVRM6 L77TWB13W3SHCSV4F L77TWB13W3SHCSVRM6 L77TWB13W3SMCSV4F L77TWB13W3SP2SY L77TWB13W3SP2SY4R L77TWB13W3SP3SY L77TWB17W2SESV3FRM6 L77TWB17W2SMCSV4FRM6 L77TWB17W2SMCSVRM6 L77TWB17W2SMP2SV4FRM6 L77TWB17W2SMP3SV4RRM6 L77TWB17W2SMSV4RRM6 L77TWB17W2SMSVRM6 L77TWB17W2SP2SYRM54 L77TWB21W1P L77TWB21W1PHCSV L77TWB21W1PHSV4RRM6 L77TWB21W1SFM L77TWB21W1SP3SY L77TWB5W5SEP2VRM6 L77TWB5W5SHCV4FRM6 L77TWB5W5SMCV4RRM6 L77TWB5W5SMP2VRM6 L77TWB5W5SMP3V4R L77TWB5W5SMP3V4RRM6 L77TWB5W5SP2Y4R L77TWB5W5SP3Y4R L77TWB9W4SEP2SVRM6 L77TWB9W4SMCSV4R L77TWB9W4SP2SY3R L77TWB9W4SP2SYRM53 L77TWB9W4SP2SYRM84 L77TWB9W4SP3SYRM54 L77TWBF21W1S L77TWBF21W1SOL3 L77TWBF5W5S L77TWBH5W5S L77TWC13W6SHCSV4RRM6 L77TWC13W6SMCSV L77TWC13W6SMCSV4RRM6 L77TWC13W6SP2SY L77TWC13W6SSY L77TWC17W5SP2SY4R L77TWC17W5SP2SYRM84 L77TWC17W5SSYRM54 L77TWC21WA4SEP2SV4RRM6 L77TWC21WA4SMCSVRM6 L77TWC21WA4SMP3SV L77TWC21WA4SMP3SV4FRM6 L77TWC21WA4SMP3SV4R L77TWC21WA4SMP3SV4RRM6 L77TWC21WA4SP3SYRM84 L77TWC21WA4SSY L77TWC25W3S L77TWC25W3S4F L77TWC25W3SEP2SV4RRM6 L77TWC25W3SMSV4R L77TWC25W3SSY L77TWC27W2SFM L77TWC27W2SMP3SV4FRM6 L77TWC27W2SMP3SV4R L77TWC27W2SSYFM L77TWC8W8SFM L77TWC8W8SHCV3RRM6 L77TWC8W8SMCV4FRM6 L77TWC8W8SMCV4R L77TWC8W8SMCVRM6 L77TWC8W8SP3Y L77TWC8W8SRM84
L77TWB17W2SP3SY 价格&库存
很抱歉,暂时无法提供与“L77TWB17W2SP3SY”相匹配的价格&库存,您可以联系我们找货
