DCDM-51P6E5-36.0K
DCDM-51P6E5-36.0K
    CINCH
    MICRO 51 P 36" RBW JACKS
DCDM-51P6E5-36.0K 数据手册
DURA-CON All-Plastic Strip Connectors Metal Shell Mil-C-83513 Connectors Terminal Blocks Microedge .050" D-microminiature Dura-Con Introduction Cinch Dura-ConTM connectors are designed for applications that require a rugged, durable, and high-performance interconnect. Dura-Con is the ideal connector for applications where weight and space must be kept to a minimum while maintaining maximum reliability. Miniaturized airborne electronics and data processing equipment, where shorter signal paths are needed, represent typical applications for these unique connectors. The heart of the Dura-Con system is the Dura-Con pin contact. The Cinch Dura-Con pin contact is made from a precision miniature spring cable with a welded tip. The expanded cable provides seven spring members peripherally around the pin so that contact is maintained with the mating socket wall no matter what radial forces are applied. This spring may be flexed many times without any evidence of metal fatigue. Reliable mating is further ensured by protecting the pin contact in a tightly toleranced recessed cavity. Cinch’s family of Dura-Con connectors includes MIL-C-83513 Series connectors along with our own commercial equivalents. The commercial Dura-Con product line offers an expanded range of termination and hardware options for all-plastic and metal shell wire versions and right-angle and straight PC board mount “terminal blocks”. Cinch also packages the Dura-Con contact in a very low profile plastic strip connector on .050" centers and in a line of high-density microminiature edge (Microedge) board connectors that meet the requirements of MIL-C-55302. Cinch has created a line of plastic and metal shell Dura-Con connector savers for very high mating cycle applications such as test equipment. Termination Options: Cinch offers the following termination methods for its Dura-Con connectors: Insulated Wire - Insulated wire is crimped to the Dura-Con contacts then epoxy backpotted at the factory. Wire is available in standard lengths of 18, 24, 36, and 48 inches. Uninsulated Wire - 24 AWG, gold-plated, uninsulated wire is crimped to the Dura-Con contact at the factory. Wire is available in standard lengths of 0.5, 1.0, and 2.0 inches. This option allows the user greater flexibility when installing the connector. Solder Cup - For applications that require the lowest contact resistance, Cinch offers Dura-Con connectors with solder cups for termination by the user. 5 Dura-Con is a trademark of Cinch Connectors. 5-1 Call Toll Free: 1 (800) 323-9612 Dura-Con Introduction Custom Capabilities: Standard Cinch Dura-Con connectors satisfy a wide variety of applications. Cinch’s line of Dura-Con D-microminiature connectors is one of the most versatile in the industry. There are over 50,000 possible combinations of Cinch standard options such as connector type, size, materials, hardware, and termination. When special application requirements arise, Cinch Dura-Con connectors take this versatility to the next level. Whether specific needs entail new variations of simple end-to-end connector assemblies or more complex and intricate harness assemblies, Cinch Connector Division has the state-of-the-art engineering resources and research facilities in place to meet your needs. Cinch approaches your business with a well-defined goal: to ensure the integrity of your design and to execute our contribution to it in a responsible, cost-effective manner. This philosophy has led Cinch to a position of industry leadership. For complete information regarding the total capabilities of the Dura-Con connector series, or for custom application assistance, contact your nearest Cinch Connectors sales office. 5 Call Toll Free: 1 (800) 323-9612 5-2 Dura-Con High Reliability All-Plastic .050" (1.27mm) Density Solder Cup/Wire D-Microminiature ■ Both plug and socket available in 9, 15, 21, 25, 31, 37, and 51 positions. FEATURES ■ Termination styles - solder cup, gold-plated solid wire, and insulated stranded wire. ■ Several styles of mounting hardware are available for cable-to-cable, cable-to-board mount, and cable-to-panel mount applications. ■ High-performance Dura-Con twist-pin contact. ■ Economical all-plastic shell for lightweight applications where no shielding is required. MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS ■ Meets requirements of MIL-C-83513 except where noted. Insulator: UL94V-0 rated glass-filled polyester Contacts: Pins - Copper alloy, Sockets - Copper alloy (machined) Contact Plating: .000050 in gold Operating Temperature: -55° C to +135° C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level 8 milliohms maximum change Individual Contact: 6 oz. (170.40 g) maximum insertion; 0.5 oz. (14.20 g) minimum withdrawal Mating / Unmating Force: See table Call Toll Free: 1 (800) 323-9612 5-4 No. of Contacts 9 15 21 25 31 37 51 Maximum Mating Force Lb. Kg 5.63 2.56 9.38 4.26 13.13 5.96 15.63 7.10 19.38 8.80 23.13 10.50 31.88 14.47 Minimum Unmating Force Lb. Kg .28 .13 .47 .21 .66 .30 .78 .35 .97 .44 1.16 .53 1.59 .72 Dura-Con High Reliability All-Plastic .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Contact Arrangements (Face view of pin insulator) (Use reverse order for socket) Ordering Information DC D A 37 P 6 E 2 -18.0 K Cinch Dura-Con D Connector Mounting Hardware** B = No Hardware F = Float Mount R = Reverse Float Mount K = Jackscrew (Standard) L = Jackscrew (Low Profile) P = Jackpost, MIL-C-83513/5-07 Insulator Type *D = Thermoplastic Glass Reinforced Mounting Type *A = Screw Mount Flange Lead Length in inches*** 00.5 Solid copper wire only 01.0 Solid copper wire only 02.0 Solid copper wire only 18.0 Stranded wire only 24.0 Stranded wire only 36.0 Stranded wire only 48.0 Stranded wire only No. of Contacts 9, 15, 21, 25, 31, 37, 51 Contact Type P – Pin (Plug) S – Socket (Receptacle) Wire Size in AWG 5 = 25 AWG Solid Copper 6 = 26 AWG Stranded S = Solder Cup (Skip to Mounting Hardware) Insulation Color or Wire Finish 1 = White *2 = Yellow (Stranded Wire) 3 = Tin-Plated *4 = Gold-Plated (Solid Wire Only) *5 = Color Coded Per MIL-Std. (681) System 1. (Stranded Wire Only) Wire Type E = MIL-W-16878/4, 7 Strand C = Solid Copper - Uninsulated (Consult factory for non-standard wire types) * - Indicates Cinch std. option. ** - See p. 5-12 for std. hardware dims. See p. 5-13 for non-std. hardware & p. 5-31 for Mil spec. hardware both sold separately. ***- Length Tolerance: solid wire = ± 3/32”, standard wire = ± 1/4”. 5-5 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability All-Plastic .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Connector Dimensions - Plastic Shell Plug Socket 5 A No. of Contacts B Max. + .010 (.254) in mm in D E +.005 (.127) in mm F Max. +.010 (.254) in mm in mm 7.42 .398 10.11 .565 14.35 .208 5.28 .173 4.39 .376 9.55 .398 10.11 .565 14.35 .208 5.28 .173 4.39 .442 11.23 .548 13.92 .715 18.16 .208 5.28 .173 4.39 23.57 .526 13.36 .548 13.92 .715 18.16 .208 5.28 .173 4.39 1.078 27.38 .592 15.04 .698 17.73 .865 21.97 .208 5.28 .173 4.39 21 Socket 1.078 27.38 .676 17.17 .698 17.73 .865 21.97 .208 5.28 .173 4.39 25 Plug 1.178 29.92 .692 17.58 .798 20.27 .965 24.51 .208 5.28 .173 4.39 25 Socket 1.178 29.92 .776 19.71 .798 20.27 .965 24.51 .208 5.28 .173 4.39 31 Plug 1.328 33.73 .842 21.39 .948 24.08 1.115 28.32 .208 5.28 .173 4.39 31 Socket 1.328 33.73 .926 23.52 .948 24.08 1.115 28.32 .208 5.28 .173 4.39 37 Plug 1.478 37.54 .992 25.20 1.098 27.89 1.265* 32.13 .208 5.28 .173 4.39 37 Socket 1.478 37.54 1.076 27.33 1.098 27.89 1.265* 32.13 .208 5.28 .173 4.39 51 Plug 1.428 36.27 .942 23.93 1.048 26.62 1.215 30.86 .250 6.35 .220 5.59 51 Socket 1.428 36.27 1.026 26.06 1.048 26.62 1.215 30.86 .250 6.35 .220 5.59 9 Plug .778 19.76 .292 9 Socket .778 19.76 15 Plug .928 23.57 15 Socket .928 21 Plug Call Toll Free: 1 (800) 323-9612 mm C +.010 (.254) -.018 (.457) in mm 5-6 Dura-Con High Reliability All-Plastic .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Panel Mounting Dimensions Panel Cutout Dimensions Figure 1. Front Mounting Figure 3. Edgeboard Mounting Figure 2. Rear Mounting A No. of Contacts 9 15 21 25 31 37 51 Figure Number 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 +.004 -.000 in .408 .373 .558 .523 .708 .674 .808 .774 .958 .924 1.108 1.074 1.058 1.024 - B (.101) (.000) mm 10.36 9.47 14.17 13.28 17.98 17.12 20.52 19.66 24.33 23.47 28.14 27.28 26.87 26.01 - 5-7 +.004 -.000 in .172 .216 .172 .216 .172 .216 .172 .216 .172 .216 .172 .216 .215 .259 - C (.101) (.000) mm 4.37 5.49 4.37 5.49 4.37 5.49 4.37 5.49 4.37 5.49 4.37 5.49 5.46 6.58 - +.005 -.000 in .570 .570 .570 .720 .720 .720 .870 .870 .870 .970 .970 .970 1.120 1.120 1.120 1.270 1.270 1.270 1.220 1.220 1.220 (.127) (.000) mm 14.48 14.48 14.48 18.29 18.29 18.29 22.10 22.10 22.10 24.64 24.64 24.64 28.45 28.45 28.45 32.26 32.26 32.26 30.99 30.99 30.99 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density Solder Cup/Wire D-Microminiature ■ Both plug and socket available in 9, 15, 21, 25, 31, 37, 51, and 100 positions. FEATURES ■ Several styles of mounting are available for cable-to-cable, cable-to-panel mount, and cable-to-board mount. ■ Aluminum shell provides extra strength and EMI/RFI shielding capability. Plating options available. ■ Silicone elastomer compression interfacial seal protects contacts from moisture and humidity and isolates contacts from each other and the metal shell. ■ Meets requirements of MIL-C-83513 except where noted. ■ Rugged twist-pin contacts resistant to shock and vibration make metal shell Dura-Con an excellent choice for harsh environments such as airborne or space applications. MATERIALS Insulator: UL94V-0 rated glass-filled polyester or diallyl phthalate Contacts: Pins - Copper alloy, Sockets - Copper alloy (machined) Contact Plating: .000050 in gold Shell: Aluminum alloy Shell Plating: Yellow chromate over cadmium (std.) or MECHANICAL ELECTRICAL ENVIRONMENTAL electroless nickel Operating Temperature: -55°C to +135°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level 8 milliohms maximum Individual Contact: 6 oz. (170.40 g) maximum insertion; 0.5 oz. (14.20 g) minimum withdrawal Mating / Unmating Force: See table Call Toll Free: 1 (800) 323-9612 5-8 No. of Contacts 9 15 21 25 31 37 51 100 Maximum Mating Force Lb. Kg 5.63 2.56 9.38 4.26 13.13 5.96 15.63 7.10 19.38 8.80 23.13 10.50 31.88 14.47 62.50 28.38 Minimum Unmating Force Lb. Kg .28 .13 .47 .21 .66 .30 .78 .35 .97 .44 1.16 .53 1.59 .72 3.13 1.42 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Contact Arrangements (Face view of pin insert) (Use reverse order for socket side) Ordering Information DC D M 37 P 6 E 2-18.0 K N Cinch Dura-Con D Connector Shell Plating *No Letter = Yellow Chromate over Cadmium N = Electroless Nickel Insulator Type C = Diallyl Phthalate Glass-Reinforced D = Thermoplastic Glass-Reinforced Mounting Hardware** B = No Hardware F = Float Mount R = Reverse Float Mount K = Jackscrew (Standard) L = Jackscrew (Low Profile) P = Jackpost, Size 9 through 51 MIL-C-83513/5-07 Size 100 MIL-C-83513/5-17 Mounting Type M = Screw Mount Metal Shell No. of Contacts 9, 15, 21, 25, 31, 37, 51, 100 Contact Type P = Pin (Plug) S = Socket (Receptacle) Lead Length in inches*** 00.5 Solid copper wire only 01.0 Solid copper wire only 02.0 Solid copper wire only 18.0 Stranded wire only 24.0 Stranded wire only 36.0 Stranded wire only 48.0 Stranded wire only Wire Size in AWG 5 = 25 AWG Solid Copper 6 = 26 AWG Stranded S = Solder cup (Skip to Mounting Hardware) Insulation Color or Wire Finish 1 = White *2 = Yellow (Stranded Wire) 3 = Tin-Plated *4 = Gold-Plated (Solid Wire) *5 = Color Coded Per MIL-Std. 681, System 1. (Stranded Wire Only) Wire Type C = Solid Copper (Uninsulated) E = MIL-W-16878/4, 7 Strand (Consult factory for non-standard wire types) * - Indicates Cinch std. option. ** - See p. 5-12 for std. hardware dims. See p. 5-13 for non-std. hardware & p. 5-31 for Mil spec. hardware both sold separately. ***- Length Tolerance: solid wire = ± 3/32”, standard wire = ± 1/4”. 5-9 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Connector Dimensions - Metal Shell Plug Socket A 5 B Max. No. of Contacts 9 Plug + .010 (.254) in mm .775 19.68 in .333 mm 8.46 C +.010 (.254) -.018 (.457) in mm .390 9.91 9 Socket .775 19.68 .396 10.06 .390 9.91 .565 14.35 .298 7.57 .270 6.86 15 Plug .925 23.50 .483 12.27 .540 13.72 .715 18.16 .298 7.57 .270 6.86 15 Socket .925 23.50 .546 13.87 .540 13.72 .715 18.16 .298 7.57 .270 6.86 21 Plug 1.075 27.30 .633 16.08 .690 17.53 .865 21.97 .298 7.57 .270 6.86 21 Socket 1.075 27.30 .696 17.68 .690 17.53 .865 21.97 .298 7.57 .270 6.86 25 Plug 1.175 29.84 .733 18.62 .790 20.07 .965 24.51 .298 7.57 .270 6.86 25 Socket 1.175 29.84 .796 20.22 .790 20.07 .965 24.51 .298 7.57 .270 6.86 31 Plug 1.325 33.66 .883 21.16 .940 23.88 1.115 28.32 .298 7.57 .270 6.86 31 Socket 1.325 33.66 .946 24.03 .940 23.88 1.115 28.32 .298 7.57 .270 6.86 37 Plug 1.475 37.46 1.033 26.24 1.090 27.69 1.265 32.13 .298 7.57 .270 6.86 37 Socket 1.475 37.46 1.096 27.84 1.090 27.69 1.265 32.13 .298 7.57 .270 6.86 51 Plug 1.425 36.20 .983 24.97 1.040 26.42 1.215 30.86 .341 8.66 .310 7.87 51 Socket 1.425 36.20 1.046 26.57 1.040 26.42 1.215 30.86 .341 8.66 .310 7.87 100 Plug 2.160 54.86 1.383 35.13 1.432 36.38 1.800 45.71 .384 9.75 .360 9.15 100 Socket 2.160 54.86 1.446 36.73 1.432 36.38 1.800 45.71 .384 9.75 .360 9.15 Call Toll Free: 1 (800) 323-9612 5-10 D E F Max. + .005 (.127) in mm .565 14.35 + .010 (.254) in mm .298 7.57 in .270 mm 6.86 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Panel Mounting Dimensions Panel Cutout Dimensions A No. of Contacts 9 15 21 25 31 37 51 100 Figure Number 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 +.004 -.000 in .408 .408 .558 .558 .708 .708 .808 .808 .958 .958 1.108 1.108 1.058 1.058 1.450 1.562 - B (.101) (.000) mm 10.36 10.36 14.17 14.17 17.98 17.98 20.52 20.52 24.33 24.33 28.14 28.14 26.87 26.87 36.84 39.68 - +.004 -.000 in .270 .256 .270 .256 .270 .256 .270 .256 .270 .256 .270 .256 .315 .300 .361 .338 - 5-11 C (.101) (.000) mm 6.86 6.50 6.86 6.50 6.86 6.50 6.86 6.50 6.86 6.50 6.86 6.50 8.00 7.62 9.17 8.58 - +.005 -.000 in .570 .570 .570 .720 .720 .720 .870 .870 .870 .970 .970 .970 1.120 1.120 1.120 1.270 1.270 1.270 1.220 1.220 1.220 1.805 1.805 1.805 D (.127) (.000) mm 14.48 14.48 14.48 18.29 18.29 18.29 22.10 22.10 22.10 24.64 24.64 24.64 28.45 28.45 28.45 32.26 32.26 32.26 30.99 30.99 30.99 45.86 45.86 45.86 +.005 -.000 in .089 .089 .089 .089 .089 .089 .089 .117 .117 .117 (1.27) (.000) mm 2.26 2.26 2.26 2.26 2.26 2.26 2.26 2.97 2.97 2.97 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Mounting Hardware .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Mounting Hardware For Plastic & Metal Shell Dura-Con Connectors Option “R” Option “F” 5 Option “L” Option “K” Option “P” Call Toll Free: 1 (800) 323-9612 5-12 Dura-Con High Reliability Mounting Hardware .050" (1.27mm) Density Solder Cup/Wire D-Microminiature P/N: DCSL1 Purchased Separately Jackpost - Rear Panel Mount (Purchased Separately) Panel Cutout Dimensions (Plug & Receptacle) Jackpost Part Number DCJPRM094 DCJPRM063 DCJPRM047 DCJPRM031 Part Number (by Shell Size) 9 15 21 25 31 37 51 100 Panel Thickness in mm .094 2.5 .063 1.6 .047 1.2 .031 0.8 A +.004 (.101) -.000 (.000) in mm .398 10.11 .548 13.92 .698 17.73 .798 20.27 .948 24.08 1.098 27.89 1.048 26.62 1.448 36.78 5-13 A Dimension in mm .092/.087 2.34/2.21 .061/.056 1.55/1.42 .047/.042 1.19/1.07 .030/.025 0.76/0.64 B +.004 (.101) -.000 (.000) in mm .249 6.32 .249 6.32 .249 6.32 .249 6.32 .249 6.32 .249 6.32 .292 7.42 .336 8.53 C +.005 (.127) in mm .565 14.35 .715 18.16 .865 21.97 .965 24.51 1.115 28.34 1.265 32.13 1.215 30.86 1.800 45.72 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block ■ Plug & socket versions available in 9, 15, 21, 25, 31, 37, 51, and 100 positions. ■ Flow-through design facilitates inspection and cleaning after soldering. FEATURES ■ All terminal block connectors use standard mounting hardware. ■ Metal shell provides EMI/RFI shielding capability. ■ Available in 3 styles: Straight mount, 90° right-angle mount, and 90° rightangle narrow profile mounting. ■ Silicone elastomer interfacial seal protects contacts from moisture and isolates them from each other and from the metal shell. ■ Meets requirements of MIL-C-83513. ■ Choice of insulator materials. ELECTRICAL ENVIRONMENTAL MATERIALS Insulator: UL94V-0 glass-filled polyester or diallyl phthalate Contacts: Pins - Copper alloy, Sockets - Copper alloy (machined) Contact Plating: .000050 in gold Shell: Aluminum alloy Shell Plating: Yellow chromate over cadmium (std.) or electroless nickel Operating Temperature: -55°C to +135°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level, 150 VAC @ 70,000 ft. 8 milliohms maximum MECHANICAL Insulation Resistance: 1,000 megohms min between adjacent pins Individual Contact: 6 oz. (170.40 g) maximum insertion force; 0.5 oz. (14.20 g) minimum withdrawal force Mating / Unmating Forces: See table Call Toll Free: 1 (800) 323-9612 5-14 No. of Contacts 9 15 21 25 31 37 51 100 Maximum Mating Force Lb. Kg 5.63 2.56 9.38 4.26 13.13 5.96 15.63 7.10 19.38 8.80 23.13 10.50 31.88 14.47 62.50 28.38 Minimum Unmating Force Lb. Kg .28 .13 .47 .21 .66 .30 .78 .35 .97 .44 1.16 .53 1.59 .72 3.13 1.42 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block Contact Arrangements Ordering Information DC D M 25 S BR -- -Shell Finish* No Letter = Standard Yellow Chromate over Cadmium N = Electroless Nickel Cinch Dura-Con D Connector Insulator Type C = Diallyl Phthalate Glass Reinforced D = Thermoplastic Glass Reinforced Hardware* No Letter = Less Hardware P = Jackpost Termination Style BR = 90° PCB BS = Straight 180° PCB CBR = 90° Narrow Profile PCB Mounting Type M = Screw Mount Metal Shell No. of Contacts 9, 15, 21, 25, 31, 37, 51, & 100 Contact Type P = Pin (Plug) S = Socket (Receptacle) * For other options consult factory. 5-15 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block Recommended Board Layout Typ. Hole Dia. = .040" (1.02 mm) NOTE: For additional connector dimensions, see page 5-10. 5 A Max. No. of Contacts in mm 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket 1.390 1.390 1.540 1.540 1.690 1.690 1.790 1.790 2.040 2.040 2.340 2.340 1.875 1.875 2.780 2.780 35.31 35.31 39.12 39.12 42.93 42.93 45.47 45.47 51.82 51.82 59.44 59.44 47.63 47.63 70.61 70.61 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket B + .007 (0.18) in mm 1.150 1.150 1.300 1.300 1.450 1.450 1.550 1.550 1.800 1.800 2.100 2.100 1.600 1.600 2.500 2.500 G Max. in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .394 .394 mm 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 8.92 8.92 10.00 10.00 29.21 29.21 33.02 33.02 36.83 36.83 39.37 39.37 45.72 45.72 53.34 53.34 40.64 40.64 63.50 63.50 H Max. in .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 Call Toll Free: 1 (800) 323-9612 mm 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 C + .005 (0.13) in mm .565 .565 .715 .715 .865 .865 .965 .965 1.115 1.115 1.265 1.265 1.215 1.215 1.800 1.800 14.35 14.35 18.16 18.16 21.97 21.97 24.51 24.51 28.32 28.32 32.13 32.13 30.86 30.86 45.72 45.72 J + .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 5-16 F Max. in mm .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .565 .565 .765 .765 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 14.35 14.35 19.43 19.43 K + .015 in .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .225 .225 mm 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 5.72 5.72 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block Straight (180°) Termination Recommended Board Layout Typ. Hole Dia. = .040" (1.02 mm) NOTE: For additional connector dimensions, see page 5-10. No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket A Max. in 1.390 1.390 1.390 1.390 1.690 1.690 1.740 1.740 2.040 2.040 2.340 2.340 2.270 2.270 3.070 3.070 mm 35.31 35.31 35.31 35.31 42.93 42.93 44.20 44.20 51.82 51.82 59.44 59.44 57.66 57.66 77.98 77.98 H Max. in .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 mm 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 B + .007 (0.18) in mm 1.150 29.21 1.150 29.21 1.150 29.21 1.150 29.21 1.450 36.83 1.450 36.83 1.500 38.10 1.500 38.10 1.800 45.72 1.800 45.72 2.100 53.34 2.100 53.34 2.000 50.80 2.000 50.80 2.800 71.12 2.800 71.12 J + .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 C + .005 (0.13) in mm .565 14.35 .565 14.35 .715 18.16 .715 18.16 .865 21.97 .865 21.97 .965 24.51 .965 24.51 1.115 28.32 1.115 28.32 1.265 32.13 1.265 32.13 1.215 30.86 1.215 30.86 1.800 45.72 1.800 45.72 D Max. in .885 .885 .945 .945 1.185 1.185 1.275 1.275 1.575 1.576 1.875 1.875 1.775 1.775 2.585 2.585 K Max. in .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .300 .300 5-17 mm 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 7.62 7.62 G Max. mm 22.48 22.48 24.0 24.0 30.09 30.09 32.38 32.38 40.00 40.00 47.62 47.62 45.08 45.08 65.55 65.65 in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .455 .455 mm 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 8.92 8.92 11.56 11.56 L Max. in .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .550 .550 mm 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 13.97 13.97 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block Recommended Board Layout NOTE: For additional connector dimensions, see page 5-10. Typ. Hole Dia. = .040" (1.02 mm) 5 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket A Max. in .785 .785 .935 .935 1.085 1.085 1.085 1.185 1.335 1.335 1.485 1.485 1.435 1.435 2.175 2.175 mm 19.94 19.94 23.75 23.75 27.56 27.56 30.10 30.10 33.91 33.91 37.72 37.72 36.45 36.45 55.25 55.25 B + .005 (0.13) in mm .565 14.35 .565 14.35 .715 18.16 .715 18.16 .865 21.97 .865 21.97 .965 24.51 .965 24.51 1.115 28.32 1.115 28.32 1.265 32.13 1.265 32.13 1.215 30.86 1.215 30.86 1.800 45.72 1.800 45.72 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket F + .010 (0.25) in mm .230 5.84 .230 5.84 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .150 3.81 .150 3.81 .200 5.08 .200 5.08 G + .010 (0.25) in mm .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .300 7.62 .300 7.62 .400 10.16 .400 10.16 Call Toll Free: 1 (800) 323-9612 C Max. in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .394 .394 mm 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 8.92 8.92 10.00 10.00 H Max. in .420 .420 .420 .420 .420 .420 .420 .420 .520 .520 .520 .520 .650 .650 1.000 1.000 mm 10.67 10.67 10.67 10.67 10.67 10.67 10.67 10.67 13.21 13.21 13.21 13.21 16.51 16.51 25.40 25.40 5-18 J + .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .996 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature FEATURES ■ All-plastic and metal shell wire versions available in solder cup, gold-plated solid wire, and insulated stranded wire. ■ PCB mount “terminal block” type connectors available in straight or right angle. ■ Sizes offered - 9, 15, 21, 25, 31, 35, 51, and 100 (metal shell only). ■ All products are qualified to the requirements of MIL-C-83513 and marked with the M83513 part number. ■ Optional shell platings and insulator materials offer high performance in harsh environments. MECHANICAL ELECTRICAL ENVIRONMENTA L MATERIALS ■ Mounting hardware per MIL-C-83513. Insulator: UL94V-0 rated glass-filled polyester per MIL-M-24519 or diallyl phthalate (DAP) per MIL-M-14. Contacts: Pins - Copper alloy, Sockets - Copper alloy Contact Plating: .000050 in gold per MIL-G-45204 Shell Material (Metal Shell Only): Aluminum alloy Shell Plating (Metal Shell Only): Yellow chromate over cadmium (std.) or electroless nickel Operating Temperature: -55°C to +125°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level 8 milliohms maximum Durability: 500 mate/unmate cycles Individual Contact: Forces 6 oz. (170.40 g) maximum insertion; 0.5 oz. (14.20 g) minimum withdrawal Mating / Unmating Force: See table Call Toll Free: 1 (800) 323-9612 5-20 No. of Contacts 9 15 21 25 31 37 51 Maximum Mating Force Lb. Kg 5.63 2.56 9.38 4.26 13.13 5.96 15.63 7.10 19.38 8.80 23.13 10.50 31.88 14.47 Minimum Unmating Force Lb. Kg .28 .13 .47 .21 .66 .30 .78 .35 .97 .44 1.16 .53 1.59 .72 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature - Metal Shell Metal Shell Contact Arrangements (Face view of pin insert) (Use reverse order for socket side) Ordering Information M83513/04 - A 03 C Shell Finish C = Cadmium N = Electroless Nickel Connector Type 01 - Metal Shell D Plugs with Solder Cup Termination Wire Type (Use only for /03 & /04, otherwise omit) 01 - M22759/11-26-9, 18 inches, White (see note below) 02 - M22759/11-26-9, 36 inches, White (see note below) 03 - M22759/11-26-( ), 18 inches, Color Coded (see note below) 04 - M22759/11-26-( ), 36 inches, Color Coded (see note below) 05 - QQ-W-343, 25 AWG, 0.5 inch, Gold-Plated 06 - QQ-W-343, 25 AWG, 1.0 inch, Gold-Plated 07 - QQ-W-343, 25 AWG, 0.5 inch, Tin-Plated 08 - QQ-W-343, 25 AWG, 1.0 inch, Tin-Plated 09 - M22759/33-26-9, 18 inches, White 10 - M22759/33-26-9, 36 inches, White 11 - M22759/33-26-( ), 18 inches, Color Coded 12 - M22759/33-26-( ), 36 inches, Color Coded 13 - M22759/11-26-9, 72 inches, White 14 - M22759/11-26-( ), 72 inches, Color Coded 15 - M22759/33-26-9, 72 inches, White 16 - M22759/33-26-( ), 72 inches, Color Coded 02 - Metal Shell D Sockets with Solder Cup Termination 03 - Metal Shell D Plugs with Wire Leads 04 - Metal Shell D Sockets with Wire Leads Insert Arrangements (No. of Contacts) A=9 B = 15 C = 21 D = 25 E = 31 F = 37 G = 51 H = 100 Note: See page 5-31 for M83513 mounting hardware. 5-21 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature - Metal Shell Connector Dimensions - Metal Shell Plug Socket A 5 B Max. (Plug) Min. (Socket) mm 8.48 C + .010" (.254) - .018" (.457) in mm .390 9.91 .3342 8.49 .390 9.91 .565 14.35 .298 7.57 .270 6.68 .4838 12.29 .540 13.72 .715 18.16 .298 7.57 .270 6.68 23.50 .4842 12.30 .540 13.72 .715 18.16 .298 7.57 .270 6.68 27.30 .6338 16.10 .690 17.53 .865 21.97 .298 7.57 .270 6.68 1.075 27.30 .6342 16.11 .690 17.53 .865 21.97 .298 7.57 .270 6.68 1.175 29.84 .7338 18.64 .790 20.07 .965 24.51 .298 7.57 .270 6.68 25 Socket 1.175 29.84 .7342 18.65 .790 20.07 .965 24.51 .298 7.57 .270 6.68 31 Plug 1.325 33.66 .8838 22.45 .940 23.88 1.115 28.32 .298 7.57 .270 6.68 31 Socket 1.325 33.66 .8842 22.46 .940 23.88 1.115 28.32 .298 7.57 .270 6.68 37 Plug 1.475 37.46 1.0338 26.26 1.090 27.69 1.265 32.13 .298 7.57 .270 6.68 37 Socket 1.475 37.46 1.0342 26.27 1.090 27.69 1.265 32.13 .298 7.57 .270 6.68 51 Plug 1.425 36.20 .9838 24.99 1.040 26.42 1.215 30.86 .341 8.66 .310 7.87 51 Socket 1.425 36.20 .9842 25.00 1.040 26.42 1.215 30.86 .341 8.66 .310 7.87 100 Plug 2.160 54.86 1.3838 35.15 1.432 36.38 1.800 45.71 .384 9.75 .360 9.15 100 Socket 2.160 54.86 1.3842 35.16 1.432 36.38 1.800 45.71 .384 9.75 .360 9.15 No. of Contacts 9 Plug ± .010" (.254) in mm .775 19.68 in .3338 9 Socket .775 19.68 15 Plug .925 23.50 15 Socket .925 21 Plug 1.075 21 Socket 25 Plug Call Toll Free: 1 (800) 323-9612 5-22 D E F Max. ± .005" (.127) in mm .565 14.35 ± .010" (.254) in mm .298 7.57 in .270 mm 6.68 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature - Metal Shell Panel Mounting Dimensions - Metal Shell Panel Mounting Dimensions Panel Cutout Dimensions - Metal Shell No. of Contacts Front Mounting 9 15 21 25 31 37 51 100 No. of Contacts Rear Mounting 9 15 21 25 31 37 51 100 No. of Contacts Edgeboard Mounting 9 15 21 25 31 37 51 100 A +.004" (.101mm) -.000" (.000mm) in mm .408 .558 .708 .808 .958 1.108 1.058 1.450 10.36 14.17 17.98 20.52 24.33 28.14 26.87 36.84 A +.004" (.101mm) -.000" (.000mm) in mm .408 .558 .708 .808 .958 1.108 1.058 1.450 10.36 14.17 17.98 20.52 24.33 28.14 26.87 36.84 B +.004" (.101mm) -.000" (.000mm) in mm .270 .270 .270 .270 .270 .270 .315 .361 6.86 6.86 6.86 6.86 6.86 6.86 8.00 9.17 6.50 6.50 6.50 6.50 6.50 6.50 7.62 8.58 C +.005" (.127mm) -.000" (.000mm) in mm .570 .720 .870 .970 1.120 1.270 1.220 1.805 14.48 18.29 22.10 24.64 28.45 32.26 30.99 45.86 5-23 .570 .720 .870 .970 1.120 1.270 1.220 1.805 B +.004" (.101mm) -.000" (.000mm) in mm .256 .256 .256 .256 .256 .256 .300 .338 C +.005" (.127mm) -.000" (.000mm) in mm 14.48 14.48 22.10 24.64 28.45 32.26 30.99 45.86 C +.005" (.127mm) -.000" (.000mm) in mm .570 .720 .870 .970 1.120 1.270 1.220 1.805 D +.005" (.127mm) -.000" (.000mm) in mm .089 .089 .089 .089 .089 .089 .089 .117 D +.005" (.127mm) -.000" (.000mm) in mm 14.48 18.29 22.10 24.64 28.45 32.26 30.99 45.86 .089 .089 .089 .089 .089 .089 .089 .117 D +.005" (.127mm) -.000" (.000mm) in mm .089 .089 .089 .089 .089 .089 .089 .117 2.26 2.26 2.26 2.26 2.26 2.26 2.26 2.97 2.26 2.26 2.26 2.26 2.26 2.26 2.26 2.97 Call Toll Free: 1 (800) 323-9612 2.26 2.26 2.26 2.26 2.26 2.26 2.26 2.97 5 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature - Plastic Plastic Shell Contact Arrangements (Face view of pin insert) (Use reverse order for socket side) Ordering Information M83513/06-A 04 Connector Type Wire Type (Use only for /08 & /09, otherwise omit) 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 06 - Plastic Shell Plugs with Solder Cup Termination 07 - Plastic Shell Sockets with Solder Cup Termination 5 08 - Plastic Shell Plugs with Wire Leads 09 - Plastic Shell Sockets with Wire Leads Insert Arrangements (No. of Contacts) A=9 B = 15 C = 21 D = 25 E = 31 F = 37 G = 51 Call Toll Free: 1 (800) 323-9612 - M22759/11-26-9, 18 inches, White M22759/11-26-9, 36 inches, White M22759/11-26-( ), 18 inches, Color Coded M22759/11-26-( ), 36 inches, Color Coded QQ-W-343, 25 AWG, 0.5 inch, Gold-Plated QQ-W-343, 25 AWG, 1.0 inch, Gold-Plated QQ-W-343, 25 AWG, 0.5 inch, Tin-Plated QQ-W-343, 25 AWG, 1.0 inch, Tin-Plated M22759/33-26-9, 18 inches, White M22759/33-26-9, 36 inches, White M22759/33-26-( ), 18 inches, Color Coded M22759/33-26-( ), 36 inches, Color Coded M22759/11-26-9, 72 inches, White M22759/11-26-( ), 72 inches, Color Coded M22759/33-26-9, 72 inches, White M22759/33-26-( ), 72 inches, Color Coded Note: See page 5-31 for M83513 mounting hardware. 5-24 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature - Plastic Shell Dimensions - (All-Plastic Version) Plug Socket A No. of Contacts B Max. (Plug) Min. (Socket) ±.010" (.254) in mm in mm C +.010" (.254) -.018" (.457) in mm D E ±.005" (.127) in mm F Max. ±.010" (.254) in mm in mm 9 Plug .778 19.76 .2918 7.41 .398 10.11 .565 14.35 .208 5.28 .173 4.39 9 Socket .778 19.76 .2922 7.42 .398 10.11 .565 14.35 .208 5.28 .173 4.39 15 Plug .928 23.57 .4418 11.22 .548 13.92 .715 18.16 .208 5.28 .173 4.39 15 Socket .928 23.57 .4422 11.23 .548 13.92 .715 18.16 .208 5.28 .173 4.39 21 Plug 1.078 27.38 .5918 15.03 .698 17.73 .865 21.97 .208 5.28 .173 4.39 21 Socket 1.078 27.38 .5922 15.04 .698 17.73 .865 21.97 .208 5.28 .173 4.39 25 Plug 1.178 29.92 .6918 17.57 .798 20.27 .965 24.51 .208 5.28 .173 4.39 25 Socket 1.178 29.92 .6922 17.58 .798 20.27 .965 24.51 .208 5.28 .173 4.39 31 Plug 1.328 33.73 .8418 21.38 .948 24.08 1.115 28.32 .208 5.28 .173 4.39 31 Socket 1.328 33.73 .8422 21.39 .948 24.08 1.115 28.32 .208 5.28 .173 4.39 37 Plug 1.478 37.54 .9918 25.19 1.098 27.89 1.265 32.13 .208 5.28 .173 4.39 37 Socket 1.478 37.54 .9922 25.20 1.098 27.89 1.265 32.13 .208 5.28 .173 4.39 51 Plug 1.428 36.27 .9418 23.92 1.048 26.62 1.215 30.86 .250 6.35 .220 5.59 51 Socket 1.428 36.27 .9422 23.93 1.048 26.62 1.215 30.86 .250 6.35 .220 5.59 5-25 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature - Plastic Panel Mounting Dimensions - All-Plastic Panel Cutout Dimensions No. of Contacts Front Mounting A +.004" (.101mm) -.000" (.000mm) in mm B +.004" (.101mm) -.000" (.000mm) in mm C +.005" (.127mm) -.000" (.000mm) in mm 9 .408 10.36 .172 4.37 .570 14.48 15 .558 14.17 .172 4.37 .720 14.48 21 .708 17.98 .172 4.37 .870 22.10 25 .808 20.52 .172 4.37 .970 24.64 31 .958 24.33 .172 4.37 1.120 28.45 37 1.108 28.14 .172 4.37 1.270 32.26 51 1.058 26.87 .215 5.46 1.220 30.99 Rear Cutout Dimensions No. of Contacts 5 Rear Mounting A +.004" (.101mm) -.000" (.000mm) in mm B +.004" (.101mm) -.000" (.000mm) in mm 9 .373 9.47 .216 5.49 .570 14.48 15 .523 13.28 .216 5.49 .720 18.29 21 .674 17.12 .216 5.49 .870 22.10 25 .774 19.66 .216 5.49 .970 24.64 31 .924 23.47 .216 5.49 1.120 28.45 37 1.074 27.28 .216 5.49 1.270 32.26 51 1.024 26.01 .259 6.58 1.220 30.99 Edgeboard Mounting Cutout Dimensions Edgeboard Mounting C +.005" (.127mm) -.000" (.000mm) in mm No. of Contacts D +.005" (.127mm) -.000" (.000mm) in mm 9 .570 14.48 15 .720 18.29 21 .870 22.10 25 .970 24.64 31 1.120 28.45 37 1.270 32.26 51 1.220 30.99 Call Toll Free: 1 (800) 323-9612 5-26 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density D-Microminiature PC Board Mount Terminal Block Contact Arrangements (Face view of pin insert) (Use reverse order for socket side) Ordering Information M83513/10 - C 02 C N Hardware N = No Jackpost P = Jackpost Attached Connector Description 10 = Plug, 9-37 Pos., Narrow Profile, Rt. Angle 11 = Plug, 51 Pos., Narrow Profile, Rt. Angle 12 = Plug, 100 Pos., Narrow Profile, Rt. Angle 13 = Socket, 9-37 Pos., Narrow Profile, Rt. Angle 14 = Socket, 51 Pos., Narrow Profile, Rt. Angle 15 = Socket, 100 Pos., Narrow Profile, Rt. Angle 16 = Plug, 9-37 Pos., Std. Profile, Rt. Angle 17 = Plug, 51 Pos., Std. Profile, Rt. Angle 18 = Plug, 100 Pos., Std. Profile, Rt. Angle 19 = Socket, 9-37 Pos., Std. Profile, Rt. Angle 20 = Socket, 51 Pos., Std. Profile, Rt. Angle 21 = Socket, 100 Pos., Std. Profile, Rt. Angle 22 = Plug, 9-37 Pos., Straight Mount 23 = Plug, 51 Pos., Straight Mount 24 = Plug, 100 Pos., Straight Mount 25 = Socket, 9-37 Pos., Straight Mount 26 = Socket, 51 Pos., Straight Mount 27 = Socket, 100 Pos., Straight Mount Shell Finish C = Cadmium N = Electroless Nickel Termination Length 01 = 0.109 02 = 0.140 03 = 0.172 Insert Arrangement Length (No. of Contacts) A=9 B = 15 C = 21 D = 25 E = 31 F = 37 G = 51 H = 100 5-27 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature Recommended Board Layout (/16-/21) Typ. Hole Dia. = .040" (1.02 mm) NOTE: For additional connector dimensions, see page 5-22. 5 A Max. No. of Contacts in mm 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket 1.390 1.390 1.540 1.540 1.690 1.690 1.790 1.790 2.040 2.040 2.340 2.340 1.875 1.875 2.780 2.780 35.31 35.31 39.12 39.12 42.93 42.93 45.47 45.47 51.82 51.82 59.44 59.44 47.63 47.63 70.61 70.61 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket B ± .007 (0.18) in mm 1.150 1.150 1.300 1.300 1.450 1.450 1.550 1.550 1.800 1.800 2.100 2.100 1.600 1.600 2.500 2.500 29.21 29.21 33.02 33.02 36.83 36.83 39.37 39.37 45.72 45.72 53.34 53.34 40.64 40.64 63.50 63.50 in .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 H Max. mm 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 G Max. in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .394 .394 mm 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 8.92 8.92 10.00 10.00 Call Toll Free: 1 (800) 323-9612 C ± .005 (0.13) in mm .565 .565 .715 .715 .865 .865 .965 .965 1.115 1.115 1.265 1.265 1.215 1.215 1.800 1.800 14.35 14.35 18.16 18.16 21.97 21.97 24.51 24.51 28.32 28.32 32.13 32.13 30.86 30.86 45.72 45.72 J ± .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 5-28 F Max. in mm .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .565 .565 .765 .765 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 14.35 14.35 19.43 19.43 K ± .015 in .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .225 .225 mm 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 5.72 5.72 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature Straight (180°) Termination (/22-/27) Recommended Board Layout Typ. Hole Dia. = .040" (1.02 mm) NOTE: For additional connector dimensions, see page 5-22. No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket A Max. in 1.390 1.390 1.390 1.390 1.690 1.690 1.740 1.740 2.040 2.040 2.340 2.340 2.270 2.270 3.070 3.070 mm 35.31 35.31 35.31 35.31 42.93 42.93 44.20 44.20 51.82 51.82 59.44 59.44 57.66 57.66 77.98 77.98 B ± .007 (0.18) in mm 1.150 29.21 1.150 29.21 1.150 29.21 1.150 29.21 1.450 36.83 1.450 36.83 1.500 38.10 1.500 38.10 1.800 45.72 1.800 45.72 2.100 53.34 2.100 53.34 2.000 50.80 2.000 50.80 2.800 71.12 2.800 71.12 mm 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 J ± .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 H Max. in .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 C ± .005 (0.13) in mm .565 14.35 .565 14.35 .715 18.16 .715 18.16 .865 21.97 .865 21.97 .965 24.51 .965 24.51 1.115 28.32 1.115 28.32 1.265 32.13 1.265 32.13 1.215 30.86 1.215 30.86 1.800 45.72 1.800 45.72 D Max. in .885 .885 .945 .945 1.185 1.185 1.275 1.275 1.575 1.576 1.875 1.875 1.775 1.775 2.585 2.585 K Max. in .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .300 .300 5-29 G Max. mm 22.48 22.48 24.0 24.0 30.09 30.09 32.38 32.38 40.00 40.00 47.62 47.62 45.08 45.08 65.55 65.65 in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .455 .455 mm 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 8.92 8.92 11.56 11.56 L Max. mm 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 7.62 7.62 in .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .550 .550 mm 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 13.97 13.97 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature Recommended Board Layout (/10-/15) NOTE: For additional connector dimensions, see page 5-22. Typ. Hole Dia. = .040" (1.02 mm) 5 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket A Max. in .785 .785 .935 .935 1.085 1.085 1.085 1.185 1.335 1.335 1.485 1.485 1.435 1.435 2.175 2.175 mm 19.94 19.94 23.75 23.75 27.56 27.56 30.10 30.10 33.91 33.91 37.72 37.72 36.45 36.45 55.25 55.25 B ± .005 (0.13) in mm .565 14.35 .565 14.35 .715 18.16 .715 18.16 .865 21.97 .865 21.97 .965 24.51 .965 24.51 1.115 28.32 1.115 28.32 1.265 32.13 1.265 32.13 1.215 30.86 1.215 30.86 1.800 45.72 1.800 45.72 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket F ± .010 (0.25) in mm .230 5.84 .230 5.84 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .150 3.81 .150 3.81 .200 5.08 .200 5.08 G ± .010 (0.25) in mm .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .300 7.62 .300 7.62 .400 10.16 .400 10.16 Call Toll Free: 1 (800) 323-9612 C Max. in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .394 .394 mm 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 8.92 8.92 10.00 10.00 H Max. in .420 .420 .420 .420 .420 .420 .420 .420 .520 .520 .520 .520 .650 .650 1.000 1.000 mm 10.67 10.67 10.67 10.67 10.67 10.67 10.67 10.67 13.21 13.21 13.21 13.21 16.51 16.51 25.40 25.40 5-30 J ± .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .996 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature Mounting Hardware 5 Ordering Information Type Style Jackscrew Low Profile Jackscrew High Profile Jackscrew Low Profile Jackscrew High Profile Jackpost -Jackscrew Low Profile Jackscrew High Profile Jackscrew Low Profile Jackscrew High Profile Jackpost -*100 Size Only Screwhead Recessed Hex Recessed Hex Slotted Slotted -Hex Hex Slotted Slotted -- Thread 2/56 2/56 2/56 2/56 2/56 4/40* 4/40* 4/40* 4/40* 4/40* Military Part No. M83513/5-02 M83513/5-03 M83513/5-05 M83513/5-06 M83513/5-07 M83513/5-12 M83513/5-13 M83513/5-15 M83513/5-16 M83513/5-17 5-31 Call Toll Free: 1 (800) 323-9612 Dura-Con .050" (1.27mm) Density High Reliability Connector Saver All-Plastic & Metal Shell FEATURES ■ Designed to significantly reduce damage to already mounted Dura-Con connectors during routine system tests. ■ Eliminates numerous mating & unmating cycles experienced by connectors on test harnesses. ■ Plug connector on one end, socket connector on the other. ■ Available in all-plastic (polyester) or in metal shell with diallyl phthalate or polyester insulators (both UL94V-0 rated). ■ Locking hardware must be ordered separately. MATERIALS Insulator: UL94V-0 glass-filled polyester or diallyl phthalate Contacts: Copper alloy Contact Plating: .000050 in gold Shell (Metal Only): Aluminum alloy MECHANICAL ELECTRICAL ENVIRONMENTAL Shell Plating: Yellow chromate over cadmium Operating Temperature: -55°C to +135°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level 8 milliohms maximum Individual Contact: Insertion force, 6 oz. (170.40 g) maximum; Withdrawal force 0.5 oz. (14.20 g) minimum Mating / Unmating Forces: See previous tables No. of Contacts 9 15 21 25 31 37 51 100 Diallyl Phthalate Catalog No. DCCM9CS DCCM15CS DCCM21CS DCCM25CS DCCM31CS DCCM37CS DCCM51CS DCCM100CS Metal Shell Glass-Filled Polyester Catalog No. DCDM9CS DCDM15CS DCDM21CS DCDM25CS DCDM31CS DCDM37CS DCDM51CS DCDM100CS Call Toll Free: 1 (800) 323-9612 5-32 All Plastic Glass-Filled Polyester Catalog No. DCDA9CS DCDA15CS DCDA21CS DCDA25CS DCDA31CS DCDA37CS DCDA51CS – Dura-Con High Reliability Microedge Connectors FEATURES ■ ■ ■ ■ ■ ■ .050" (1.27mm) Density PC Board Mount Metal Shell Variety of available PC board mounting styles. - “Coke Bottle” for edge mounting on double-sided PCBs - Right-angle (90°) mounting for single- or double-sided daughter boards - “Claw Foot” leads - Gold-plated solid copper wire pigtails Harnessing capabilities exist for both plug & socket. Standard sizes are 128 and 184 positions. Utilizes high-reliability Dura-Con twist pin contact system assuring electrical continuity under extreme shock and vibration. Aluminum shells and diallyl phthalate insulators make Dura-Con microedge connectors ideal for airborne or space applications. Microedge metal shell connectors meet the requirement of MIL-C-55302. MATERIALS Insulator: UL94V-0 glass-filled polyester or diallyl phthalate per MIL-M-14 (green) Contacts: Copper alloy Contact Plating: .000050 in Gold Shell: Aluminum alloy MECHANICAL ELECTRICAL ENVIRONMENTAL Shell Plating: Electroless Nickel Operating Temperature: -55°C to +135°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level, 300 VAC @ 70,000 ft. 8 milliohms maximum Insertion/Withdrawal Force: 6 oz. (170.40 g[f]) maximum insertion force, per contact; 0.5 oz. (14.20 g[f]) minimum withdrawal force, per contact Call Toll Free: 1 (800) 323-9612 5-34 Dura-Con High Reliability Microedge Connectors .050" (1.27mm) Density PC Board Mount Metal Shell 5 5-35 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability Microedge Connectors .050" (1.27mm) Density PC Board Mount Metal Shell Recommended PCB thickness .047-.062. Consult factory for other thicknesses. 5 * Narrow Version (DNEB) .250 Wide Call Toll Free: 1 (800) 323-9612 5-36 Dura-Con High Reliability Microedge Connectors .050" (1.27mm) Density PC Board Mount Metal Shell 184 Contact Plug (Standard Insulated Wire) Side View * Narrow Version (DNEB) .250 Wide Shell Polarization Kit Order No. DNEBP0L1 DMEBP0L1 “L” .250 .312 Key L Used On DNEB Narrow Only DMEB Std. Width Mounting Hardware Standard Jackscrew/Jackpost Assembly Removable Jackscrew/Jackpost Assembly Plug with Jackscrew Consult factory if required. Ordering Information Receptacle with Jackscrew DMEB 1-128 P 6 E 2 180 Series Prefix DMEB = Microedgeboard DNEB = Microedgeboard, Narrow (184 Only) Lead Length in Inches Contact Spacing 1 = .050" (1.27mm) centers 128/184 2 = .100" (2.54mm) centers 64/92 (every other contact hole) For other contact spacing accommodations, consult the factory. Termination, Color of Finish 1 = White *2 = Yellow 3 = Tin-Plated *4 = Gold-Plated (Solid Copper Wire Only) *5 = Color Coded per MIL-Std. 681, System 1 No. of Contacts 128, 184 Wire Type/Termination Style C = Solid Copper E = MIL-W-16878/4, 7 Strand BS = PC Board (Coke Bottle) BRA = PC Board Right-Angle (Formed to “A” Side) BRB = PC Board Right-Angle (Formed to “B” Side) W = PC Board (Claw Foot) Contact Type P = Pin S = Socket Wire Size in AWG 5 = 25 AWG Solid Copper 6 = 26 AWG Stranded Wire S = Solder Cup *Indicates Cinch std Option 5-37 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Strip Connectors .050" (1.27mm) Density Solder Cup/Wire All-Plastic ■ Lightweight. FEATURES ■ Slim Profile. ■ High-Density Interconnect. ■ High-reliability Dura-Con twist pin contact system for extreme shock & vibration applications. ■ Optional polarization with guide pins to prevent mismating connectors. MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS ■ Plug & socket available in sizes from 1 to 60 positions. Insulator: UL94V-0 glass-filled polyester Contacts: Copper alloy Contact Plating: .000050 in gold Operating Temperature: -55°C to +135°C Current Rating: 3 Amps maximum Withstanding Voltage: 600 VAC @ sea level; 150 VAC @ 70,000 ft. Contact Resistance: 8 milliohms maximum Insertion & Withdrawal Force (Per Contact): 6 oz. (170.40 g[f]) maximum insertion; 0.5 oz. (14.20 g[f]) minimum withdrawal Call Toll Free: 1 (800) 323-9612 5-38 Dura-Con High Reliability Strip Connectors .050" (1.27mm) Density Solder Cup/Wire All Plastic Dimensions Socket Connector Pin Connector Epoxy 24 Gauge Stainless Steel Guide Pin* NOTE: Dimension A is number of positions less 1 multiplied by .050 * Assembly in socket connector only. Ordering Information CS A 1 10 P 4 C 4-00.5 G Cinch Dura-Con Strip Thermoplastic Glass-Reinforced Strip Connector Guide Pin (Socket Only) Empty Cavity (Pin Only) G02 = Guide Pin Position No. 2 GX = Special Position, Consult Factory Contact Centers A = .050 (24 Ga.) Contact Position 1 = Contacts in every position Lead Length in inches 00.5 Solid copper wire only 01.0 Solid copper wire only 02.0 Solid copper wire only 18.0 Stranded wire only 24.0 Stranded wire only 36.0 Stranded wire only 48.0 Stranded wire only No. of Contact Positions 1 through 60** Contact Type P = Pin S = Socket Insulation Color, Solid Wire Finish, Solid Cup Finish 1 = All White *2 = All Yellow 3 = Tin-Plated *4 = Gold-Plated (Solid Wire Only) *5 = Color Coded Per MIL-Std. 681, System 1 System 1. (Stranded Wire Only) Wire Size in AWG 5 = 25 AWG Solid Copper Wire 6 = 26 AWG Stranded Wire S = Solder Cup (Skip to guide pin field if necessary) Insulation Wire or Solid Wire Type C = Solid Copper E = MIL-W-168 78/4, 7 Strand * - Indicates Cinch std. option. ** - Consult factory for larger sizes and multi-row. 5-39 Call Toll Free: 1 (800) 323-9612 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cinch Connectivity Solutions: DCDM-15P6E5-36.0B DCDM-15S6E5-10.0F DCDM-15S6E5-24.0B DCDM-15S6E5-24.0F DCDM-15S6E5-24.0K DCDM-15S6E5-36.0B DCDM-15S6E5-36.0B LPM DCDM-15S6E5-36.0F DCDM-15S6E5-36.0K DCDM-25P6E536.0B DCDM-25S6E5-24.0B DCDM-25S6E5-24.0F DCDM-25S6E5-24.0K DCDM-15P6E5-18.0B DCDM-15P6E518.0F DCDM-15P6E5-18.0K DCDM-15P6E5-18.0L DCDM-15P6E5-18.0P DCDM-15PSB DCDM-15PSF DCDM15PSK DCDM-15PSL DCDM-15PSP DCDM-15S6E5-18.0B DCDM-15S6E5-18.0F DCDM-15S6E5-18.0K DCDM15S6E5-18.0L DCDM-15S6E5-18.0P DCDM-15SSB DCDM-15SSF DCDM-15SSK DCDM-15SSL DCDM-15SSP DCDM-25P6E5-18.0B DCDM-25SSF DCDM-25SSK DCDM-25SSL DCDM-25SSP DCDM-51P6E5-18.0B DCDM51P6E5-18.0F DCDM-51P6E5-18.0K DCDM-51P6E5-18.0L DCDM-51P6E5-18.0P DCDM-51PSF DCDM-51PSK DCDM-51PSL DCDM-51PSP DCDM-51S6E5-18.0F DCDM-51S6E5-18.0K DCDM-51S6E5-18.0L DCDM-51S6E518.0P DCDM-51SSB DCDM-51SSF DCDM-25S6E5-36.0B LPM DCDM-25S6E5-36.0F DCDM-25S6E5-36.0K DCDM-51P6E5-36.0B DCDM-9S6E5-36.0B DCDM-21S6E5-18.0B DCDM-21S6E5-18.0F DCDM-21S6E5-18.0K DCDM-21S6E5-18.0S DCDM-21S6E5-24.0F DCDM-21S6E5-36.0B LPM DCDM-21S6E5-36.0K DCDM-51SSK DCDM-51SSL DCDM-51SSP DCDM-9P6E5-18.0B DCDM-9P6E5-18.0F DCDM-9P6E5-18.0K DCDM-9P6E5-18.0L DCDM-9P6E5-18.0P DCDM-9PSF DCDM-9PSK DCDM-9PSL DCDM-9PSP DCDM-9S6E5-18.0B DCDM-9S6E518.0F DCDM-9S6E5-18.0K DCDM-9S6E5-18.0L DCDM-9S6E5-18.0P DCDM-9SSF DCDM-9SSK DCDM-9SSL DCDM-9SSP DCDM-25P6E5-18.0F DCDM-25P6E5-18.0K DCDM-25P6E5-18.0L DCDM-25P6E5-18.0P DCDM25PSB DCDM-25PSF DCDM-25PSK DCDM-25PSL DCDM-25PSP DCDM-25S6E5-18.0B DCDM-25S6E5-18.0F DCDM-25S6E5-18.0K DCDM-25S6E5-18.0L DCDM-25S6E5-18.0P
DCDM-51P6E5-36.0K 价格&库存
很抱歉,暂时无法提供与“DCDM-51P6E5-36.0K”相匹配的价格&库存,您可以联系我们找货
