TMPC0603H-R10YG-D
TMPC0603H-R10YG-D
    TAI-TECH(台庆)
    SMD,7.3x6.6mm
    功率电感 100nH ±30% IND_7.3X6.6MM_SM 3.00mm 7.30 x 6.60mm 1.7mΩ 32.5A
TMPC0603H-R10YG-D 数据手册
TAI-TECH P1 SMD Power Inductor TMPC0603H-Series(G)-D D 1. Features 1. Carbonyl Powder. 2. Compact design. Halogen 3. High current,low DCR,high efficiency. 4. Very low acoustic noise and very low leakage flux noise. Halogen-free 5. High reliability. 6. 100% Lead(Pb)-Free and RoHS compliant. 7. Operating temperature -40~+125℃(Including self - temperature rise) 2. Applications Note PC power system,incl. IMVP-6 DC/DC converter . 3. Dimensions A Recommend PC Board Pattern C H L E B  8R2 2019 D G Series A(mm) B(mm) C(mm) D(mm) E(mm) TMPC0603H 7.3±0.3 6.6±0.3 2.8±0.2 1.8±0.3 3.0±0.3 4. Part Numbering TMPC 0603 H A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: D/C - 8R2 MG D E - L(mm) G(mm) H(mm) 8.4 2.5 3.5 Note: 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.15mm and above. D F BxC Carbonyl Powder. 8R2=8.20uH K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%. Marking: Black.8R2 and 2019(20 YY, 19 WW,follow production date). TAI-TECH P2 5. Specification Part Number Inductance L0 (uH)±20% I rms ( A ) I sat ( A ) DCR (mΩ) Typ. @25℃ DCR (mΩ) Max. @25℃ TMPC0603H-R10YG-D 0.10±30% 32.5 60.0 1.2 1.7 TMPC0603H-R22YG-D 0.22±30% 23.0 40.0 2.1 2.8 TMPC0603H-R33MG-D 0.33 20.0 32.0 3.5 3.9 TMPC0603H-R36MG-D 0.36 19.0 32.0 3.6 4.2 TMPC0603H-R47MG-D 0.47 17.5 26.0 4.0 4.2 TMPC0603H-R56MG-D 0.56 16.5 25.5 4.7 5.0 TMPC0603H-R68MG-D 0.68 15.5 25.0 4.8 5.5 TMPC0603H-R82MG-D 0.82 13.0 24.0 6.7 8.0 TMPC0603H-1R0MG-D 1.00 11.0 22.0 8.3 10 TMPC0603H-1R5MG-D 1.50 9.00 18.0 13 15 TMPC0603H-2R2MG-D 2.20 8.00 14.0 18 20 TMPC0603H-3R3MG-D 3.30 6.00 13.5 28 30 TMPC0603H-4R7MG-D 4.70 5.50 10.0 37 40 TMPC0603H-5R6MG-D 5.60 5.00 9.00 43 48 TMPC0603H-6R8MG-D 6.80 4.50 8.00 54 60 TMPC0603H-8R2MG-D 8.20 4.00 7.50 64 68 TMPC0603H-100MG-D 10.0 3.50 6.00 75 85 TMPC0603H-150MG-D 15.0 3.00 4.00 107 123 TMPC0603H-220MG-D 22.0 2.00 3.50 165 190 Note: 1. Test frequency : Ls : 100KHz /1.0V. 2. All test data referenced to 25℃ ambient. 3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃ 5. Saturation Current (Isat) will cause L0 to drop approximately 30%. 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Special inquiries besides the above common used types can be met on your requirement. TAI-TECH 6. Typical Performance Curves P3 TAI-TECH P4
TMPC0603H-R10YG-D 价格&库存
很抱歉,暂时无法提供与“TMPC0603H-R10YG-D”相匹配的价格&库存,您可以联系我们找货
