RSU12N65F
RSU12N65F
    REASUNOS(瑞森半导体)
    TO-220F-3
    MOS管 N-Channel VDS=650V VGS=±30V ID=12A RDS(ON)=420mΩ TO220F-3
RSU12N65F 数据手册
RSU12N65F Multi-Epi Super Junction MOSFETs Lead Free Package and Finish Applications: RDS(ON)(Max.) ID 12A 420mΩ VDSS 650V RSU12N65F Units 650 12 7 44 31 ±30 V IDM PD VGS Drain-to-Source Voltage Continuous Drain Current (TC = 25℃) Continuous Drain Current (TC = 100℃) Pulsed Drain Current (Note*1) Power Dissipation(Tc=25℃) Gate-to-Source Voltage W V EAS Single Pulse Avalanche Engergy 120 mJ IAR Avalanche Current EAR Repetitive Avalanche Engergy •Switch Mode Power Supply(SMPS) •Uninterruptible Power Supply(UPS) •PFC stages for server & telecom •Consumer Features: •New revolutionary high voltage technology •Better RDS(on) in TO-220F •Ultra Low Gate Charge cause lower driving requirements •Periodic avalanche rated •Ultra low effective capacitances Ordering Information Not to Scale Part Number Package RSU12N65F TO-220F Marking RSU12N65F Absolute Maximun Ratings Tc=25℃ unless otherwise specified Symbol VDSS ID Parameter (Note*2) (Note*1) (Note*1) A 1.8 A 0.32 mJ Maximum Temperature for Soldering TL TPKG TJ and TSTG 300 260 Leads at 0.063in(1.6mm)from Case for 10 seconds Package Body for 10 seconds Operating Junction and Storage Temperature Range ℃ -55 to 150 *Drain Current Limited by Maximum Junction Temperature Caution:Stresses greater than those listed in the“Absolute Maximum Ratings”Table may cause permanent damage to the device. Thermal Resistance Symbol Parameter RSU12N65F RθJC Junction-to-Case 4 RθJA Junction-to-Ambient 78 Copyright Reasunos http://www.reasunos.com Units Test Conditions Drain lead soldered to water cooled heatsink,PD ℃/W REV:A6 Nov.2019 Adjusted for a peak junction temperature of +150℃. 1 cubic foot chamber,free air. Page 1 of 8 RSU12N65F OFF Characteristics TJ=25 ℃ unless otherwise specified Symbol BVDSS IDSS IGSS Parameter Min. Typ. Max. Units 650 -- -- V -- 650 -- V Drain-to-Source Leakage Current -- -- 1.0 µA Gate-to-Source Forward Leakage -- -- 100 Gate-to-Source Reverse Leakage -- -- -100 Drain-to-source Breakdown Voltage nA Test Conditions VGS = 0V, ID = 250µA, TJ= 25℃ VGS = 0V, ID = 250µA, TJ= 150℃ VDS=650V,VGS=0V VGS=+30V VDS=0V VGS=-30V VDS=0V ON Characteristics TJ=25 ℃ unless otherwise specified Symbol Parameter RDS(on) Static Drain-to-Source On-Resistance VGS(TH) Gate Threshold Voltage gfs Transconductance Min. Typ. Max. Units -- 380 420 mΩ VGS=10V,ID=6A 3.5 4 4.5 V VGS=VDS,ID=250µA S VDS=20V,ID=6A 40 Test Conditions Resistive Switching Characteristics Essentially independent of operating temperature Symbol Parameter Min. Typ. Max. Units td(ON) Turn-on Delay Time -- 21 -- trise Rise Time -- 20 -- td(OFF) Turn-OFF Delay Time -- 51 tfall Fall Time -- 40 ns Test Conditions VDS=400V ID=6A RG=25Ω VGS=10V Dynamic Characteristics Essentially independent of operating temperature Symbol Parameter Min. Typ. Max. Units Ciss Input Capacitance -- 850 -- Coss Output Capacitance -- 35 -- Crss Reverse Transfer Capacitance -- 5 -- Qg Total Gate Charge -- 19 -- Qgs Gate-to-Source Charge -- 6 -- Qgd Gate-to-Drain("Miller")Charge -- 6 -- Copyright Reasunos http://www.reasunos.com REV:A6 Nov.2019 Test Conditions pF VGS=0V VDS=100V f=1.0MHz nC VDS=520V ID=12A VGS=10V Page 2 of 8 RSU12N65F Source-Drain Diode Characteristics Symbol Parameter Min. Typ. Max. Units Test Conditions IS Continuous Source Current -- -- 12 A ISM Maximum Pulsed Current -- -- 44 A Integral pn-diode in MOSFET VSD Diode Forward Voltage -- 0.9 1.2 V IS=12A,VGS=0V Tj=25℃ trr Reverse Recovery Time -- 212 -- nS Qrr Reverse Recovery Charge -- 2.28 -- µC VR=400V,VGS=0V IS=12A,di/dt=100A/µs Notes: *1.Repetitive rating;pulse width limited by maximum junction temperature. *2. IAS = 1.8A, VDD = 50V, RG = 25Ω, Starting TJ = 25°CPulse width tp limited by Tj,max Typical Feature curve TJ=25℃, unless otherwise noted Copyright Reasunos http://www.reasunos.com REV:A6 Nov.2019 Page 3 of 8 RSU12N65F Copyright Reasunos http://www.reasunos.com REV:A6 Nov.2019 Page 4 of 8 RSU12N65F Copyright Reasunos http://www.reasunos.com REV:A6 Nov.2019 Page 5 of 8 RSU12N65F Test Circuits and Waveforms # # Copyright Reasunos http://www.reasunos.com REV:A6 Nov.2019 Page 6 of 8 RSU12N65F Package outline drawing Unit:mm Copyright Reasunos http://www.reasunos.com REV:A6 Nov.2019 Page 7 of 8 RSU12N65F Disclaimers: Reasunos Semiconductor Technology CO.,LTD(Reasunos)reserves the right to make changes without notice in order to improve reliability,function or design and to discontinue any product or service without notice .Customers should obtain the latest relevant information before orders and should verify that such information in current and complete.All products are sold subject to Reasunos's terms and conditions supplied at the time of order acknowledgement. Reasunos Semiconductor Technology CO.,LTD warrants performance of its hardware products to the speciffications at the time of sale.Testing,reliability and quality control are used to the extene Reasunos deems necessary to support this warrantee. Except where agreed upon by contractual agreement,testing of all parameters of each product is not necessarily performed. Reasunos Semiconductor Technology CO.,LTD does not assume any liability arising from the use of any product or circuit designs described herein.Customers are responsible for their products and applications using Reasunos's components.To minimize risk,customers must provide adequate design and operating safeguards. Reasunos Semiconductor Technology CO.,LTD does not warrant or convey any license either expressed or implied under its patent rights,nor the rights of others.Reproduction of information in Reasunos's data sheeets or data books is permissible only if reproduction is without modification oralteration.Reproduction of this information with any alteration is an unfair and deceptive business practice. Reasunos Semiconductor Technology CO.,LTD is not responsible or liable for such altered documentation. Resale of Reasunos's products with statements different from or beyond the parameters stated by Reasunos Semiconductor Technology CO.,LTD for that product or service voids all express or implied warrantees for the associated Reasunos's product or service and is unfair and deceptive business practice. Reasunos Semiconductor Technology CO.,LTD is not responsible or liable for such statements. Life Support Policy: Reasunos Semiconductor Technology CO.,LTD's Products are not authorized for use as critical components in life support devices or systems without the expressed written approval of Reasunos Semiconductor Technology CO.,LTD. As used herein: 1.Life support devices or systems are devices or systems which: a.are intended for surgical implant into the human body, b.support or sustain life, c.whose failuer to when properly used in accordance with instructions for used provided in the laeling,can be reasonably expected to result in significant injury to the user. system whose failure to perform can be reasonably expected to cause the failure of the life support device or system,or to affect its safety or effectiveness. Copyright Reasunos http://www.reasunos.com REV:A6 Nov.2019 Page 8 of 8
RSU12N65F 价格&库存
很抱歉,暂时无法提供与“RSU12N65F”相匹配的价格&库存,您可以联系我们找货
RSU12N65F
  • 1+2.79500
  • 10+2.58000
  • 30+2.53700
  • 100+2.40800
